MT3000, Firmware 4.6.4 and Starlink
I have my Starlink connected to my MT3000. I used to have an MT1300 but upgraded due to frequent disconnects of the Ethernet connection. Once I was using the MT3000, the issue went away.
However, I was away for 4 months and returned and upgraded the MT3000 to 4.6.4 (was previously on 4.5.16). Everything seemed OK, but I am seeing disconnects now on the Ethernet port again.
I will revert back to 4.5.16 and see if the issue disappears, but wondering if this is a known issue or I am a one-off with the problem and perhaps the issue is not on the MT3000....?
Thanks for any help.
Tue Oct 1 16:16:55 2024 kern.info kernel: [719273.867386] mtk_soc_eth 15100000.ethernet eth0: Link is Down
Tue Oct 1 16:16:55 2024 daemon.notice netifd: Network device 'eth0' link is down
Tue Oct 1 16:16:55 2024 daemon.notice netifd: Interface 'wan' has link connectivity loss
Tue Oct 1 16:16:55 2024 daemon.notice netifd: wan (21234): udhcpc: received SIGTERM
Tue Oct 1 16:16:55 2024 daemon.notice netifd: wan (21234): udhcpc: unicasting a release of 100.105.221.10 to 100.64.0.1
Tue Oct 1 16:16:55 2024 daemon.notice netifd: wan (21234): udhcpc: sending release
Tue Oct 1 16:16:55 2024 daemon.notice netifd: wan (21234): udhcpc: entering released state
Tue Oct 1 16:16:55 2024 daemon.notice netifd: wan (21234): Command failed: Permission denied
Tue Oct 1 16:16:55 2024 daemon.notice netifd: Interface 'wan' is now down
Tue Oct 1 16:16:55 2024 daemon.info avahi-daemon[5138]: Withdrawing address record for 100.105.221.10 on eth0.
Tue Oct 1 16:16:55 2024 daemon.info avahi-daemon[5138]: Leaving mDNS multicast group on interface eth0.IPv4 with address 100.105.221.10.
Tue Oct 1 16:16:55 2024 daemon.notice netifd: Interface 'wan' is disabled
Tue Oct 1 16:16:55 2024 daemon.info avahi-daemon[5138]: Interface eth0.IPv4 no longer relevant for mDNS.
Tue Oct 1 16:16:55 2024 daemon.info avahi-daemon[5138]: Interface eth0.IPv6 no longer relevant for mDNS.
Tue Oct 1 16:16:55 2024 daemon.info avahi-daemon[5138]: Leaving mDNS multicast group on interface eth0.IPv6 with address fe80::9683:c4ff:fe3a:a031.
Tue Oct 1 16:16:55 2024 daemon.info avahi-daemon[5138]: Withdrawing address record for fe80::9683:c4ff:fe3a:a031 on eth0.
Tue Oct 1 16:16:55 2024 kern.info kernel: [719273.957223] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
Tue Oct 1 16:16:55 2024 daemon.notice netifd: Interface 'wan' is enabled
Tue Oct 1 16:16:55 2024 user.notice firewall: Reloading firewall due to ifdown of wan ()
Tue Oct 1 16:16:55 2024 user.notice kmwan: config json str={ "op": 3, "data": { "cells": [ "wan" ] } }
Tue Oct 1 16:16:55 2024 kern.debug kernel: [719274.309376] kmwan: Delete node:wan
Tue Oct 1 16:17:15 2024 kern.info kernel: [719294.438160] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
Tue Oct 1 16:17:15 2024 kern.info kernel: [719294.446706] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Tue Oct 1 16:17:15 2024 daemon.notice netifd: Network device 'eth0' link is up
Tue Oct 1 16:17:15 2024 daemon.notice netifd: Interface 'wan' has link connectivity
Tue Oct 1 16:17:15 2024 daemon.notice netifd: Interface 'wan' is setting up now
Tue Oct 1 16:17:15 2024 daemon.notice netifd: wan (30270): udhcpc: started, v1.33.2
Tue Oct 1 16:17:15 2024 daemon.notice netifd: wan (30270): udhcpc: sending discover
Tue Oct 1 16:17:16 2024 kern.info kernel: [719295.461904] mtk_soc_eth 15100000.ethernet eth0: Link is Down
Tue Oct 1 16:17:16 2024 daemon.notice netifd: Network device 'eth0' link is down
Tue Oct 1 16:17:16 2024 daemon.notice netifd: Interface 'wan' has link connectivity loss
Tue Oct 1 16:17:16 2024 daemon.notice netifd: wan (30270): udhcpc: received SIGTERM
Tue Oct 1 16:17:16 2024 daemon.notice netifd: wan (30270): udhcpc: entering released state
Tue Oct 1 16:17:16 2024 daemon.notice netifd: wan (30270): Command failed: Permission denied
Tue Oct 1 16:17:16 2024 daemon.notice netifd: Interface 'wan' is now down
Tue Oct 1 16:17:16 2024 daemon.notice netifd: Interface 'wan' is disabled
Tue Oct 1 16:17:16 2024 daemon.notice netifd: Interface 'wan' is enabled
Tue Oct 1 16:17:16 2024 kern.info kernel: [719295.535203] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
Tue Oct 1 16:17:16 2024 user.notice firewall: Reloading firewall due to ifdown of wan ()
Tue Oct 1 16:17:17 2024 user.notice kmwan: config json str={ "op": 3, "data": { "cells": [ "wan" ] } }
Tue Oct 1 16:18:34 2024 kern.info kernel: [719373.330057] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
Tue Oct 1 16:18:34 2024 kern.info kernel: [719373.338602] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Tue Oct 1 16:18:34 2024 daemon.notice netifd: Network device 'eth0' link is up
Tue Oct 1 16:18:34 2024 daemon.notice netifd: Interface 'wan' has link connectivity
Tue Oct 1 16:18:34 2024 daemon.notice netifd: Interface 'wan' is setting up now
Tue Oct 1 16:18:34 2024 daemon.notice netifd: wan (31026): udhcpc: started, v1.33.2
Tue Oct 1 16:18:34 2024 daemon.notice netifd: wan (31026): udhcpc: sending discover
Tue Oct 1 16:18:36 2024 daemon.info avahi-daemon[5138]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::9683:c4ff:fe3a:a031.
Tue Oct 1 16:18:36 2024 daemon.info avahi-daemon[5138]: New relevant interface eth0.IPv6 for mDNS.
Tue Oct 1 16:18:36 2024 daemon.info avahi-daemon[5138]: Registering new address record for fe80::9683:c4ff:fe3a:a031 on eth0.*.
Tue Oct 1 16:18:38 2024 daemon.notice netifd: wan (31026): udhcpc: sending discover
Tue Oct 1 16:18:38 2024 daemon.notice netifd: wan (31026): udhcpc: sending select for 100.105.221.10
Tue Oct 1 16:18:38 2024 daemon.notice netifd: wan (31026): udhcpc: lease of 100.105.221.10 obtained, lease time 300
Tue Oct 1 16:18:38 2024 daemon.info avahi-daemon[5138]: Joining mDNS multicast group on interface eth0.IPv4 with address 100.105.221.10.
Tue Oct 1 16:18:38 2024 daemon.info avahi-daemon[5138]: New relevant interface eth0.IPv4 for mDNS.
Tue Oct 1 16:18:38 2024 daemon.info avahi-daemon[5138]: Registering new address record for 100.105.221.10 on eth0.IPv4.
Tue Oct 1 16:18:38 2024 daemon.notice netifd: Interface 'wan' is now up
Tue Oct 1 16:18:38 2024 user.notice firewall: Reloading firewall due to ifup of wan (eth0)
Tue Oct 1 16:18:38 2024 user.notice kmwan: config json str={ "op": 2, "data": { "cells": [ { "interface": "wan", "netdev": "eth0", "track_mode": "force", "addr_type": 4, "tracks": [ { "type": "ping", "ip": "1.1.1.1" }, { "type": "ping", "ip": "8.8.8.8" }, { "type": "ping", "ip": "208.67.222.222" }, { "type": "ping", "ip": "208.67.220.220" } ] } ] } }
Tue Oct 1 16:18:38 2024 kern.debug kernel: [719377.583424] [add_dev_config 287]add node success. iface:wan, dev:eth0, ifindex:2
In the MT3000 admin panel->Network->Network Acceleration, can you check if it is on.
Pls turn off Network Acceleration to see if it helps.
It was off already.
I installed 4.5.16 again last night and will let it run for a few days. If I do not have any disconnects then something changed to cause them in the new version of the firmware 4.6.4.
I will post an update in 2 days.
Thank you.
After about 4 days on the older firmware I have seen no drops to Starlink.
This means to me that an issue was introduced in the lastest version causing these drops on the WAN port.
Hoping someone from GL is paying attention and can look into this. If there are any logs I can send, I am happy to do so.
There is another thread on here also with the same issue to some other equipment. GL-MT3000 ethernet connection drops & no reconnect - #19 by UserGermany
Let me ask what the developer changed about the Ethernet driver between 4.5.16 and 4.6.4.
Please try this modified firmware.
I will try it.
Do you want to see logs if the issue continues on this version, or just let you know that the issue still happens?
If the issue does not happen obviously I will let you know.
I installed the firmware from above and will watch the connection and see what happens.
One issue I have, it seems that USB Drive Share support is not in this version of the firmware, and I rely on this heavily..... So I will not be able to keep the firmware on my router very long as I need to have my network shared USB drive available. I assume this feature is not going away in 4.7.0?
So far the firmware above has not caused me any drops with the Ethernet connection to Starlink.
Seems that this version of the firmware is working OK as best I can tell.
