Splitting the following topic to aid clarity:
[MT3000: Beryl AX Wi-FI 5G Wireguard DNS OPNsense](https://MT3000: Beryl AX Wi-FI 5G Wireguard DNS OPNsense)
Here are ssh scans from a Beryl and an Opal run at the same time:
Opal
root@opal-GL-SFT1200:~# date ; iwinfo wlan1 scan
Sat Nov 23 11:59:40 GMT 2024
Cell 01 - Address: EE:38:83:25:6C:62
ESSID: "Mynet-2"
Mode: Master Channel: 44
Signal: -35 dBm Quality: 70/70
Encryption: WPA2 PSK (CCMP)
HT Capabilities: HT20 HT40 VHT20 VHT40
Cell 02 - Address: 12:59:32:0E:4F:15
ESSID: "DIRECT-roku-614-D07D56"
Signal: -70 dBm Quality: 40/70
Cell 03 - Address: BE:D7:D4:59:12:0E
ESSID: unknown
Cell 04 - Address: 8A:0A:B6:12:66:75
ESSID: "GL-MT3000-930-5G"
Signal: -22 dBm Quality: 70/70
Cell 05 - Address: EA:38:83:25:6C:62
ESSID: "Mynet-1"
Signal: -36 dBm Quality: 70/70
Cell 06 - Address: F2:38:83:25:6C:62
ESSID: "Mynet-3"
Cell 07 - Address: F6:38:83:25:6C:62
ESSID: unknown
Cell 08 - Address: FA:38:83:25:6C:62
ESSID: unknown
Cell 09 - Address: 80:75:1F:DD:3D:95
ESSID: "SKYDU18P"
Mode: Master Channel: 36
Signal: -86 dBm Quality: 24/70
HT Capabilities: HT20 HT40 VHT20 VHT40 VHT80
Cell 10 - Address: 90:02:18:4D:2F:02
ESSID: "SKY0013F"
Signal: -83 dBm Quality: 27/70
Cell 11 - Address: 80:72:15:37:BC:1D
ESSID: "SKYDU18P"
Signal: -79 dBm Quality: 31/70
Cell 12 - Address: AA:B5:7C:E7:C8:D0
ESSID: unknown
Mode: Master Channel: 161
Cell 13 - Address: EA:38:83:25:D7:29
ESSID: "Mynet-1"
Signal: -45 dBm Quality: 65/70
Cell 14 - Address: EE:38:83:25:D7:29
ESSID: "Mynet-2"
Cell 15 - Address: F2:38:83:25:D7:29
ESSID: "Mynet-3"
Cell 16 - Address: F6:38:83:25:D7:29
ESSID: unknown
Cell 17 - Address: FA:38:83:25:D7:29
ESSID: unknown
Cell 18 - Address: EA:38:83:26:1F:93
ESSID: "Mynet-1"
Signal: -59 dBm Quality: 51/70
Cell 19 - Address: EE:38:83:26:1F:93
ESSID: "Mynet-2"
Cell 20 - Address: F2:38:83:26:1F:93
ESSID: "Mynet-3"
Cell 21 - Address: F6:38:83:26:1F:93
ESSID: unknown
Cell 22 - Address: FA:38:83:26:1F:93
ESSID: unknown
Beryl
root@beryl-GL-MT3000:~# date ; iwpriv apclix0 get_site_survey
apclix0 get_site_survey:
Total=9
No Ch SSID BSSID Security Rssi Siganl(%)W-Mode ExtCH NT SSID_Len WPS DPID BcnRept MWDSCap MDId FToverDS RsrReqCap
0 44 be:d7:d4:59:12:0e WPA2PSK/AES -75 37 11a/n NONE In 0 YES NO NO
