I have an Beryl MT 3000 with the latest firmware 4.2.3. I tested the router at home in The Netherlands and with with a public wifi (with captive portal) and all worked fine. I’m on vacation now in France, and try to connect to the camping wifi. In the admin-page when I try to connect to repeater, it does not show ANY wifi SSID. I tried differtent Country codes (via luci) I tried also my own iPhone setting in wifi tethering-mode, does not show up. tried my wife’s Samsung S21 in wifi tethering mode, does not show up… I factory resetted the Beryl, with no result. I found the function, to goto: http://192.168.8.1/cgi-bin/luci/admin/network/wireless and do a scan there. In there I see all the wifi SSID available and around me…
… but you don’t see the campsite AP listed via the Beryl AX using GL GUI → Internet → Repeater → Connect? You shouldn’t need LuCI for this if it is a straightforward hotspot. Can your phone connect to Beryl AX (read: are the radios on? GL GUI → Wireless)?
The repeater feature has always been broken on these devices and flakey at the best of times. I had reported major similar problems with it in the past (one of my feedbacks was just a few days the flagship AXT1800 came out) and it is quite hard to believe that people are still having major issues up to this day. Really frustrating when one is trying to support this brand.
Yeah, you should be able to downgrade. Check the bottom of the GL product page, firmware. Upload the previous version via GL GUI → System → Upgrade → Local Upgrade .