I am going to downgrade back to 4.5.16 since I am missing features in the above firmware, such as network USB drive, that I need.
Hopefully whatever changed makes it into the next release.
Ok, so bad news unfortunately with this.
I am back in to 4.5.16 and the issue happened on this firmware last night, and again this morning.
The router just seems "stuck". I will attach logs as well and screenshot.
To resolve the problem all I do is unplug and replug the Ethernet cable and the connection comes back up....
What else can I send you to help diagnose the issue?
Tue Oct 22 07:36:40 2024 kern.info kernel: [52821.376665] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 10Mbps/Half - flow control rx/tx
Tue Oct 22 07:36:40 2024 kern.info kernel: [52821.385212] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Tue Oct 22 07:36:40 2024 daemon.notice netifd: Network device 'eth0' link is up
Tue Oct 22 07:36:40 2024 daemon.notice netifd: Interface 'wan' has link connectivity
Tue Oct 22 07:36:40 2024 daemon.notice netifd: Interface 'wan' is setting up now
Tue Oct 22 07:36:40 2024 daemon.notice netifd: wan (28875): udhcpc: started, v1.33.2
Tue Oct 22 07:36:40 2024 daemon.notice netifd: wan (28875): udhcpc: sending discover
Tue Oct 22 07:36:41 2024 daemon.info avahi-daemon[6809]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::9683:c4ff:fe3a:a031.
Tue Oct 22 07:36:41 2024 daemon.info avahi-daemon[6809]: New relevant interface eth0.IPv6 for mDNS.
Tue Oct 22 07:36:41 2024 daemon.info avahi-daemon[6809]: Registering new address record for fe80::9683:c4ff:fe3a:a031 on eth0..
Tue Oct 22 07:36:43 2024 kern.info kernel: [52824.447900] mtk_soc_eth 15100000.ethernet eth0: Link is Down
Tue Oct 22 07:36:43 2024 daemon.notice netifd: Network device 'eth0' link is down
Tue Oct 22 07:36:43 2024 daemon.notice netifd: Interface 'wan' has link connectivity loss
Tue Oct 22 07:36:43 2024 daemon.notice netifd: wan (28875): udhcpc: sending discover
Tue Oct 22 07:36:43 2024 daemon.notice netifd: wan (28875): udhcpc: received SIGTERM
Tue Oct 22 07:36:43 2024 daemon.notice netifd: wan (28875): udhcpc: entering released state
Tue Oct 22 07:36:43 2024 daemon.notice netifd: wan (28875): Command failed: Permission denied
Tue Oct 22 07:36:44 2024 daemon.notice netifd: Interface 'wan' is now down
Tue Oct 22 07:36:44 2024 daemon.info avahi-daemon[6809]: Interface eth0.IPv6 no longer relevant for mDNS.
Tue Oct 22 07:36:44 2024 daemon.info avahi-daemon[6809]: Leaving mDNS multicast group on interface eth0.IPv6 with address fe80::9683:c4ff:fe3a:a031.
Tue Oct 22 07:36:44 2024 daemon.info avahi-daemon[6809]: Withdrawing address record for fe80::9683:c4ff:fe3a:a031 on eth0.
Tue Oct 22 07:36:44 2024 daemon.notice netifd: Interface 'wan' is disabled
Tue Oct 22 07:36:44 2024 daemon.notice netifd: Interface 'wan' is enabled
Tue Oct 22 07:36:44 2024 kern.info kernel: [52824.553488] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
Tue Oct 22 07:36:44 2024 user.notice firewall: Reloading firewall due to ifdown of wan ()
Tue Oct 22 07:36:44 2024 daemon.err gl-cloud[9207]: (gl-cloud:539) disconnected false 4 The client is not currently connected.
Tue Oct 22 07:36:44 2024 user.notice kmwan: config json str={ "op": 3, "data": { "cells": [ "wan" ] } }
Tue Oct 22 07:36:47 2024 kern.info kernel: [52827.615099] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
Tue Oct 22 07:36:47 2024 kern.info kernel: [52827.623559] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Tue Oct 22 07:36:47 2024 daemon.notice netifd: Network device 'eth0' link is up
Tue Oct 22 07:36:47 2024 daemon.notice netifd: Interface 'wan' has link connectivity
Tue Oct 22 07:36:47 2024 daemon.notice netifd: Interface 'wan' is setting up now
Tue Oct 22 07:36:47 2024 daemon.notice netifd: wan (29243): udhcpc: started, v1.33.2
Tue Oct 22 07:36:47 2024 daemon.notice netifd: wan (29243): udhcpc: sending discover
Tue Oct 22 07:36:48 2024 daemon.info avahi-daemon[6809]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::9683:c4ff:fe3a:a031.
Tue Oct 22 07:36:48 2024 daemon.info avahi-daemon[6809]: New relevant interface eth0.IPv6 for mDNS.
Tue Oct 22 07:36:48 2024 daemon.info avahi-daemon[6809]: Registering new address record for fe80::9683:c4ff:fe3a:a031 on eth0.
Tue Oct 22 07:36:50 2024 daemon.notice netifd: wan (29243): udhcpc: sending discover
Tue Oct 22 07:36:53 2024 daemon.notice netifd: wan (29243): udhcpc: sending discover
Tue Oct 22 07:36:56 2024 daemon.notice netifd: wan (29243): udhcpc: sending select for 206.214.239.194
Tue Oct 22 07:36:56 2024 daemon.notice netifd: wan (29243): udhcpc: lease of 206.214.239.194 obtained, lease time 122
Tue Oct 22 07:36:56 2024 daemon.info avahi-daemon[6809]: Joining mDNS multicast group on interface eth0.IPv4 with address 206.214.239.194.
Tue Oct 22 07:36:56 2024 daemon.info avahi-daemon[6809]: New relevant interface eth0.IPv4 for mDNS.
Tue Oct 22 07:36:56 2024 daemon.info avahi-daemon[6809]: Registering new address record for 206.214.239.194 on eth0.IPv4.
Tue Oct 22 07:36:56 2024 daemon.notice netifd: Interface 'wan' is now up
Tue Oct 22 07:36:56 2024 user.notice firewall: Reloading firewall due to ifup of wan (eth0)
Tue Oct 22 07:36:56 2024 user.notice kmwan: config json str={ "op": 2, "data": { "cells": [ { "interface": "wan", "netdev": "eth0", "track_mode": "force", "addr_type": 4, "tracks": [ { "type": "ping", "ip": "1.1.1.1" }, { "type": "ping", "ip": "8.8.8.8" }, { "type": "ping", "ip": "208.67.222.222" }, { "type": "ping", "ip": "208.67.220.220" } ] } ] } }
Tue Oct 22 07:36:56 2024 kern.debug kernel: [52837.281398] [add_dev_config 288]add node success. iface:wan, dev:eth0, ifindex:2
Tue Oct 22 07:37:57 2024 daemon.info gl-cloud[9207]: (gl-cloud:230) fetch server from: https://gslb-us.goodcloud.xyz/gslb/getbucket?deviceType=1&mac=9483c43aa031&sn=db1210b622388a87&ddns=rlaa031&timestamp=1729593477&sign=878eb47ba03795a566782c87354ce131
Tue Oct 22 07:37:57 2024 daemon.err gl-cloud[9207]: (gl-cloud:234) fetch server fail: resolve "gslb-us.goodcloud.xyz" fail: name error
Tue Oct 22 07:37:57 2024 daemon.err gl-cloud[9207]: (gl-cloud:495) reconnect mqtt in 160s...
Tue Oct 22 07:37:57 2024 daemon.notice netifd: wan (29243): udhcpc: sending renew to 206.214.239.195
Tue Oct 22 07:37:57 2024 daemon.notice netifd: wan (29243): udhcpc: lease of 206.214.239.194 obtained, lease time 122
Tue Oct 22 07:38:58 2024 daemon.notice netifd: wan (29243): udhcpc: sending renew to 206.214.239.195
Tue Oct 22 07:39:28 2024 daemon.notice netifd: wan (29243): udhcpc: sending renew to 0.0.0.0
Tue Oct 22 07:39:43 2024 daemon.notice netifd: wan (29243): udhcpc: sending renew to 0.0.0.0
Tue Oct 22 07:39:50 2024 daemon.notice netifd: wan (29243): udhcpc: sending renew to 0.0.0.0
Tue Oct 22 07:39:53 2024 daemon.notice netifd: wan (29243): udhcpc: sending renew to 0.0.0.0
Tue Oct 22 07:39:54 2024 daemon.notice netifd: wan (29243): udhcpc: sending renew to 0.0.0.0
Tue Oct 22 07:39:54 2024 daemon.notice netifd: wan (29243): udhcpc: lease lost, entering init state
Tue Oct 22 07:39:54 2024 daemon.notice netifd: Interface 'wan' has lost the connection
Tue Oct 22 07:39:54 2024 daemon.info avahi-daemon[6809]: Withdrawing address record for 206.214.239.194 on eth0.
Tue Oct 22 07:39:54 2024 daemon.info avahi-daemon[6809]: Leaving mDNS multicast group on interface eth0.IPv4 with address 206.214.239.194.
Tue Oct 22 07:39:54 2024 daemon.info avahi-daemon[6809]: Interface eth0.IPv4 no longer relevant for mDNS.
Tue Oct 22 07:39:55 2024 daemon.notice netifd: wan (29243): udhcpc: sending select for 100.105.221.10
Tue Oct 22 07:39:55 2024 daemon.notice netifd: wan (29243): udhcpc: lease of 100.105.221.10 obtained, lease time 300
Tue Oct 22 07:39:55 2024 user.notice firewall: Reloading firewall due to ifdown of wan ()
Tue Oct 22 07:39:55 2024 daemon.info avahi-daemon[6809]: Joining mDNS multicast group on interface eth0.IPv4 with address 100.105.221.10.