1 44 DIRECT-roku-614-D07D56 12:59:32:0e:4f:15 WPA2PSK/AES -72 44 11a/n NONE In 22 YES NO NO
2 44 Mynet-1 ea:38:83:25:6c:62 WPA2PSK/AES -44 100 11a/n/ac/ax ABOVE In 10 NO NO NO
3 44 Mynet-2 ee:38:83:25:6c:62 WPA2PSK/AES -44 100 11a/n/ac/ax ABOVE In 4 NO NO NO
4 44 Mynet-3 f2:38:83:25:6c:62 WPA2PSK/AES -44 100 11a/n/ac/ax ABOVE In 4 NO NO NO
5 44 f6:38:83:25:6c:62 WPA2PSK/AES -44 100 11a/n/ac/ax ABOVE In 0 NO NO NO
6 44 fa:38:83:25:6c:62 WPA2PSK/AES -44 100 11a/n/ac/ax ABOVE In 0 NO NO NO
7 44 GL-SFT1200-1ec-5G 94:83:c4:5a:01:ef WPA2PSK/AES -40 100 11a/n/ac ABOVE In 17 YES NO NO
8 48 82:d6:d0:85:a5:27 WPA2PSK/AES -77 31 11a/n NONE In 0 YES NO NO
On the Beryl I have now had time to run netowrk scans for 2.4GHz and 5GHz for firmware
4.7.0b6, 4.6.9 and 4.6.6-op24.
Only the scans from 4.6.6-op24 look to be reliable.
Post 1 of 2
2.4 GHz
4.7.0b6
root@beryl-GL-MT3000:~# iwpriv apcli0 get_site_survey
apcli0 get_site_survey:
Total=16
0 1 TNCAPF770C3 a4:91:b1:f7:70:c3 WPA2PSK/AES -81 23 11b/g/n NONE In 11 YES NO NO
1 1 BT-99CPRM d4:86:60:48:ad:69 WPA2PSK/AES -98 0 11b/g/n NONE In 9 YES NO NO
2 1 TAG b8:be:f4:a5:a9:83 WPAPSKWPA2PSK/TKIPAES -60 76 11b/g/n NONE In 3 YES NO NO 0102 TRUE FALSE
3 1 vodafone069CED d4:6e:0e:9f:5b:b9 WPAPSKWPA2PSK/TKIPAES -89 2 11b/g/n NONE In 14 YES NO NO
4 1 [washer]_E30AJT2103349V 40:ca:63:1c:44:88 WPA2PSK/AES -65 63 11b/g/n NONE In 23 NO NO NO
5 1 6a:b6:87:83:77:11 WPA2PSK/AES -97 0 11b/g/n NONE In 0 NO NO NO
6 1 BT-96F68K ac:b6:87:83:77:15 WPA2PSK/AES -98 0 11b/g/n NONE In 9 YES NO NO
7 1 e4:38:83:25:6c:61 WPA2PSK/AES -32 100 11b/g/n/ax NONE In 0 NO NO NO
8 1 SKYSMXN2 0c:f9:c0:9d:35:1e WPA2PSK/AES -92 0 11b/g/n NONE In 8 YES NO NO
9 1 VTECH_7766_bffb a6:97:5c:a6:bf:fb WPA2PSK/TKIPAES -95 0 11b/g/n NONE In 15 NO NO NO
10 9 62:e9:31:e1:93:3a WPA2PSK/AES -94 0 11b/g/n ABOVE In 0 NO NO NO
11 9 62:e9:31:e1:92:66 WPA2PSK/AES -95 0 11b/g/n ABOVE In 0 NO NO NO
12 9 168 Home 5c:e9:31:e1:93:3a WPA2PSK/AES -95 0 11b/g/n ABOVE In 8 YES NO NO
13 11 SKYDU18P 90:02:18:4c:07:dc WPA2PSK/AES -81 23 11b/g/n NONE In 8 YES NO NO
14 11 SKYSMXN2 50:70:43:6a:11:ba WPA2PSK/AES -92 0 11b/g/n NONE In 8 YES NO NO
15 11 e4:38:83:25:d7:28 WPA2PSK/AES -68 55 11b/g/n/ax NONE In 0 NO NO NO
4.6.9
root@beryl-GL-MT3000:~# date ; iwpriv apcli0 get_site_survey
Wed Oct 30 09:57:22 UTC 2024
