Received the beta test unit with firmware 4.1 and noticed all configuration woudl reset upon reboot.
Fix - update to beta 4.1.2 version.
Seems a bug. But as long as it does not appear in newer firmware…
Mine is on firmware 4.1.0 and doesn’t present the settings lost issue after reboot.
I have just done a software reboot and power cable disconnect and reconnect.
Same - I have not encountered this and I rebooted a lot.