Tue Oct 22 07:39:55 2024 daemon.info avahi-daemon[6809]: New relevant interface eth0.IPv4 for mDNS.
Tue Oct 22 07:39:55 2024 daemon.info avahi-daemon[6809]: Registering new address record for 100.105.221.10 on eth0.IPv4.
Tue Oct 22 07:39:55 2024 daemon.notice netifd: Interface 'wan' is now up
Tue Oct 22 07:39:55 2024 user.notice kmwan: config json str={ "op": 3, "data": { "cells": [ "wan" ] } }
Tue Oct 22 07:39:55 2024 kern.debug kernel: [53015.852399] kmwan: Delete node:wan
Tue Oct 22 07:39:55 2024 user.notice firewall: Reloading firewall due to ifup of wan (eth0)
Tue Oct 22 07:39:55 2024 user.notice kmwan: config json str={ "op": 2, "data": { "cells": [ { "interface": "wan", "netdev": "eth0", "track_mode": "force", "addr_type": 4, "tracks": [ { "type": "ping", "ip": "1.1.1.1" }, { "type": "ping", "ip": "8.8.8.8" }, { "type": "ping", "ip": "208.67.222.222" }, { "type": "ping", "ip": "208.67.220.220" } ] } ] } }
Tue Oct 22 07:39:55 2024 kern.debug kernel: [53016.238561] [add_dev_config 288]add node success. iface:wan, dev:eth0, ifindex:2
Tue Oct 22 07:40:37 2024 daemon.info gl-cloud[9207]: (gl-cloud:230) fetch server from: https://gslb-us.goodcloud.xyz/gslb/getbucket?deviceType=1&mac=9483c43aa031&sn=db1210b622388a87&ddns=rlaa031&timestamp=1729593637&sign=3fe3da91209453710dc850b33785587e
Tue Oct 22 07:40:39 2024 daemon.info gl-cloud[9207]: (gl-cloud:522) connected: true 0 connection accepted
Tue Oct 22 07:40:39 2024 daemon.info gl-cloud[9207]: (gl-cloud:529) connected: 0 connection accepted
Tue Oct 22 07:42:25 2024 daemon.notice netifd: wan (29243): udhcpc: sending renew to 100.64.0.1
Tue Oct 22 07:42:25 2024 daemon.notice netifd: wan (29243): udhcpc: lease of 100.105.221.10 obtained, lease time 300
Tue Oct 22 07:44:55 2024 daemon.notice netifd: wan (29243): udhcpc: sending renew to 100.64.0.1
Tue Oct 22 07:44:55 2024 daemon.notice netifd: wan (29243): udhcpc: lease of 100.105.221.10 obtained, lease time 300
Tue Oct 22 07:47:25 2024 daemon.notice netifd: wan (29243): udhcpc: sending renew to 100.64.0.1
Tue Oct 22 07:47:25 2024 daemon.notice netifd: wan (29243): udhcpc: lease of 100.105.221.10 obtained, lease time 300
Tue Oct 22 07:49:55 2024 daemon.notice netifd: wan (29243): udhcpc: sending renew to 100.64.0.1
Tue Oct 22 07:49:55 2024 daemon.notice netifd: wan (29243): udhcpc: lease of 100.105.221.10 obtained, lease time 300
Tue Oct 22 07:52:25 2024 daemon.notice netifd: wan (29243): udhcpc: sending renew to 100.64.0.1
Tue Oct 22 07:52:25 2024 daemon.notice netifd: wan (29243): udhcpc: lease of 100.105.221.10 obtained, lease time 300
Tue Oct 22 07:54:55 2024 daemon.notice netifd: wan (29243): udhcpc: sending renew to 100.64.0.1
Tue Oct 22 07:54:55 2024 daemon.notice netifd: wan (29243): udhcpc: lease of 100.105.221.10 obtained, lease time 300
Tue Oct 22 07:57:25 2024 daemon.notice netifd: wan (29243): udhcpc: sending renew to 100.64.0.1
Tue Oct 22 07:57:25 2024 daemon.notice netifd: wan (29243): udhcpc: lease of 100.105.221.10 obtained, lease time 300
Tue Oct 22 07:59:55 2024 daemon.notice netifd: wan (29243): udhcpc: sending renew to 100.64.0.1
Tue Oct 22 07:59:55 2024 daemon.notice netifd: wan (29243): udhcpc: lease of 100.105.221.10 obtained, lease time 300
Tue Oct 22 08:00:53 2024 kern.info kernel: [54274.106157] mtk_soc_eth 15100000.ethernet eth0: Link is Down
Tue Oct 22 08:00:54 2024 daemon.notice netifd: Network device 'eth0' link is down
Tue Oct 22 08:00:54 2024 daemon.notice netifd: Interface 'wan' has link connectivity loss
Tue Oct 22 08:00:54 2024 daemon.notice netifd: wan (29243): udhcpc: received SIGTERM
Tue Oct 22 08:00:54 2024 daemon.notice netifd: wan (29243): udhcpc: unicasting a release of 100.105.221.10 to 100.64.0.1
Tue Oct 22 08:00:54 2024 daemon.notice netifd: wan (29243): udhcpc: sending release
Tue Oct 22 08:00:54 2024 daemon.notice netifd: wan (29243): udhcpc: entering released state
Tue Oct 22 08:00:54 2024 daemon.notice netifd: wan (29243): Command failed: Permission denied
Tue Oct 22 08:00:54 2024 daemon.notice netifd: Interface 'wan' is now down
Tue Oct 22 08:00:54 2024 daemon.info avahi-daemon[6809]: Withdrawing address record for 100.105.221.10 on eth0.
Tue Oct 22 08:00:54 2024 daemon.info avahi-daemon[6809]: Leaving mDNS multicast group on interface eth0.IPv4 with address 100.105.221.10.
Tue Oct 22 08:00:54 2024 daemon.info avahi-daemon[6809]: Interface eth0.IPv4 no longer relevant for mDNS.
Tue Oct 22 08:00:54 2024 daemon.info avahi-daemon[6809]: Interface eth0.IPv6 no longer relevant for mDNS.
Tue Oct 22 08:00:54 2024 daemon.info avahi-daemon[6809]: Leaving mDNS multicast group on interface eth0.IPv6 with address fe80::9683:c4ff:fe3a:a031.
Tue Oct 22 08:00:54 2024 daemon.info avahi-daemon[6809]: Withdrawing address record for fe80::9683:c4ff:fe3a:a031 on eth0.
Tue Oct 22 08:00:54 2024 daemon.notice netifd: Interface 'wan' is disabled
Tue Oct 22 08:00:54 2024 kern.info kernel: [54274.174769] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
Tue Oct 22 08:00:54 2024 daemon.notice netifd: Interface 'wan' is enabled
Tue Oct 22 08:00:54 2024 user.notice firewall: Reloading firewall due to ifdown of wan ()
Tue Oct 22 08:00:54 2024 user.notice kmwan: config json str={ "op": 3, "data": { "cells": [ "wan" ] } }
Tue Oct 22 08:00:54 2024 kern.debug kernel: [54274.515719] kmwan: Delete node:wan
Tue Oct 22 08:01:34 2024 kern.info kernel: [54314.090649] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
Tue Oct 22 08:01:34 2024 kern.info kernel: [54314.099109] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Tue Oct 22 08:01:34 2024 daemon.notice netifd: Network device 'eth0' link is up
Tue Oct 22 08:01:34 2024 daemon.notice netifd: Interface 'wan' has link connectivity
Tue Oct 22 08:01:34 2024 daemon.notice netifd: Interface 'wan' is setting up now
Tue Oct 22 08:01:34 2024 daemon.notice netifd: wan (4348): udhcpc: started, v1.33.2
Tue Oct 22 08:01:34 2024 daemon.notice netifd: wan (4348): udhcpc: sending discover
Tue Oct 22 08:01:34 2024 daemon.notice netifd: wan (4348): udhcpc: sending select for 100.105.221.10
Tue Oct 22 08:01:34 2024 daemon.notice netifd: wan (4348): udhcpc: lease of 100.105.221.10 obtained, lease time 300
Tue Oct 22 08:01:34 2024 daemon.info avahi-daemon[6809]: Joining mDNS multicast group on interface eth0.IPv4 with address 100.105.221.10.
Tue Oct 22 08:01:34 2024 daemon.info avahi-daemon[6809]: New relevant interface eth0.IPv4 for mDNS.
Tue Oct 22 08:01:34 2024 daemon.info avahi-daemon[6809]: Registering new address record for 100.105.221.10 on eth0.IPv4.
