Hi All,
Just received this device and I’m wondering what’s the capacity of this reader ?
Thanks
Hi All,
Thanks
Hi All,
Just found that the MTK7620A support SDXC.
http://www.mediatek.com/en/products/connectivity/wifi/home-network/wifi-ap/mt7620na/
However no information about which version of SDXC is supported ?
Thanks
FWIW, I was unable to get the exFAT file system working under OpenWrt and re-formatted the card.
I run a 64GB card on another MT7620A device.
128MB should OK. We only tested 64MB though.
