Trying to setup NordVPN and can’t connect.
Using firmware gl-mt3000-4.6.0-r2-2.1-13.20
I’ve attached a log:
Mon Apr 22 16:35:00 2024 daemon.notice ovpnclient[13898]: VERIFY OK: depth=0, CN=us6318.nordvpn.com
Mon Apr 22 16:35:01 2024 daemon.notice ovpnclient[13898]: Control Channel: TLSv1.3, cipher TLSv1.3 TLS_AES_256_GCM_SHA384, peer certificate: 4096 bit RSA, signature: RSA-SHA512
Mon Apr 22 16:35:01 2024 daemon.notice ovpnclient[13898]: [us6318.nordvpn.com] Peer Connection Initiated with [AF_INET]172.93.177.59:1194
Mon Apr 22 16:35:02 2024 daemon.notice ovpnclient[13898]: SENT CONTROL [us6318.nordvpn.com]: ‘PUSH_REQUEST’ (status=1)
Mon Apr 22 16:35:07 2024 daemon.notice ovpnclient[13898]: SENT CONTROL [us6318.nordvpn.com]: ‘PUSH_REQUEST’ (status=1)
Mon Apr 22 16:35:07 2024 daemon.notice ovpnclient[13898]: AUTH: Received control message: AUTH_FAILED
Mon Apr 22 16:35:07 2024 daemon.notice ovpnclient[13898]: SIGTERM[soft,auth-failure] received, process exiting
Mon Apr 22 16:35:07 2024 daemon.notice netifd: ovpnclient (13953): [!] Section @forwarding[0] is disabled, ignoring section
Mon Apr 22 16:35:07 2024 daemon.notice netifd: ovpnclient (13953): [!] Section @forwarding[1] is disabled, ignoring section
Mon Apr 22 16:35:07 2024 daemon.notice netifd: ovpnclient (13953): [!] Section nat6 option ‘reload’ is not supported by fw4
Mon Apr 22 16:35:07 2024 daemon.notice netifd: ovpnclient (13953): [!] Section gls2s option ‘reload’ is not supported by fw4
Mon Apr 22 16:35:07 2024 daemon.notice netifd: ovpnclient (13953): [!] Section gls2s specifies unreachable path ‘/var/etc/gls2s.include’, ignoring section
Mon Apr 22 16:35:07 2024 daemon.notice netifd: ovpnclient (13953): [!] Section glblock option ‘reload’ is not supported by fw4
Mon Apr 22 16:35:07 2024 daemon.notice netifd: ovpnclient (13953): [!] Section vpn_server_policy option ‘reload’ is not supported by fw4
Mon Apr 22 16:35:07 2024 daemon.notice netifd: ovpnclient (13953): [!] Automatically including ‘/usr/share/nftables.d/chain-pre/dstnat/00-dhcp-no-flow_offloading.nft’
Mon Apr 22 16:35:07 2024 daemon.notice netifd: ovpnclient (13953): [!] Automatically including ‘/usr/share/nftables.d/chain-pre/mangle_output/01-process_mark.nft’
Mon Apr 22 16:35:07 2024 daemon.notice netifd: ovpnclient (13953): [!] Automatically including ‘/usr/share/nftables.d/chain-post/mangle_output/out_conn_mark_restore.nft’
Mon Apr 22 16:35:07 2024 daemon.notice netifd: ovpnclient (13953): Failed to parse json data: unexpected character
Mon Apr 22 16:35:07 2024 daemon.notice netifd: ovpnclient (13953): uci: Entry not found
Mon Apr 22 16:35:07 2024 daemon.notice netifd: ovpnclient (13953): cat: can’t open ‘/tmp/run/ovpn_resolved_ip’: No such file or directory
