Hi. Using the beta 4.2.0 b4 from 2023-02-23 if you use the switch on the side to activate and deactivate Adguard Home the option to use Adguard to handle client requests does not survive using the button to disable and then enable it. Thanks
The latest release has been fixed.
I just loaded the most current snapshot from 2023-3-12 and the problem persists. To be clear if I have Adguard activated and using it to handle client requests when I disable it and then re enable it it no longer uses Adguard to handle client requests. Thank you
This is indeed a new issue, thanks for the feedback, we will fix it as soon as possible.