Total=48
0 6 EXT-SKYULWEA c8:3a:35:fd:60:40 WPA2PSK/AES -86 10 11b/g/n NONE In 12 NO NO NO
1 6 SKYYNMUI e8:76:40:49:7d:0d WPA2PSKWPA3PSK/AES -95 0 11b/g/n/ax NONE In 8 YES NO NO
2 6 SKYULWEA 80:72:15:9a:7b:aa WPA2PSK/AES -94 0 11b/g/n NONE In 8 YES NO NO
3 1 62:75:dc:3b:90:8c WPA2PSK/AES -92 0 11b/g/n NONE In 0 NO NO NO
4 1 e4:38:83:25:6c:61 WPA2PSK/AES -36 100 11b/g/n/ax NONE In 0 NO NO NO
5 1 PLUSNET-9HF6X5 4c:22:f3:5b:f3:ac WPA2PSK/AES -91 0 11b/g/n NONE In 14 YES NO NO
6 1 TNCAPF770C3 a4:91:b1:f7:70:c3 WPA2PSK/AES -79 26 11b/g/n NONE In 11 YES NO NO
7 1 [washer]_E30AJT2103349V 40:ca:63:1c:44:88 WPA2PSK/AES -70 50 11b/g/n NONE In 23 NO NO NO
8 1 TAG b8:be:f4:a5:a9:83 WPAPSKWPA2PSK/TKIPAES -62 70 11b/g/n NONE In 3 YES NO NO 0102 TRUE FALSE
9 1 hubertz.wifi-2 48:8d:36:f4:2e:45 WPA2PSK/AES -93 0 11b/g/n NONE In 14 YES NO NO
10 6 e4:38:83:26:1f:92 WPA2PSK/AES -65 63 11b/g/n/ax NONE In 0 NO NO NO
11 6 Living Room TV.v, fa:8f:ca:7c:2f:67 OPEN/NONE -97 0 11b/g/n NONE In 17 NO NO NO
12 6 EE-FC9GR8 fa:f8:7e:50:01:3f WPA2PSK/AES -93 0 11b/g/n/ax NONE In 9 YES NO NO
13 6 vodafoneB20FBB d4:92:5e:b2:0f:bb WPA2PSK/AES -96 0 11b/g/n NONE In 14 YES NO NO
14 6 vodafone0F4DC3 d4:35:1d:0f:4d:c3 WPA2PSK/AES -99 0 11b/g/n NONE In 14 YES NO NO
15 11 GL-SFT1200-1ec 94:83:c4:5a:01:ee WPA2PSK/AES -31 100 11b/g/n BELOW In 14 YES NO NO
16 9 62:e9:31:e1:93:3a WPA2PSK/AES -95 0 11b/g/n ABOVE In 0 NO NO NO
17 9 168 Home 5c:e9:31:e1:92:66 WPA2PSK/AES -96 0 11b/g/n ABOVE In 8 YES NO NO
18 9 62:e9:31:e1:93:02 WPA2PSK/AES -97 0 11b/g/n ABOVE In 0 NO NO NO
19 9 168 Home 5c:e9:31:e1:93:02 WPA2PSK/AES -99 0 11b/g/n ABOVE In 8 YES NO NO
20 9 62:e9:31:e1:92:66 WPA2PSK/AES -95 0 11b/g/n ABOVE In 0 NO NO NO
21 11 YourCruise-WiFi 8e:d4:45:24:c3:58 WPA2PSK/AES -56 86 11b/g/n/ax NONE In 15 NO NO NO
22 11 SKYDU18P 80:72:15:37:bc:1a WPA2PSK/AES -67 57 11b/g/n NONE In 8 YES NO NO
23 11 e4:38:83:25:d7:28 WPA2PSK/AES -69 52 11b/g/n/ax NONE In 0 NO NO NO
24 11 SKYSMXN2 50:70:43:6a:11:ba WPA2PSK/AES -90 0 11b/g/n NONE In 8 YES NO NO
25 11 SKYDU18P 80:75:1f:dd:3d:92 WPA2PSK/AES -77 31 11b/g/n NONE In 8 YES NO NO
26 11 SKYDU18P d4:52:ee:14:0f:3e WPA2PSK/AES -79 26 11b/g/n NONE In 8 YES NO NO
27 11 SKYKDJSP c0:a3:6e:86:cc:72 WPA2PSK/AES -96 0 11b/g/n NONE In 8 YES NO NO
