MT3000 will not connect to or repeat wifi
Channel 44 should work fine, which is the same as for me with Rogers. You can also check the XB7 logs by logging into the gateway as admin.
Does the 5GHz wifi work if you connect to the XB7 directly using your Mac or a smartphone? If that works, then you can try downgrading to the previous firmware version you had on the GL-MT3000.