Tue Oct 22 08:01:34 2024 daemon.notice netifd: Interface 'wan' is now up
Tue Oct 22 08:01:34 2024 user.notice firewall: Reloading firewall due to ifup of wan (eth0)
Tue Oct 22 08:01:34 2024 user.notice kmwan: config json str={ "op": 2, "data": { "cells": [ { "interface": "wan", "netdev": "eth0", "track_mode": "force", "addr_type": 4, "tracks": [ { "type": "ping", "ip": "1.1.1.1" }, { "type": "ping", "ip": "8.8.8.8" }, { "type": "ping", "ip": "208.67.222.222" }, { "type": "ping", "ip": "208.67.220.220" } ] } ] } }
Tue Oct 22 08:01:34 2024 kern.debug kernel: [54314.666220] [add_dev_config 288]add node success. iface:wan, dev:eth0, ifindex:2
Tue Oct 22 08:01:35 2024 kern.info kernel: [54315.114248] mtk_soc_eth 15100000.ethernet eth0: Link is Down
Tue Oct 22 08:01:35 2024 daemon.notice netifd: Network device 'eth0' link is down
Tue Oct 22 08:01:35 2024 daemon.notice netifd: Interface 'wan' has link connectivity loss
Tue Oct 22 08:01:35 2024 daemon.notice netifd: wan (4348): udhcpc: received SIGTERM
Tue Oct 22 08:01:35 2024 daemon.notice netifd: wan (4348): udhcpc: unicasting a release of 100.105.221.10 to 100.64.0.1
Tue Oct 22 08:01:35 2024 daemon.notice netifd: wan (4348): udhcpc: sending release
Tue Oct 22 08:01:35 2024 daemon.notice netifd: wan (4348): udhcpc: entering released state
Tue Oct 22 08:01:35 2024 daemon.notice netifd: wan (4348): Command failed: Permission denied
Tue Oct 22 08:01:35 2024 daemon.notice netifd: Interface 'wan' is now down
Tue Oct 22 08:01:35 2024 daemon.info avahi-daemon[6809]: Withdrawing address record for 100.105.221.10 on eth0.
Tue Oct 22 08:01:35 2024 daemon.info avahi-daemon[6809]: Leaving mDNS multicast group on interface eth0.IPv4 with address 100.105.221.10.
Tue Oct 22 08:01:35 2024 daemon.info avahi-daemon[6809]: Interface eth0.IPv4 no longer relevant for mDNS.
Tue Oct 22 08:01:35 2024 daemon.notice netifd: Interface 'wan' is disabled
Tue Oct 22 08:01:35 2024 kern.info kernel: [54315.177247] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
Tue Oct 22 08:01:35 2024 daemon.notice netifd: Interface 'wan' is enabled
Tue Oct 22 08:01:35 2024 user.notice firewall: Reloading firewall due to ifdown of wan ()
Tue Oct 22 08:01:35 2024 user.notice kmwan: config json str={ "op": 3, "data": { "cells": [ "wan" ] } }
Tue Oct 22 08:01:35 2024 kern.debug kernel: [54315.522396] kmwan: Delete node:wan
Tue Oct 22 08:01:39 2024 kern.info kernel: [54319.272655] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
Tue Oct 22 08:01:39 2024 kern.info kernel: [54319.281115] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Tue Oct 22 08:01:39 2024 daemon.notice netifd: Network device 'eth0' link is up
Tue Oct 22 08:01:39 2024 daemon.notice netifd: Interface 'wan' has link connectivity
Tue Oct 22 08:01:39 2024 daemon.notice netifd: Interface 'wan' is setting up now
Tue Oct 22 08:01:39 2024 daemon.notice netifd: wan (4935): udhcpc: started, v1.33.2
Tue Oct 22 08:01:39 2024 daemon.notice netifd: wan (4935): udhcpc: sending discover
Tue Oct 22 08:01:39 2024 daemon.notice netifd: wan (4935): udhcpc: sending select for 100.105.221.10
Tue Oct 22 08:01:39 2024 daemon.notice netifd: wan (4935): udhcpc: lease of 100.105.221.10 obtained, lease time 300
Tue Oct 22 08:01:39 2024 daemon.info avahi-daemon[6809]: Joining mDNS multicast group on interface eth0.IPv4 with address 100.105.221.10.
Tue Oct 22 08:01:39 2024 daemon.info avahi-daemon[6809]: New relevant interface eth0.IPv4 for mDNS.
Tue Oct 22 08:01:39 2024 daemon.info avahi-daemon[6809]: Registering new address record for 100.105.221.10 on eth0.IPv4.
Tue Oct 22 08:01:39 2024 daemon.notice netifd: Interface 'wan' is now up
Tue Oct 22 08:01:39 2024 user.notice firewall: Reloading firewall due to ifup of wan (eth0)
Tue Oct 22 08:01:39 2024 user.notice kmwan: config json str={ "op": 2, "data": { "cells": [ { "interface": "wan", "netdev": "eth0", "track_mode": "force", "addr_type": 4, "tracks": [ { "type": "ping", "ip": "1.1.1.1" }, { "type": "ping", "ip": "8.8.8.8" }, { "type": "ping", "ip": "208.67.222.222" }, { "type": "ping", "ip": "208.67.220.220" } ] } ] } }
Tue Oct 22 08:01:39 2024 kern.debug kernel: [54319.842327] [add_dev_config 288]add node success. iface:wan, dev:eth0, ifindex:2
Tue Oct 22 08:01:40 2024 daemon.info avahi-daemon[6809]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::9683:c4ff:fe3a:a031.
Tue Oct 22 08:01:40 2024 daemon.info avahi-daemon[6809]: New relevant interface eth0.IPv6 for mDNS.
Tue Oct 22 08:01:40 2024 daemon.info avahi-daemon[6809]: Registering new address record for fe80::9683:c4ff:fe3a:a031 on eth0..
Tue Oct 22 08:02:57 2024 kern.info kernel: [54397.066997] mtk_soc_eth 15100000.ethernet eth0: Link is Down
Tue Oct 22 08:02:57 2024 daemon.notice netifd: Network device 'eth0' link is down
Tue Oct 22 08:02:57 2024 daemon.notice netifd: Interface 'wan' has link connectivity loss
Tue Oct 22 08:02:57 2024 daemon.notice netifd: wan (4935): udhcpc: received SIGTERM
Tue Oct 22 08:02:57 2024 daemon.notice netifd: wan (4935): udhcpc: unicasting a release of 100.105.221.10 to 100.64.0.1
Tue Oct 22 08:02:57 2024 daemon.notice netifd: wan (4935): udhcpc: sending release
Tue Oct 22 08:02:57 2024 daemon.notice netifd: wan (4935): udhcpc: entering released state
Tue Oct 22 08:02:57 2024 daemon.notice netifd: wan (4935): Command failed: Permission denied
Tue Oct 22 08:02:57 2024 daemon.notice netifd: Interface 'wan' is now down
Tue Oct 22 08:02:57 2024 daemon.info avahi-daemon[6809]: Withdrawing address record for 100.105.221.10 on eth0.
Tue Oct 22 08:02:57 2024 daemon.info avahi-daemon[6809]: Leaving mDNS multicast group on interface eth0.IPv4 with address 100.105.221.10.
Tue Oct 22 08:02:57 2024 daemon.info avahi-daemon[6809]: Interface eth0.IPv4 no longer relevant for mDNS.
Tue Oct 22 08:02:57 2024 daemon.info avahi-daemon[6809]: Interface eth0.IPv6 no longer relevant for mDNS.
Tue Oct 22 08:02:57 2024 daemon.info avahi-daemon[6809]: Leaving mDNS multicast group on interface eth0.IPv6 with address fe80::9683:c4ff:fe3a:a031.
Tue Oct 22 08:02:57 2024 daemon.info avahi-daemon[6809]: Withdrawing address record for fe80::9683:c4ff:fe3a:a031 on eth0.
Tue Oct 22 08:02:57 2024 daemon.notice netifd: Interface 'wan' is disabled
Tue Oct 22 08:02:57 2024 kern.info kernel: [54397.132924] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
Tue Oct 22 08:02:57 2024 daemon.notice netifd: Interface 'wan' is enabled
Tue Oct 22 08:02:57 2024 user.notice firewall: Reloading firewall due to ifdown of wan ()
Tue Oct 22 08:02:57 2024 user.notice kmwan: config json str={ "op": 3, "data": { "cells": [ "wan" ] } }
Tue Oct 22 08:02:57 2024 kern.debug kernel: [54397.477702] kmwan: Delete node:wan
Tue Oct 22 08:03:32 2024 kern.info kernel: [54432.957540] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
Tue Oct 22 08:03:32 2024 kern.info kernel: [54432.966004] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Tue Oct 22 08:03:32 2024 daemon.notice netifd: Network device 'eth0' link is up
Tue Oct 22 08:03:32 2024 daemon.notice netifd: Interface 'wan' has link connectivity
Tue Oct 22 08:03:32 2024 daemon.notice netifd: Interface 'wan' is setting up now
Tue Oct 22 08:03:32 2024 daemon.notice netifd: wan (6096): udhcpc: started, v1.33.2
Tue Oct 22 08:03:32 2024 daemon.notice netifd: wan (6096): udhcpc: sending discover
Tue Oct 22 08:03:34 2024 daemon.info avahi-daemon[6809]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::9683:c4ff:fe3a:a031.
Tue Oct 22 08:03:34 2024 daemon.info avahi-daemon[6809]: New relevant interface eth0.IPv6 for mDNS.
Tue Oct 22 08:03:34 2024 daemon.info avahi-daemon[6809]: Registering new address record for fe80::9683:c4ff:fe3a:a031 on eth0.
Tue Oct 22 08:03:36 2024 daemon.notice netifd: wan (6096): udhcpc: sending discover
Tue Oct 22 08:03:39 2024 daemon.notice netifd: wan (6096): udhcpc: sending discover
Tue Oct 22 08:04:07 2024 kern.info kernel: [54467.760596] mtk_soc_eth 15100000.ethernet eth0: Link is Down
Tue Oct 22 08:04:07 2024 daemon.notice netifd: Network device 'eth0' link is down
Tue Oct 22 08:04:07 2024 daemon.notice netifd: Interface 'wan' has link connectivity loss
Tue Oct 22 08:04:07 2024 daemon.notice netifd: wan (6096): udhcpc: received SIGTERM
Tue Oct 22 08:04:07 2024 daemon.notice netifd: wan (6096): udhcpc: entering released state
Tue Oct 22 08:04:07 2024 daemon.notice netifd: wan (6096): Command failed: Permission denied
Tue Oct 22 08:04:07 2024 daemon.notice netifd: Interface 'wan' is now down
Tue Oct 22 08:04:07 2024 daemon.info avahi-daemon[6809]: Interface eth0.IPv6 no longer relevant for mDNS.
