Hi All,
While building our firmware I noticed the following report from the builder.
Here are the issued warnings:
make[3] -C target/linux install
Pseudo file “/dev” exists in source filesystem “/work/firmware/MT300A/openwrt.18.06/openwrt-18.06/build_dir/target-mipsel_24kc_musl/root-ramips/dev”.
Ignoring, exclude it (-e/-ef) to override.
/work/firmware/MT300A/openwrt.18.06/openwrt-18.06/build_dir/target-mipsel_24kc_musl/linux-ramips_mt7620/gl-mt300a-kernel.bin.dtb: Warning (unit_address_vs_reg): Node /cpus/cpu@0 has a unit name, but no reg property
/work/firmware/MT300A/openwrt.18.06/openwrt-18.06/build_dir/target-mipsel_24kc_musl/linux-ramips_mt7620/gl-mt300a-kernel.bin.dtb: Warning (unit_address_vs_reg): Node /cpuintc@0 has a unit name, but no reg property
/work/firmware/MT300A/openwrt.18.06/openwrt-18.06/build_dir/target-mipsel_24kc_musl/linux-ramips_mt7620/gl-mt300a-kernel.bin.dtb: Warning (unit_address_vs_reg): Node /pcie@10140000/pcie-bridge has a reg or ranges property, but no unit name
/work/firmware/MT300A/openwrt.18.06/openwrt-18.06/build_dir/target-mipsel_24kc_musl/linux-ramips_mt7620/gl-mt300a-kernel.bin.dtb: Warning (pci_bridge): Node /pcie@10140000/pcie-bridge node name is not “pci” or “pcie”
/work/firmware/MT300A/openwrt.18.06/openwrt-18.06/build_dir/target-mipsel_24kc_musl/linux-ramips_mt7620/gl-mt300a-kernel.bin.dtb: Warning (pci_bridge): Node /pcie@10140000/pcie-bridge missing ranges for PCI bridge (or not a bridge)
/work/firmware/MT300A/openwrt.18.06/openwrt-18.06/build_dir/target-mipsel_24kc_musl/linux-ramips_mt7620/gl-mt300a-kernel.bin.dtb: Warning (pci_bridge): Node /pcie@10140000/pcie-bridge missing bus-range for PCI bridge
/work/firmware/MT300A/openwrt.18.06/openwrt-18.06/build_dir/target-mipsel_24kc_musl/linux-ramips_mt7620/gl-mt300a-kernel.bin.dtb: Warning (unit_address_format): Failed prerequisite ‘pci_bridge’
/work/firmware/MT300A/openwrt.18.06/openwrt-18.06/build_dir/target-mipsel_24kc_musl/linux-ramips_mt7620/gl-mt300a-kernel.bin.dtb: Warning (pci_device_reg): Failed prerequisite ‘pci_bridge’
/work/firmware/MT300A/openwrt.18.06/openwrt-18.06/build_dir/target-mipsel_24kc_musl/linux-ramips_mt7620/gl-mt300a-kernel.bin.dtb: Warning (pci_device_bus_num): Failed prerequisite ‘pci_bridge’
Thanks