28 11 EE WiFi 62:ce:da:40:65:89 OPEN/NONE -100 0 11b/g/n NONE In 7 NO NO NO
29 11 62:6c:9a:45:06:0c WPA2PSK/AES -96 0 11b/g/n NONE In 0 NO NO NO
30 11 EE WiFi 62:6c:9a:45:06:09 OPEN/NONE -97 0 11b/g/n NONE In 7 NO NO NO
31 11 SKYCKNZS e8:76:40:53:45:ad WPA2PSKWPA3PSK/AES -94 0 11b/g/n/ax NONE In 8 YES NO NO
32 11 BT-2FCK58 8c:19:b5:64:0d:78 WPA2PSK/AES -98 0 11b/g/n NONE In 9 YES NO NO
33 11 SKYDU18P 90:02:18:4c:07:dc WPA2PSK/AES -91 0 11b/g/n NONE In 8 YES NO NO
34 6 VWifiEXT2.4G d8:47:32:fa:40:d4 WPA2PSK/TKIPAES -97 0 11b/g/n NONE In 12 YES NO NO
35 6 40:47:5e:0a:aa:69 OPEN/NONE -92 0 11b/g/n/ax BELOW In 0 NO NO NO
36 1 BT-99CPRM d4:86:60:48:ad:69 WPA2PSK/AES -97 0 11b/g/n NONE In 9 YES NO NO
37 1 EE WiFi 62:75:dc:3b:90:89 OPEN/NONE -92 0 11b/g/n NONE In 7 NO NO NO
38 1 BT-96F68K ac:b6:87:83:77:15 WPA2PSK/AES -95 0 11b/g/n NONE In 9 YES NO NO
39 1 62:22:f3:5b:f3:a8 WPA2PSK/AES -90 0 11b/g/n NONE In 0 NO NO NO
40 1 6a:8d:36:f4:2e:41 WPA2PSK/AES -95 0 11b/g/n NONE In 0 NO NO NO
41 1 EE WiFi 6a:8d:36:f4:2e:46 OPEN/NONE -94 0 11b/g/n NONE In 7 NO NO NO
42 1 BT-NJAK3K e4:75:dc:3b:90:88 WPA2PSK/AES -93 0 11b/g/n NONE In 9 YES NO NO
43 1 6a:b6:87:83:77:11 WPA2PSK/AES -97 0 11b/g/n NONE In 0 NO NO NO
44 6 Giganet_CityFibre 40:47:5e:0a:aa:66 WPA2PSK/AES -92 0 11b/g/n/ax BELOW In 17 NO NO NO
45 9 168 Home 5c:e9:31:e1:93:3a WPA2PSK/AES -96 0 11b/g/n ABOVE In 8 YES NO NO
46 11 BT-7WAKHJ ec:6c:9a:45:06:08 WPA2PSK/AES -96 0 11b/g/n NONE In 9 YES NO NO
47 4 TALKTALK5ED02F 18:cf:24:5e:d0:40 WPA2PSK/AES -99 0 11b/g/n NONE In 14 YES NO NO
4.6.6-op24
root@beryl-GL-MT3000:~# iwinfo wlan0 scan
Cell 01 - Address: E4:38:83:25:6C:61
ESSID: unknown
Mode: Master Frequency: 2.412 GHz Band: 2.4 GHz Channel: 1
Signal: -27 dBm Quality: 70/70
HT Operation:
Primary Channel: 1
Secondary Channel Offset: no secondary
Channel Width: 20 MHz
VHT Operation:
Center Frequency 1: 1
Center Frequency 2: 0
Channel Width: 20 or 40 MHz
Cell 02 - Address: 62:75:DC:3B:90:89
ESSID: "EE WiFi"
Signal: -90 dBm Quality: 20/70
Encryption: none
HT Operation:
Primary Channel: 1
Cell 03 - Address: 62:22:F3:5B:F3:A8
ESSID: unknown
Signal: -87 dBm Quality: 23/70
HT Operation:
Primary Channel: 1
Channel Width: 40 MHz or higher
Cell 04 - Address: 4C:22:F3:5B:F3:AC
ESSID: "PLUSNET-9HF6X5"
HT Operation:
Primary Channel: 1