Tue Oct 22 08:04:07 2024 daemon.info avahi-daemon[6809]: Leaving mDNS multicast group on interface eth0.IPv6 with address fe80::9683:c4ff:fe3a:a031.
Tue Oct 22 08:04:07 2024 daemon.info avahi-daemon[6809]: Withdrawing address record for fe80::9683:c4ff:fe3a:a031 on eth0.
Tue Oct 22 08:04:07 2024 daemon.notice netifd: Interface 'wan' is disabled
Tue Oct 22 08:04:07 2024 daemon.notice netifd: Interface 'wan' is enabled
Tue Oct 22 08:04:07 2024 kern.info kernel: [54467.825576] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
Tue Oct 22 08:04:07 2024 user.notice firewall: Reloading firewall due to ifdown of wan ()
Tue Oct 22 08:04:08 2024 user.notice kmwan: config json str={ "op": 3, "data": { "cells": [ "wan" ] } }
Tue Oct 22 08:04:25 2024 kern.info kernel: [54485.226159] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
Tue Oct 22 08:04:25 2024 kern.info kernel: [54485.234619] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Tue Oct 22 08:04:25 2024 daemon.notice netifd: Network device 'eth0' link is up
Tue Oct 22 08:04:25 2024 daemon.notice netifd: Interface 'wan' has link connectivity
Tue Oct 22 08:04:25 2024 daemon.notice netifd: Interface 'wan' is setting up now
Tue Oct 22 08:04:25 2024 daemon.notice netifd: wan (6693): udhcpc: started, v1.33.2
Tue Oct 22 08:04:25 2024 daemon.notice netifd: wan (6693): udhcpc: sending discover
Tue Oct 22 08:04:26 2024 kern.info kernel: [54486.249781] mtk_soc_eth 15100000.ethernet eth0: Link is Down
Tue Oct 22 08:04:26 2024 daemon.notice netifd: Network device 'eth0' link is down
Tue Oct 22 08:04:26 2024 daemon.notice netifd: Interface 'wan' has link connectivity loss
Tue Oct 22 08:04:26 2024 daemon.notice netifd: wan (6693): udhcpc: received SIGTERM
Tue Oct 22 08:04:26 2024 daemon.notice netifd: wan (6693): udhcpc: entering released state
Tue Oct 22 08:04:26 2024 daemon.notice netifd: wan (6693): Command failed: Permission denied
Tue Oct 22 08:04:26 2024 daemon.notice netifd: Interface 'wan' is now down
Tue Oct 22 08:04:26 2024 daemon.notice netifd: Interface 'wan' is disabled
Tue Oct 22 08:04:26 2024 daemon.notice netifd: Interface 'wan' is enabled
Tue Oct 22 08:04:26 2024 kern.info kernel: [54486.326636] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
Tue Oct 22 08:04:26 2024 user.notice firewall: Reloading firewall due to ifdown of wan ()
Tue Oct 22 08:04:26 2024 user.notice kmwan: config json str={ "op": 3, "data": { "cells": [ "wan" ] } }
Tue Oct 22 08:04:45 2024 daemon.err gl-cloud[9207]: (gl-cloud:539) disconnected false 19 Unknown error.
Tue Oct 22 08:04:45 2024 daemon.err gl-cloud[9207]: (gl-cloud:495) reconnect mqtt in 5s...
Tue Oct 22 08:04:50 2024 daemon.info gl-cloud[9207]: (gl-cloud:230) fetch server from: https://gslb-us.goodcloud.xyz/gslb/getbucket?deviceType=1&mac=9483c43aa031&sn=db1210b622388a87&ddns=rlaa031&timestamp=1729595090&sign=ce672b55092ca2e8ea4a53fb110470cb
Tue Oct 22 08:04:50 2024 daemon.err gl-cloud[9207]: (gl-cloud:234) fetch server fail: resolve "gslb-us.goodcloud.xyz" fail: not found valid nameservers
Tue Oct 22 08:04:50 2024 daemon.err gl-cloud[9207]: (gl-cloud:495) reconnect mqtt in 10s...
Tue Oct 22 08:05:00 2024 daemon.info gl-cloud[9207]: (gl-cloud:230) fetch server from: https://gslb-us.goodcloud.xyz/gslb/getbucket?deviceType=1&mac=9483c43aa031&sn=db1210b622388a87&ddns=rlaa031&timestamp=1729595100&sign=4632a749949ff572180344aa3358c624
Tue Oct 22 08:05:00 2024 daemon.err gl-cloud[9207]: (gl-cloud:234) fetch server fail: resolve "gslb-us.goodcloud.xyz" fail: not found valid nameservers
Tue Oct 22 08:05:00 2024 daemon.err gl-cloud[9207]: (gl-cloud:495) reconnect mqtt in 20s...
Tue Oct 22 08:05:08 2024 kern.info kernel: [54528.282399] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
Tue Oct 22 08:05:08 2024 kern.info kernel: [54528.290859] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Tue Oct 22 08:05:08 2024 daemon.notice netifd: Network device 'eth0' link is up
Tue Oct 22 08:05:08 2024 daemon.notice netifd: Interface 'wan' has link connectivity
Tue Oct 22 08:05:08 2024 daemon.notice netifd: Interface 'wan' is setting up now
Tue Oct 22 08:05:08 2024 daemon.notice netifd: wan (7264): udhcpc: started, v1.33.2
Tue Oct 22 08:05:08 2024 daemon.notice netifd: wan (7264): udhcpc: sending discover
Tue Oct 22 08:05:09 2024 kern.info kernel: [54529.306007] mtk_soc_eth 15100000.ethernet eth0: Link is Down
Tue Oct 22 08:05:09 2024 daemon.notice netifd: Network device 'eth0' link is down
Tue Oct 22 08:05:09 2024 daemon.notice netifd: Interface 'wan' has link connectivity loss
Tue Oct 22 08:05:09 2024 daemon.notice netifd: wan (7264): udhcpc: received SIGTERM
Tue Oct 22 08:05:09 2024 daemon.notice netifd: wan (7264): udhcpc: entering released state
Tue Oct 22 08:05:09 2024 daemon.notice netifd: wan (7264): Command failed: Permission denied
Tue Oct 22 08:05:09 2024 daemon.notice netifd: Interface 'wan' is now down
Tue Oct 22 08:05:09 2024 daemon.notice netifd: Interface 'wan' is disabled
Tue Oct 22 08:05:09 2024 daemon.notice netifd: Interface 'wan' is enabled
Tue Oct 22 08:05:09 2024 kern.info kernel: [54529.371207] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
Tue Oct 22 08:05:09 2024 user.notice firewall: Reloading firewall due to ifdown of wan ()
Tue Oct 22 08:05:09 2024 daemon.err gl-cloud[9207]: (gl-cloud:539) disconnected	false	4	The client is not currently connected.
Tue Oct 22 08:05:09 2024 user.notice kmwan: config json str={ "op": 3, "data": { "cells": [ "wan" ] } }
Tue Oct 22 08:05:15 2024 kern.info kernel: [54535.511750] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
Tue Oct 22 08:05:15 2024 kern.info kernel: [54535.520207] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Tue Oct 22 08:05:15 2024 daemon.notice netifd: Network device 'eth0' link is up
Tue Oct 22 08:05:15 2024 daemon.notice netifd: Interface 'wan' has link connectivity
Tue Oct 22 08:05:15 2024 daemon.notice netifd: Interface 'wan' is setting up now
Tue Oct 22 08:05:15 2024 daemon.notice netifd: wan (7650): udhcpc: started, v1.33.2
Tue Oct 22 08:05:15 2024 daemon.notice netifd: wan (7650): udhcpc: sending discover
Tue Oct 22 08:05:16 2024 daemon.info avahi-daemon[6809]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::9683:c4ff:fe3a:a031.
Tue Oct 22 08:05:16 2024 daemon.info avahi-daemon[6809]: New relevant interface eth0.IPv6 for mDNS.
Tue Oct 22 08:05:16 2024 daemon.info avahi-daemon[6809]: Registering new address record for fe80::9683:c4ff:fe3a:a031 on eth0.*.
Tue Oct 22 08:05:18 2024 kern.info kernel: [54538.582642] mtk_soc_eth 15100000.ethernet eth0: Link is Down
Tue Oct 22 08:05:18 2024 daemon.notice netifd: Network device 'eth0' link is down
Tue Oct 22 08:05:18 2024 daemon.notice netifd: Interface 'wan' has link connectivity loss
Tue Oct 22 08:05:18 2024 daemon.notice netifd: wan (7650): udhcpc: sending discover
Tue Oct 22 08:05:18 2024 daemon.notice netifd: wan (7650): udhcpc: received SIGTERM
Tue Oct 22 08:05:18 2024 daemon.notice netifd: wan (7650): udhcpc: entering released state
Tue Oct 22 08:05:18 2024 daemon.notice netifd: wan (7650): Command failed: Permission denied
Tue Oct 22 08:05:18 2024 daemon.notice netifd: Interface 'wan' is now down
Tue Oct 22 08:05:18 2024 daemon.info avahi-daemon[6809]: Interface eth0.IPv6 no longer relevant for mDNS.
