MT3000 log onto LuCI
I have not been able to log into the LuCI interface for a while yet. When I bring up the LuCI interface, the username ‘root’ is pre-filled. When I enter the password that I use with the GL.Inet interface, the login page accepts it and the login page comes back and doesn’t display an error message. If I don’t enter a password, I get an error message that the username or password is incorrect.
How can I get into the LuCI interface? It seems it’s the only way to back up my configuration.
Try to using a private browser if you have not been doing so, you may need to clear the regular browser cache first.
You could also try:
http://192.168.8.1/cgi-bin/luci/#
add the / and # the LuCi address( note it is your default gateway address)
:gl_emoji_dizzy:I do not work for and I am not directly associated with GL.iNet :gl_emoji_shacking:
Thanks. I cleared the cache for the router on my web browser. All is well.
What is your firmware version? Have you installed any other packages?