Cell 05 - Address: 40:CA:63:1C:44:88
ESSID: "[washer]_E30AJT2103349V"
Signal: -63 dBm Quality: 47/70
HT Operation:
Primary Channel: 1
Cell 06 - Address: 6A:8D:36:F4:2E:41
ESSID: unknown
Signal: -92 dBm Quality: 18/70
HT Operation:
Primary Channel: 1
Cell 07 - Address: A4:91:B1:F7:70:C3
ESSID: "TNCAPF770C3"
Signal: -73 dBm Quality: 37/70
HT Operation:
Primary Channel: 1
Cell 08 - Address: D4:86:60:48:AD:69
ESSID: "BT-99CPRM"
Signal: -94 dBm Quality: 16/70
HT Operation:
Primary Channel: 1
Cell 09 - Address: 6A:86:60:48:AD:6A
ESSID: "EE WiFi"
Signal: -93 dBm Quality: 17/70
Encryption: none
HT Operation:
Primary Channel: 1
Cell 10 - Address: E4:75:DC:3B:90:88
ESSID: "BT-NJAK3K"
HT Operation:
Primary Channel: 1
Cell 11 - Address: D4:6E:0E:9F:5B:B9
ESSID: "vodafone069CED"
Signal: -88 dBm Quality: 22/70
Encryption: mixed WPA/WPA2 PSK (TKIP, CCMP)
HT Operation:
Primary Channel: 1
Cell 12 - Address: 62:75:DC:3B:90:8C
ESSID: unknown
Signal: -95 dBm Quality: 15/70
HT Operation:
Primary Channel: 1
Cell 13 - Address: 48:8D:36:F4:2E:45
ESSID: "hubertz.wifi-2"
HT Operation:
Primary Channel: 1
Cell 14 - Address: 7A:99:B2:A8:C4:2F
ESSID: unknown
Signal: -85 dBm Quality: 25/70
HT Operation:
Primary Channel: 1
Cell 15 - Address: C8:99:B2:A8:C4:2B
ESSID: "PLUSNET-28C276"
Signal: -84 dBm Quality: 26/70
HT Operation:
Primary Channel: 1
Cell 16 - Address: 0C:F9:C0:9D:35:1E
ESSID: "SKYSMXN2"
Signal: -89 dBm Quality: 21/70
HT Operation:
Primary Channel: 1
Cell 17 - Address: A6:97:5C:A6:BF:FB
ESSID: "VTECH_7766_bffb"
Encryption: WPA2 PSK (TKIP, CCMP)
HT Operation:
Primary Channel: 1
Cell 18 - Address: 6A:86:60:48:AD:6D
ESSID: unknown
HT Operation:
Primary Channel: 1
Cell 19 - Address: AC:B6:87:83:77:15
ESSID: "BT-96F68K"
Signal: -96 dBm Quality: 14/70
HT Operation:
Primary Channel: 1
Cell 20 - Address: 6A:B6:87:83:77:16
ESSID: "EE WiFi"
Encryption: none
HT Operation:
Primary Channel: 1
Cell 21 - Address: 6A:8D:36:F4:2E:46
ESSID: "EE WiFi"
Encryption: none
HT Operation:
Primary Channel: 1
Cell 22 - Address: 6A:B6:87:83:77:11
ESSID: unknown
HT Operation:
Primary Channel: 1
Cell 23 - Address: E4:38:83:26:1F:92
ESSID: unknown
Mode: Master Frequency: 2.437 GHz Band: 2.4 GHz Channel: 6
Signal: -64 dBm Quality: 46/70
HT Operation:
Primary Channel: 6
VHT Operation:
Center Frequency 1: 6
Cell 24 - Address: D4:35:1D:06:9C:ED
HT Operation:
Primary Channel: 1
Cell 25 - Address: 6C:A0:B4:10:CF:42
ESSID: "SKY05BD0"
Signal: -97 dBm Quality: 13/70
HT Operation:
Primary Channel: 1
Cell 26 - Address: B8:BE:F4:A5:A9:83
ESSID: "TAG"
Signal: -56 dBm Quality: 54/70
HT Operation:
Primary Channel: 6
VHT Operation:
Cell 27 - Address: D4:52:EE:14:0F:3E
ESSID: "SKYDU18P"
Signal: -68 dBm Quality: 42/70
HT Operation:
Primary Channel: 6
Cell 28 - Address: D4:35:1D:23:D9:E3
ESSID: "VWifi2.4G"
HT Operation:
Primary Channel: 6
Cell 29 - Address: FA:8F:CA:7C:2F:67
ESSID: "Living Room TV.v,"
Encryption: none
HT Operation:
Primary Channel: 6
Cell 30 - Address: E8:76:40:49:7D:0D
ESSID: "SKYYNMUI"
Encryption: mixed WPA2/WPA3 PSK/SAE (CCMP)
HT Operation:
Primary Channel: 6
Cell 31 - Address: 80:72:15:9A:7B:AA
ESSID: "SKYULWEA"
Signal: -91 dBm Quality: 19/70
HT Operation:
Primary Channel: 6
Cell 32 - Address: 94:83:C4:5A:01:EE
ESSID: "GL-SFT1200-1ec"
Mode: Master Frequency: 2.462 GHz Band: 2.4 GHz Channel: 11
HT Operation:
Primary Channel: 11
Secondary Channel Offset: below
Cell 33 - Address: 62:E9:31:E1:92:66
ESSID: unknown
Mode: Master Frequency: 2.452 GHz Band: 2.4 GHz Channel: 9
HT Operation:
Primary Channel: 9
Secondary Channel Offset: above
Cell 34 - Address: 5C:E9:31:E1:92:66
ESSID: "168 Home"
HT Operation:
Primary Channel: 9
Cell 35 - Address: 5C:E9:31:E1:93:3A
ESSID: "168 Home"
HT Operation:
Primary Channel: 9
Cell 36 - Address: 80:75:1F:DD:3D:92
ESSID: "SKYDU18P"
HT Operation:
Primary Channel: 11
Cell 37 - Address: 90:02:18:4C:07:DC
ESSID: "SKYDU18P"
Signal: -78 dBm Quality: 32/70
HT Operation:
Primary Channel: 11
Cell 38 - Address: 80:72:15:37:BC:1A
ESSID: "SKYDU18P"
HT Operation:
Primary Channel: 11
Cell 39 - Address: 8E:D4:45:24:C3:58
ESSID: "YourCruise-WiFi"
Signal: -50 dBm Quality: 60/70
HT Operation:
Primary Channel: 11
Cell 40 - Address: EC:6C:9A:45:06:08
ESSID: "BT-7WAKHJ"
HT Operation:
Primary Channel: 11
Cell 41 - Address: 62:6C:9A:45:06:09
ESSID: "EE WiFi"
Encryption: none
HT Operation:
Primary Channel: 11
Cell 42 - Address: E4:38:83:25:D7:28
ESSID: unknown
Signal: -40 dBm Quality: 70/70
HT Operation:
Primary Channel: 11
VHT Operation:
Center Frequency 1: 11
Cell 43 - Address: 50:70:43:6A:11:BA
ESSID: "SKYSMXN2"