Tue Oct 22 08:05:18 2024 daemon.info avahi-daemon[6809]: Leaving mDNS multicast group on interface eth0.IPv6 with address fe80::9683:c4ff:fe3a:a031.
Tue Oct 22 08:05:18 2024 daemon.info avahi-daemon[6809]: Withdrawing address record for fe80::9683:c4ff:fe3a:a031 on eth0.
Tue Oct 22 08:05:18 2024 daemon.notice netifd: Interface 'wan' is disabled
Tue Oct 22 08:05:18 2024 kern.info kernel: [54538.679857] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
Tue Oct 22 08:05:18 2024 daemon.notice netifd: Interface 'wan' is enabled
Tue Oct 22 08:05:18 2024 user.notice firewall: Reloading firewall due to ifdown of wan ()
Tue Oct 22 08:05:19 2024 user.notice kmwan: config json str={ "op": 3, "data": { "cells": [ "wan" ] } }
Tue Oct 22 08:05:20 2024 daemon.info gl-cloud[9207]: (gl-cloud:230) fetch server from:	https://gslb-us.goodcloud.xyz/gslb/getbucket?deviceType=1&mac=xxxxxxxxxx&sn=xxxxxxxxxx&ddns=xxxxxxxxxx&timestamp=1729595120&sign=13841290a06ef67ca6feb3dd467cca80
Tue Oct 22 08:05:20 2024 daemon.err gl-cloud[9207]: (gl-cloud:234) fetch server fail: resolve "gslb-us.goodcloud.xyz" fail: not found valid nameservers
Tue Oct 22 08:05:20 2024 daemon.err gl-cloud[9207]: (gl-cloud:495) reconnect mqtt in 40s...
Tue Oct 22 08:05:49 2024 kern.info kernel: [54569.387493] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
Tue Oct 22 08:05:49 2024 kern.info kernel: [54569.395951] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Tue Oct 22 08:05:49 2024 daemon.notice netifd: Network device 'eth0' link is up
Tue Oct 22 08:05:49 2024 daemon.notice netifd: Interface 'wan' has link connectivity
Tue Oct 22 08:05:49 2024 daemon.notice netifd: Interface 'wan' is setting up now
Tue Oct 22 08:05:49 2024 daemon.notice netifd: wan (8162): udhcpc: started, v1.33.2
Tue Oct 22 08:05:49 2024 daemon.notice netifd: wan (8162): udhcpc: sending discover
Tue Oct 22 08:05:51 2024 daemon.info avahi-daemon[6809]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::9683:c4ff:fe3a:a031.
Tue Oct 22 08:05:51 2024 daemon.info avahi-daemon[6809]: New relevant interface eth0.IPv6 for mDNS.
Tue Oct 22 08:05:51 2024 daemon.info avahi-daemon[6809]: Registering new address record for fe80::9683:c4ff:fe3a:a031 on eth0.*.
Tue Oct 22 08:05:52 2024 kern.info kernel: [54572.458382] mtk_soc_eth 15100000.ethernet eth0: Link is Down
Tue Oct 22 08:05:52 2024 daemon.notice netifd: Network device 'eth0' link is down
Tue Oct 22 08:05:52 2024 daemon.notice netifd: Interface 'wan' has link connectivity loss
Tue Oct 22 08:05:52 2024 daemon.notice netifd: wan (8162): udhcpc: sending discover
Tue Oct 22 08:05:52 2024 daemon.notice netifd: wan (8162): udhcpc: received SIGTERM
Tue Oct 22 08:05:52 2024 daemon.notice netifd: wan (8162): udhcpc: entering released state
Tue Oct 22 08:05:52 2024 daemon.notice netifd: wan (8162): Command failed: Permission denied
Tue Oct 22 08:05:52 2024 daemon.notice netifd: Interface 'wan' is now down
Tue Oct 22 08:05:52 2024 daemon.info avahi-daemon[6809]: Interface eth0.IPv6 no longer relevant for mDNS.
Tue Oct 22 08:05:52 2024 daemon.info avahi-daemon[6809]: Leaving mDNS multicast group on interface eth0.IPv6 with address fe80::9683:c4ff:fe3a:a031.
Tue Oct 22 08:05:52 2024 daemon.info avahi-daemon[6809]: Withdrawing address record for fe80::9683:c4ff:fe3a:a031 on eth0.
Tue Oct 22 08:05:52 2024 daemon.notice netifd: Interface 'wan' is disabled
Tue Oct 22 08:05:52 2024 kern.info kernel: [54572.564281] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
Tue Oct 22 08:05:52 2024 daemon.notice netifd: Interface 'wan' is enabled
Tue Oct 22 08:05:52 2024 user.notice firewall: Reloading firewall due to ifdown of wan ()
Tue Oct 22 08:05:52 2024 user.notice kmwan: config json str={ "op": 3, "data": { "cells": [ "wan" ] } }
Tue Oct 22 08:06:00 2024 daemon.info gl-cloud[9207]: (gl-cloud:230) fetch server from:	https://gslb-us.goodcloud.xyz/gslb/getbucket?deviceType=1&mac=xxxxxxxxxx&sn=xxxxxxxxxx&ddns=xxxxxxxxxx&timestamp=1729595160&sign=8c6ee8f378d9e3d1889faa6ad8933835
Tue Oct 22 08:06:00 2024 daemon.err gl-cloud[9207]: (gl-cloud:234) fetch server fail: resolve "gslb-us.goodcloud.xyz" fail: not found valid nameservers
Tue Oct 22 08:06:00 2024 daemon.err gl-cloud[9207]: (gl-cloud:495) reconnect mqtt in 80s...
Tue Oct 22 08:06:09 2024 kern.info kernel: [54589.956087] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
Tue Oct 22 08:06:09 2024 kern.info kernel: [54589.964549] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Tue Oct 22 08:06:09 2024 daemon.notice netifd: Network device 'eth0' link is up
Tue Oct 22 08:06:09 2024 daemon.notice netifd: Interface 'wan' has link connectivity
Tue Oct 22 08:06:09 2024 daemon.notice netifd: Interface 'wan' is setting up now
Tue Oct 22 08:06:10 2024 daemon.notice netifd: wan (8632): udhcpc: started, v1.33.2
Tue Oct 22 08:06:10 2024 daemon.notice netifd: wan (8632): udhcpc: sending discover
Tue Oct 22 08:06:10 2024 kern.info kernel: [54590.979734] mtk_soc_eth 15100000.ethernet eth0: Link is Down
Tue Oct 22 08:06:10 2024 daemon.notice netifd: Network device 'eth0' link is down
Tue Oct 22 08:06:10 2024 daemon.notice netifd: Interface 'wan' has link connectivity loss
Tue Oct 22 08:06:11 2024 daemon.notice netifd: wan (8632): udhcpc: received SIGTERM
Tue Oct 22 08:06:11 2024 daemon.notice netifd: wan (8632): udhcpc: entering released state
Tue Oct 22 08:06:11 2024 daemon.notice netifd: wan (8632): Command failed: Permission denied
Tue Oct 22 08:06:11 2024 daemon.notice netifd: Interface 'wan' is now down
Tue Oct 22 08:06:11 2024 daemon.notice netifd: Interface 'wan' is disabled
Tue Oct 22 08:06:11 2024 daemon.notice netifd: Interface 'wan' is enabled
Tue Oct 22 08:06:11 2024 kern.info kernel: [54591.057102] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
Tue Oct 22 08:06:11 2024 user.notice firewall: Reloading firewall due to ifdown of wan ()
Tue Oct 22 08:06:11 2024 user.notice kmwan: config json str={ "op": 3, "data": { "cells": [ "wan" ] } }
Tue Oct 22 08:06:36 2024 kern.info kernel: [54616.634539] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
Tue Oct 22 08:06:36 2024 kern.info kernel: [54616.643002] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Tue Oct 22 08:06:36 2024 daemon.notice netifd: Network device 'eth0' link is up
Tue Oct 22 08:06:36 2024 daemon.notice netifd: Interface 'wan' has link connectivity
Tue Oct 22 08:06:36 2024 daemon.notice netifd: Interface 'wan' is setting up now
Tue Oct 22 08:06:36 2024 daemon.notice netifd: wan (9133): udhcpc: started, v1.33.2
Tue Oct 22 08:06:36 2024 daemon.notice netifd: wan (9133): udhcpc: sending discover
Tue Oct 22 08:06:37 2024 kern.info kernel: [54617.658161] mtk_soc_eth 15100000.ethernet eth0: Link is Down
Tue Oct 22 08:06:37 2024 daemon.notice netifd: Network device 'eth0' link is down
Tue Oct 22 08:06:37 2024 daemon.notice netifd: Interface 'wan' has link connectivity loss
Tue Oct 22 08:06:37 2024 daemon.notice netifd: wan (9133): udhcpc: received SIGTERM
Tue Oct 22 08:06:37 2024 daemon.notice netifd: wan (9133): udhcpc: entering released state
Tue Oct 22 08:06:37 2024 daemon.notice netifd: wan (9133): Command failed: Permission denied
Tue Oct 22 08:06:37 2024 daemon.notice netifd: Interface 'wan' is now down
Tue Oct 22 08:06:37 2024 daemon.notice netifd: Interface 'wan' is disabled
Tue Oct 22 08:06:37 2024 daemon.notice netifd: Interface 'wan' is enabled
Tue Oct 22 08:06:37 2024 kern.info kernel: [54617.739416] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
Tue Oct 22 08:06:37 2024 user.notice firewall: Reloading firewall due to ifdown of wan ()
Tue Oct 22 08:06:38 2024 user.notice kmwan: config json str={ "op": 3, "data": { "cells": [ "wan" ] } }
Tue Oct 22 08:07:20 2024 daemon.info gl-cloud[9207]: (gl-cloud:230) fetch server from:	https://gslb-us.goodcloud.xyz/gslb/getbucket?deviceType=1&mac=xxxxxxxxxx&sn=xxxxxxxxxx&ddns=xxxxxxxxxx&timestamp=1729595240&sign=9d62a06398c466b880af052d27384296
Tue Oct 22 08:07:20 2024 daemon.err gl-cloud[9207]: (gl-cloud:234) fetch server fail: resolve "gslb-us.goodcloud.xyz" fail: not found valid nameservers
Tue Oct 22 08:07:20 2024 daemon.err gl-cloud[9207]: (gl-cloud:495) reconnect mqtt in 160s...
