Hi. I looked for the answer and couldn’t find it so I figured it was time to just ask.
There is a public WiFi hotspot near my house, but in repeater mode I can only get about 1 megabit per second.
It is way stronger about 2 blocks closer, but I’m too far to get a decent signal. I was thinking of setting up the so the gli.net router is using both antennas to access the WiFi hotspot and only send through the Ethernet cable. I think it might help it get better reception, since the reception is cut by half when doing wifi repeater.
So what I want to do is convert the wifi signal to Ethernet and connect another router to it to broadcast in the house.
How do I turn off the wifi broadcast on the router so that the antennas are only used to access the hotspot and data sent through the lan port?
Thanks for your help!
