MT3000 Beryl AX Firmware upgrade Issue
I am trying to update the firmware of the Beryl AX from 4.6.0 Alpha 1 to either 4.5.16 or 4.6.0 dated April 13, but in both cases I get the following problem:
Any suggestions on how to solve without resetting the router?
Or is the only possibility to do a router resetting…?
I have tested it and the issue you mentioned did not recur. Could you tell me your current firmware version information, or maybe you could provide a screenshot?
Do you still have access to this 4.6.0 alpha version of the firmware? Would you be able to send it to me so I can try it out?
If I remember correctly, this should be it:
However, I solved it by doing a ‘UBOOT’ firmware installation