Tue Oct 22 08:07:30 2024 kern.info kernel: [54669.959646] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
Tue Oct 22 08:07:30 2024 kern.info kernel: [54669.968114] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Tue Oct 22 08:07:30 2024 daemon.notice netifd: Network device 'eth0' link is up
Tue Oct 22 08:07:30 2024 daemon.notice netifd: Interface 'wan' has link connectivity
Tue Oct 22 08:07:30 2024 daemon.notice netifd: Interface 'wan' is setting up now
Tue Oct 22 08:07:30 2024 daemon.notice netifd: wan (9717): udhcpc: started, v1.33.2
Tue Oct 22 08:07:30 2024 daemon.notice netifd: wan (9717): udhcpc: sending discover
Tue Oct 22 08:07:31 2024 kern.info kernel: [54670.983321] mtk_soc_eth 15100000.ethernet eth0: Link is Down
Tue Oct 22 08:07:31 2024 daemon.notice netifd: Network device 'eth0' link is down
Tue Oct 22 08:07:31 2024 daemon.notice netifd: Interface 'wan' has link connectivity loss
Tue Oct 22 08:07:31 2024 daemon.notice netifd: wan (9717): udhcpc: received SIGTERM
Tue Oct 22 08:07:31 2024 daemon.notice netifd: wan (9717): udhcpc: entering released state
Tue Oct 22 08:07:31 2024 daemon.notice netifd: wan (9717): Command failed: Permission denied
Tue Oct 22 08:07:31 2024 daemon.info avahi-daemon[6809]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::9683:c4ff:fe3a:a031.
Tue Oct 22 08:07:31 2024 daemon.info avahi-daemon[6809]: New relevant interface eth0.IPv6 for mDNS.
Tue Oct 22 08:07:31 2024 daemon.info avahi-daemon[6809]: Registering new address record for fe80::9683:c4ff:fe3a:a031 on eth0.*.
Tue Oct 22 08:07:31 2024 daemon.notice netifd: Interface 'wan' is now down
Tue Oct 22 08:07:31 2024 daemon.info avahi-daemon[6809]: Interface eth0.IPv6 no longer relevant for mDNS.
Tue Oct 22 08:07:31 2024 daemon.info avahi-daemon[6809]: Leaving mDNS multicast group on interface eth0.IPv6 with address fe80::9683:c4ff:fe3a:a031.
Tue Oct 22 08:07:31 2024 daemon.info avahi-daemon[6809]: Withdrawing address record for fe80::9683:c4ff:fe3a:a031 on eth0.
Tue Oct 22 08:07:31 2024 daemon.notice netifd: Interface 'wan' is disabled
Tue Oct 22 08:07:31 2024 kern.info kernel: [54671.074323] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
Tue Oct 22 08:07:31 2024 daemon.notice netifd: Interface 'wan' is enabled
Tue Oct 22 08:07:31 2024 user.notice firewall: Reloading firewall due to ifdown of wan ()
Tue Oct 22 08:07:31 2024 user.notice kmwan: config json str={ "op": 3, "data": { "cells": [ "wan" ] } }
Tue Oct 22 08:07:37 2024 kern.info kernel: [54677.221357] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
Tue Oct 22 08:07:37 2024 kern.info kernel: [54677.229829] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Tue Oct 22 08:07:37 2024 daemon.notice netifd: Network device 'eth0' link is up
Tue Oct 22 08:07:37 2024 daemon.notice netifd: Interface 'wan' has link connectivity
Tue Oct 22 08:07:37 2024 daemon.notice netifd: Interface 'wan' is setting up now
Tue Oct 22 08:07:37 2024 daemon.notice netifd: wan (10135): udhcpc: started, v1.33.2
Tue Oct 22 08:07:37 2024 daemon.notice netifd: wan (10135): udhcpc: sending discover
Tue Oct 22 08:07:38 2024 daemon.info avahi-daemon[6809]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::9683:c4ff:fe3a:a031.
Tue Oct 22 08:07:38 2024 daemon.info avahi-daemon[6809]: New relevant interface eth0.IPv6 for mDNS.
Tue Oct 22 08:07:38 2024 daemon.info avahi-daemon[6809]: Registering new address record for fe80::9683:c4ff:fe3a:a031 on eth0.*.
Tue Oct 22 08:07:40 2024 daemon.notice netifd: wan (10135): udhcpc: sending discover
Tue Oct 22 08:07:43 2024 daemon.notice netifd: wan (10135): udhcpc: sending discover
Tue Oct 22 08:10:00 2024 daemon.info gl-cloud[9207]: (gl-cloud:230) fetch server from:	https://gslb-us.goodcloud.xyz/gslb/getbucket?deviceType=1&mac=xxxxxxxxxx&sn=xxxxxxxxxx&ddns=xxxxxxxxxx&timestamp=1729595400&sign=4dfd8157d6b2747f58f3d2bb8f90cbad
Tue Oct 22 08:10:00 2024 daemon.err gl-cloud[9207]: (gl-cloud:234) fetch server fail: resolve "gslb-us.goodcloud.xyz" fail: not found valid nameservers
Tue Oct 22 08:10:00 2024 daemon.err gl-cloud[9207]: (gl-cloud:495) reconnect mqtt in 160s...
Tue Oct 22 08:12:40 2024 daemon.info gl-cloud[9207]: (gl-cloud:230) fetch server from:	https://gslb-us.goodcloud.xyz/gslb/getbucket?deviceType=1&mac=xxxxxxxxxx&sn=xxxxxxxxxx&ddns=xxxxxxxxxx&timestamp=1729595560&sign=20769218d232dcfa01b29108bacc4d24
Tue Oct 22 08:12:40 2024 daemon.err gl-cloud[9207]: (gl-cloud:234) fetch server fail: resolve "gslb-us.goodcloud.xyz" fail: not found valid nameservers
Tue Oct 22 08:12:40 2024 daemon.err gl-cloud[9207]: (gl-cloud:495) reconnect mqtt in 160s...
Tue Oct 22 08:15:20 2024 daemon.info gl-cloud[9207]: (gl-cloud:230) fetch server from:	https://gslb-us.goodcloud.xyz/gslb/getbucket?deviceType=1&mac=xxxxxxxxxxxxx&sn=xxxxxxxxxxxxxx&ddns=xxxxxxxxxxx&timestamp=1729595720&sign=026838c69b907b2d3db23ff8c2b5a077
Tue Oct 22 08:15:20 2024 daemon.err gl-cloud[9207]: (gl-cloud:234) fetch server fail: resolve "gslb-us.goodcloud.xyz" fail: not found valid nameservers
Tue Oct 22 08:15:20 2024 daemon.err gl-cloud[9207]: (gl-cloud:495) reconnect mqtt in 160s...
Tue Oct 22 08:18:00 2024 daemon.info gl-cloud[9207]: (gl-cloud:230) fetch server from:	https://gslb-us.goodcloud.xyz/gslb/getbucket?deviceType=1&mac=xxxxxxxxxx&sn=xxxxxxxxxx&ddns=xxxxxxxxxx&timestamp=1729595880&sign=89a02abad70c80c679674690a3b6dca9
Tue Oct 22 08:18:00 2024 daemon.err gl-cloud[9207]: (gl-cloud:234) fetch server fail: resolve "gslb-us.goodcloud.xyz" fail: not found valid nameservers
Tue Oct 22 08:18:00 2024 daemon.err gl-cloud[9207]: (gl-cloud:495) reconnect mqtt in 160s...
Tue Oct 22 08:20:40 2024 daemon.info gl-cloud[9207]: (gl-cloud:230) fetch server from:	https://gslb-us.goodcloud.xyz/gslb/getbucket?deviceType=1&mac=xxxxxxxxxx&sn=xxxxxxxxxx&ddns=xxxxxxxxxx&timestamp=1729596040&sign=4ff912d18f05b89423a358871da6c881
Tue Oct 22 08:20:40 2024 daemon.err gl-cloud[9207]: (gl-cloud:234) fetch server fail: resolve "gslb-us.goodcloud.xyz" fail: not found valid nameservers
Tue Oct 22 08:20:40 2024 daemon.err gl-cloud[9207]: (gl-cloud:495) reconnect mqtt in 160s...
Tue Oct 22 08:23:20 2024 daemon.info gl-cloud[9207]: (gl-cloud:230) fetch server from:	https://gslb-us.goodcloud.xyz/gslb/getbucket?deviceType=1&mac=xxxxxxxxxxx&sn=xxxxxxxxxx&ddns=xxxxxxxxxxxxx&timestamp=1729596200&sign=e05cb167fb236fb6ed684f934117452b
Tue Oct 22 08:23:20 2024 daemon.err gl-cloud[9207]: (gl-cloud:234) fetch server fail: resolve "gslb-us.goodcloud.xyz" fail: not found valid nameservers
Tue Oct 22 08:23:20 2024 daemon.err gl-cloud[9207]: (gl-cloud:495) reconnect mqtt in 160s...