HT Operation:
Primary Channel: 11
Cell 44 - Address: 62:19:B5:64:0D:79
ESSID: "EE WiFi"
Encryption: none
HT Operation:
Primary Channel: 11
Post 2 of 2
5 GHz
4.7.0b6
root@beryl-GL-MT3000:~# iwpriv apclix0 get_site_survey
Total=9
4.6.9
Total=13
0 36 SKY0013F 90:02:18:4d:2f:02 WPA2PSK/AES -88 5 11a/n/ac ABOVE In 8 YES NO NO
1 36 SKYDU18P 80:72:15:37:bc:1d WPA2PSK/AES -90 0 11a/n/ac ABOVE In 8 YES NO NO
2 36 SKYDU18P 80:75:1f:dd:3d:95 WPA2PSK/AES -98 0 11a/n/ac ABOVE In 8 YES NO NO
3 36 SKYDU18P d4:52:ee:14:0f:3b WPA2PSK/AES -102 0 11a/n/ac ABOVE In 8 YES NO NO
4 44 be:d7:d4:59:12:0e WPA2PSK/AES -75 37 11a/n NONE In 0 YES NO NO
5 44 12:59:32:0e:4f:15 WPA2PSK/AES -74 39 11a/n NONE In 0 YES NO NO
6 44 Mynet-1 ea:38:83:25:6c:62 WPA2PSK/AES -43 100 11a/n/ac/ax ABOVE In 10 NO NO NO
7 44 Mynet-2 ee:38:83:25:6c:62 WPA2PSK/AES -43 100 11a/n/ac/ax ABOVE In 4 NO NO NO
8 44 Mynet-3 f2:38:83:25:6c:62 WPA2PSK/AES -44 100 11a/n/ac/ax ABOVE In 4 NO NO NO
9 44 f6:38:83:25:6c:62 WPA2PSK/AES -44 100 11a/n/ac/ax ABOVE In 0 NO NO NO
10 44 fa:38:83:25:6c:62 WPA2PSK/AES -43 100 11a/n/ac/ax ABOVE In 0 NO NO NO
11 44 GL-SFT1200-1ec-5G 94:83:c4:5a:01:ef WPA2PSK/AES -39 100 11a/n/ac ABOVE In 17 YES NO NO
12 48 82:d6:d0:85:a5:27 WPA2PSK/AES -78 29 11a/n NONE In 0 YES NO NO
4.6.6-op24
root@beryl-GL-MT3000:~# iwinfo wlan1 scan
Cell 01 - Address: 80:75:1F:DD:3D:95
ESSID: "SKYDU18P"
Mode: Master Frequency: 5.180 GHz Band: 5 GHz Channel: 36
HT Operation:
Primary Channel: 36
VHT Operation:
Center Frequency 1: 42
Channel Width: 80 MHz
Cell 02 - Address: 90:02:18:4D:2F:02
ESSID: "SKY0013F"
HT Operation:
Primary Channel: 36
VHT Operation:
Cell 03 - Address: 80:72:15:37:BC:1D
ESSID: "SKYDU18P"
HT Operation:
Primary Channel: 36
VHT Operation:
Cell 04 - Address: D4:52:EE:14:0F:3B
ESSID: "SKYDU18P"
Signal: -99 dBm Quality: 11/70
HT Operation:
Primary Channel: 36
VHT Operation:
Cell 05 - Address: 82:D6:D0:85:A5:27
ESSID: unknown
Mode: Master Frequency: 5.240 GHz Band: 5 GHz Channel: 48
Signal: -74 dBm Quality: 36/70
HT Operation:
Primary Channel: 48
Cell 06 - Address: EA:38:83:25:6C:62
ESSID: "Mynet-1"
Mode: Master Frequency: 5.220 GHz Band: 5 GHz Channel: 44
Signal: -41 dBm Quality: 69/70
HT Operation:
Primary Channel: 44
VHT Operation:
Center Frequency 1: 46
Cell 07 - Address: EE:38:83:25:6C:62
