MT3000 not able to connect to wifi with WPA2/WPA3 mixed
My GL-MT3000 on firmware 4.7.4
It cannot properly connect to a WiFi using mixed WPA2/WPA3 in repeator mode.
If I changed my primary router to use WPA2 only, it works.
From the log, it shows:
Wed Jun 25 23:06:52 2025 kern.err kernel: [  476.263850] 7981@C09L1,sta_cntl_assoc_conf() 1638: CNTL - Association fails on BSS #38 Reason(16)
Wed Jun 25 23:06:52 2025 kern.warn kernel: [  476.272728] 7981@C01L2,wifi_sys_disconn_act() 1002:  wdev_idx=5
Wed Jun 25 23:06:52 2025 kern.warn kernel: [  476.278891] 7981@C13L2,MacTableDeleteEntry() 1938: Del Sta:e0:1f:2b:5f:8b:bc
Wed Jun 25 23:06:53 2025 kern.debug kernel: [  476.796035] Set_ByPassCac_Proc(): set CAC value to 1
Wed Jun 25 23:06:53 2025 kern.warn kernel: [  477.771590] 7981@C09L2,cntl_connect_request() 395: type=2,len=0,caller:ApCliIfUp+0x184/0x358 [mt_wifi]
Wed Jun 25 23:06:54 2025 kern.debug kernel: [  477.783250] entrytb_aid_aquire(): found non-occupied aid:5, allocated from:4
Wed Jun 25 23:06:54 2025 kern.notice kernel: [  477.860219] 7981@C09L3,sta_mlme_auth_req_action() 201: wdev(type=2,wdev_idx=5,wdev_func_idx=1
Wed Jun 25 23:06:54 2025 kern.notice kernel: [  477.868743] 7981@C09L3,sta_send_auth_req() 68: STA Start send Auth req
Wed Jun 25 23:06:54 2025 kern.err kernel: [  477.875272] 7981@C09L1,sta_send_auth_req() 107: AUTH - Send AUTH request seq#1 (Alg=0)...
Wed Jun 25 23:06:54 2025 kern.notice kernel: [  478.199137] 7981@C00L3,sta_auth_timeout_action() 274: AUTH - AuthTimeoutAction
Wed Jun 25 23:06:54 2025 kern.warn kernel: [  478.206381] 7981@C09L2,sta_cntl_auth_conf() 1486: CNTL - AUTH FAIL, try again...
Wed Jun 25 23:06:54 2025 kern.err kernel: [  478.340184] WiFi@C15L1,sae_parse_commit_element_ecc() 4412: pSaeIns->peer_commit_element is not NULL!
It seems like due to WPA3/WPA2 Auth failure.
We did not reproduce the issue in my MT3000:
primary router MT6000 + WPA2/3, MT3000 repeater is normal to connected to MT6000.
  1. Does the primary router WiFi have other parameters/configurations? Please PM me to share the encryption configuration.
  2. Please SSH to router MT3000, execute the command:
    iwpriv ra0 set debug=5:13
    Perform a repeater connection to primary WiFi using WPA2/3, export the syslog "logread.tar", and PM it to me.
Still here?
Please let me know if you have any updates.
TIA!