Tue Oct 22 08:26:00 2024 daemon.info gl-cloud[9207]: (gl-cloud:230) fetch server from:	https://gslb-us.goodcloud.xyz/gslb/getbucket?deviceType=1&mac=xxxxxxxxxx&sn=xxxxxxxxxx&ddns=xxxxxxxxxx&timestamp=1729596360&sign=56f725e7a3442c45435cbe601e953bbc
Tue Oct 22 08:26:00 2024 daemon.err gl-cloud[9207]: (gl-cloud:234) fetch server fail: resolve "gslb-us.goodcloud.xyz" fail: not found valid nameservers
Tue Oct 22 08:26:00 2024 daemon.err gl-cloud[9207]: (gl-cloud:495) reconnect mqtt in 160s...
Tue Oct 22 08:28:40 2024 daemon.info gl-cloud[9207]: (gl-cloud:230) fetch server from:	https://gslb-us.goodcloud.xyz/gslb/getbucket?deviceType=1&mac=xxxxxxxxxx&sn=xxxxxxxxxx&ddns=xxxxxxxxxx&timestamp=1729596520&sign=d96f778be83e65139a6b8650a8612df2
Tue Oct 22 08:28:40 2024 daemon.err gl-cloud[9207]: (gl-cloud:234) fetch server fail: resolve "gslb-us.goodcloud.xyz" fail: not found valid nameservers
Tue Oct 22 08:28:40 2024 daemon.err gl-cloud[9207]: (gl-cloud:495) reconnect mqtt in 160s...
Tue Oct 22 08:28:57 2024 kern.info kernel: [55956.814716] mtk_soc_eth 15100000.ethernet eth0: Link is Down
Tue Oct 22 08:28:57 2024 daemon.notice netifd: Network device 'eth0' link is down
Tue Oct 22 08:28:57 2024 daemon.notice netifd: Interface 'wan' has link connectivity loss
Tue Oct 22 08:28:57 2024 daemon.notice netifd: wan (10135): udhcpc: received SIGTERM
Tue Oct 22 08:28:57 2024 daemon.notice netifd: wan (10135): udhcpc: entering released state
Tue Oct 22 08:28:57 2024 daemon.notice netifd: wan (10135): Command failed: Permission denied
Tue Oct 22 08:28:57 2024 daemon.notice netifd: Interface 'wan' is now down
Tue Oct 22 08:28:57 2024 daemon.info avahi-daemon[6809]: Interface eth0.IPv6 no longer relevant for mDNS.
Tue Oct 22 08:28:57 2024 daemon.info avahi-daemon[6809]: Leaving mDNS multicast group on interface eth0.IPv6 with address fe80::9683:c4ff:fe3a:a031.
Tue Oct 22 08:28:57 2024 daemon.info avahi-daemon[6809]: Withdrawing address record for fe80::9683:c4ff:fe3a:a031 on eth0.
Tue Oct 22 08:28:57 2024 daemon.notice netifd: Interface 'wan' is disabled
Tue Oct 22 08:28:57 2024 kern.info kernel: [55956.908808] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
Tue Oct 22 08:28:57 2024 daemon.notice netifd: Interface 'wan' is enabled
Tue Oct 22 08:28:57 2024 user.notice firewall: Reloading firewall due to ifdown of wan ()
Tue Oct 22 08:28:57 2024 user.notice kmwan: config json str={ "op": 3, "data": { "cells": [ "wan" ] } }
Tue Oct 22 08:30:09 2024 kern.info kernel: [56028.569618] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
Tue Oct 22 08:30:09 2024 kern.info kernel: [56028.578078] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Tue Oct 22 08:30:09 2024 daemon.notice netifd: Network device 'eth0' link is up
Tue Oct 22 08:30:09 2024 daemon.notice netifd: Interface 'wan' has link connectivity
Tue Oct 22 08:30:09 2024 daemon.notice netifd: Interface 'wan' is setting up now
Tue Oct 22 08:30:09 2024 daemon.notice netifd: wan (18024): udhcpc: started, v1.33.2
Tue Oct 22 08:30:09 2024 daemon.notice netifd: wan (18024): udhcpc: sending discover
Tue Oct 22 08:30:09 2024 daemon.notice netifd: wan (18024): udhcpc: sending select for 100.105.221.10
Tue Oct 22 08:30:09 2024 daemon.notice netifd: wan (18024): udhcpc: lease of 100.105.221.10 obtained, lease time 300
Tue Oct 22 08:30:09 2024 daemon.info avahi-daemon[6809]: Joining mDNS multicast group on interface eth0.IPv4 with address 100.105.221.10.
Tue Oct 22 08:30:09 2024 daemon.info avahi-daemon[6809]: New relevant interface eth0.IPv4 for mDNS.
Tue Oct 22 08:30:09 2024 daemon.info avahi-daemon[6809]: Registering new address record for 100.105.221.10 on eth0.IPv4.
Tue Oct 22 08:30:09 2024 daemon.notice netifd: Interface 'wan' is now up
Tue Oct 22 08:30:09 2024 user.notice firewall: Reloading firewall due to ifup of wan (eth0)
Tue Oct 22 08:30:09 2024 user.notice kmwan: config json str={ "op": 2, "data": { "cells": [ { "interface": "wan", "netdev": "eth0", "track_mode": "force", "addr_type": 4, "tracks": [ { "type": "ping", "ip": "1.1.1.1" }, { "type": "ping", "ip": "8.8.8.8" }, { "type": "ping", "ip": "208.67.222.222" }, { "type": "ping", "ip": "208.67.220.220" } ] } ] } }
Tue Oct 22 08:30:09 2024 kern.debug kernel: [56029.234669] [add_dev_config 288]add node success. iface:wan, dev:eth0, ifindex:2
Tue Oct 22 08:30:10 2024 daemon.info avahi-daemon[6809]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::9683:c4ff:fe3a:a031.
Tue Oct 22 08:30:10 2024 daemon.info avahi-daemon[6809]: New relevant interface eth0.IPv6 for mDNS.
Tue Oct 22 08:30:10 2024 daemon.info avahi-daemon[6809]: Registering new address record for fe80::9683:c4ff:fe3a:a031 on eth0.*.
Tue Oct 22 08:31:20 2024 daemon.info gl-cloud[9207]: (gl-cloud:230) fetch server from:	https://gslb-us.goodcloud.xyz/gslb/getbucket?deviceType=1&mac=xxxxxxxxxxx&sn=xxxxxxxxxx&ddns=xxxxxxxxxxx&timestamp=1729596680&sign=70e1ac762910e2bf70e6c9adb6397055
Tue Oct 22 08:31:22 2024 daemon.info gl-cloud[9207]: (gl-cloud:522) connected:	true	0	connection accepted
Tue Oct 22 08:31:22 2024 daemon.info gl-cloud[9207]: (gl-cloud:529) connected:	0	connection accepted
Tue Oct 22 08:32:39 2024 daemon.notice netifd: wan (18024): udhcpc: sending renew to 100.64.0.1
Tue Oct 22 08:32:39 2024 daemon.notice netifd: wan (18024): udhcpc: lease of 100.105.221.10 obtained, lease time 300
Some timestamps to note:
Tue Oct 22 07:36:40 - Starlink is turned on. MT3000 is on all the time.
Tue Oct 22 07:39:55 - Starlink establishes internet connection.
Tue Oct 22 08:00:53 - First time eth0 link down.
Then the link goes up and down multiple times but never regaining actual internet connection.
Tue Oct 22 08:07:43 - After this point, nothing ever happens on router with ethernet connection, just sits saying "connecting...."
Tue Oct 22 08:28:57 - Physically unplugged Ethernet cable from MT3000.
Tue Oct 22 08:30:09 - Physically plugged Ethernet cable back into MT3000. Internet works again.
The problem occurred on 2 different devices. The common denominator are Starlink and the ethernet cable. Are you able to test the cable or replace it?
Maybe I am misunderstanding what you mean, but it all happened on the same MT3000 with different firmware versions.
Replacing the cable is not easy as Starlink uses custom pin outs and I would have to make a new one and I do not have the parts right now. I agree this is something to test though.
This sounds like you already had had issues, before you switched to MT3000. How exactly is Starlink connected to MT3000? Which Starlink dish are you using?
The MT3000 solved the Ethernet disconnect issues. This is a known problem with MT1300 where it will disconnect and then reconnect back to the Starlink.
Starlink is connected to router through a Tycon POE injector. Gen 2 running off 56V DC.
I am not ruling out a cable issue, just don't have the equipment to crimp special Ethernet wiring needed for Starlink POE. It works sometimes for a few days, so I feel the cable is likely ok.
Maybe Tycon POE is causing issue. I guess if no one else has this issue it must be some other hardware in my install.
Why would MT3000 not reconnect? That is the new issue. MT1300 would drop and reconnect. MT3000 was working fine for many months, never a disconnect (different firmware versions over the past 10 months). Now when it disconnects, it never connects again. But simply the removing and inserting the Ethernet cable causes all to be ok again. This seems like a router issue, no?
I am running some more tests. One think I changed on the router was I turned goodcloud on. Seems irrelevant to this type of issue, but I turned it off again to see what happens.
And on the latest firmware 4.6.4, the disconnect were quite frequent, on 4.5.16, it's fine for days usually, but sometimes not.
I’d expect a reconnection as well, but sometimes weird things can happen with cables. I could imagine that the cable was in a perfect alignment for a while but then it was moved slightly and started acting up. Sometimes ethtool can show some interesting statistics. dmesg can contain some information.
This firmware is fully functional. Please try it.
