MT3000, Firmware 4.6.4 and Starlink
Thank you. I will install and post feedback as soon as possible.
If I have the disconnect, what information do I post? Is there extra logging in the normal logs?
You can post the whole log. Better to send to @JerryZhao via message directly.
Sent a message to Jerry with the logs after a disconnect happened.
Hi, can you help to try mt3000 4.6.6-op24 will have the same problem? Here is the link: GL.iNet download center
Can I save settings from the router (on 4.6.8 beta1) when I install this version? Or do I need to do a full reset of all settings?
Also, does it have support for USB Network Storage and DLNA built in?
Thanks
Switching between "normal" firmware and "op24" firmware always includes a complete reset of your device. Don't keep settings.