ESSID: "Mynet-2"
HT Operation:
Primary Channel: 44
VHT Operation:
Cell 08 - Address: F2:38:83:25:6C:62
ESSID: "Mynet-3"
HT Operation:
Primary Channel: 44
VHT Operation:
Cell 09 - Address: F6:38:83:25:6C:62
ESSID: unknown
HT Operation:
Primary Channel: 44
VHT Operation:
Cell 10 - Address: FA:38:83:25:6C:62
ESSID: unknown
HT Operation:
Primary Channel: 44
VHT Operation:
Cell 11 - Address: 12:59:32:0E:4F:15
ESSID: unknown
Signal: -71 dBm Quality: 39/70
HT Operation:
Primary Channel: 44
Cell 12 - Address: BE:D7:D4:59:12:0E
ESSID: unknown
Signal: -72 dBm Quality: 38/70
HT Operation:
Primary Channel: 44
Cell 13 - Address: 94:83:C4:5A:01:EF
ESSID: "GL-SFT1200-1ec-5G"
HT Operation:
Primary Channel: 44
VHT Operation:
Cell 14 - Address: A6:91:B1:F7:70:CB
Mode: Master Frequency: 5.280 GHz Band: 5 GHz Channel: 56
HT Operation:
Primary Channel: 56
VHT Operation:
Center Frequency 1: 58
Cell 15 - Address: 62:45:B6:39:60:73
ESSID: unknown
Mode: Master Frequency: 5.765 GHz Band: 5 GHz Channel: 153
Signal: -98 dBm Quality: 12/70
Encryption: WEP Open/Shared (WEP-40, WEP-104)
HT Operation:
Primary Channel: 0
Cell 16 - Address: AA:B5:7C:E7:C8:D0
ESSID: unknown
Mode: Master Frequency: 5.805 GHz Band: 5 GHz Channel: 161
HT Operation:
Primary Channel: 161
Cell 17 - Address: EA:38:83:26:1F:93
ESSID: "Mynet-1"
HT Operation:
VHT Operation:
Center Frequency 1: 159
Cell 18 - Address: EE:38:83:26:1F:93
ESSID: "Mynet-2"
HT Operation:
VHT Operation:
Cell 19 - Address: F2:38:83:26:1F:93
ESSID: "Mynet-3"
Signal: -58 dBm Quality: 52/70
HT Operation:
VHT Operation:
Cell 20 - Address: F6:38:83:26:1F:93
ESSID: unknown
HT Operation:
VHT Operation:
Cell 21 - Address: FA:38:83:26:1F:93
ESSID: unknown
HT Operation:
VHT Operation:
Cell 22 - Address: EA:38:83:25:D7:29
ESSID: "Mynet-1"
Signal: -48 dBm Quality: 62/70
HT Operation:
VHT Operation:
Cell 23 - Address: EE:38:83:25:D7:29
ESSID: "Mynet-2"
HT Operation:
VHT Operation:
Cell 24 - Address: F2:38:83:25:D7:29
ESSID: "Mynet-3"
HT Operation:
VHT Operation:
Cell 25 - Address: F6:38:83:25:D7:29
ESSID: unknown
HT Operation:
VHT Operation:
Cell 26 - Address: FA:38:83:25:D7:29
ESSID: unknown
HT Operation:
VHT Operation:
It does looks like the MT3000 is not configured to support DFS and Band 4 of 5G wifi in the default firmware.
