on initial boot:
root@GL-X750:~# df -h
Filesystem Size Used Available Use% Mounted on
/dev/root 9.3M 9.3M 0 100% /rom
tmpfs 60.9M 296.0K 60.6M 0% /tmp
tmpfs 60.9M 132.0K 60.7M 0% /tmp/root
tmpfs 512.0K 0 512.0K 0% /dev
/dev/mtdblock6 5.0M 308.0K 4.7M 6% /overlay
overlayfs:/overlay 5.0M 308.0K 4.7M 6% /
root@GL-X750:~# dmsg
-ash: dmsg: not found
root@GL-X750:~# dmesg
[ 0.000000] Linux version 4.9.120 (lancer@gl-inet) (gcc version 7.3.0 (OpenWrt GCC 7.3.0 r7258-5eb055306f) ) #0 Thu Aug 16 07:51:15 2018
[ 0.000000] MyLoader: sysp=d735dfbf, boardp=3dfa7fd5, parts=beeaedf7
[ 0.000000] bootconsole [early0] enabled
[ 0.000000] CPU0 revision is: 00019374 (MIPS 24Kc)
[ 0.000000] SoC: Qualcomm Atheros QCA9533 ver 2 rev 0
[ 0.000000] Determined physical RAM map:
[ 0.000000] memory: 08000000 @ 00000000 (usable)
[ 0.000000] Initrd not found or empty - disabling initrd
[ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
[ 0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x0000000000000000-0x0000000007ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x0000000007ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x0000000007ffffff]
[ 0.000000] On node 0 totalpages: 32768
[ 0.000000] free_area_init_node: node 0, pgdat 804dd074, node_mem_map 81000020
[ 0.000000] Normal zone: 256 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 32768 pages, LIFO batch:7
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
[ 0.000000] Kernel command line: board=GL-X750 mtdparts=spi0.0:256k(u-boot)ro,64k(u-boot-env),64k(art)ro,-(firmware) console=null,115200 rootfstype=squashfs noinitrd
[ 0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Writing ErrCtl register=00000000
[ 0.000000] Readback ErrCtl register=00000000
[ 0.000000] Memory: 124352K/131072K available (3533K kernel code, 182K rwdata, 884K rodata, 320K init, 220K bss, 6720K reserved, 0K cma-reserved)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS:51
[ 0.000000] Clocks: CPU:650.000MHz, DDR:597.216MHz, AHB:216.666MHz, Ref:25.000MHz
[ 0.000000] clocksource: MIPS: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 5880801374 ns
[ 0.000008] sched_clock: 32 bits at 325MHz, resolution 3ns, wraps every 6607641598ns
[ 0.008240] Calibrating delay loop... 432.53 BogoMIPS (lpj=2162688)
[ 0.071099] pid_max: default: 32768 minimum: 301
[ 0.076080] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.083062] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.093220] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.103611] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.111243] NET: Registered protocol family 16
[ 0.117417] MIPS: machine is GL.iNet GL-X750
[ 0.604570] registering PCI controller with io_map_base unset
[ 0.627813] usbcore: registered new interface driver usbfs
[ 0.633718] usbcore: registered new interface driver hub
[ 0.639380] usbcore: registered new device driver usb
[ 0.645015] PCI host bridge to bus 0000:00
[ 0.649344] pci_bus 0000:00: root bus resource [mem 0x10000000-0x11ffffff]
[ 0.656614] pci_bus 0000:00: root bus resource [io 0x0000]
[ 0.662482] pci_bus 0000:00: root bus resource [??? 0x00000000 flags 0x0]
[ 0.669644] pci_bus 0000:00: No busn resource found for root bus, will use [bus 00-ff]
[ 0.678018] pci 0000:00:00.0: [168c:0050] type 00 class 0x028000
[ 0.678028] pci 0000:00:00.0: invalid calibration data
[ 0.683475] pci 0000:00:00.0: reg 0x10: [mem 0x00000000-0x001fffff 64bit]
[ 0.683529] pci 0000:00:00.0: reg 0x30: [mem 0x00000000-0x0000ffff pref]
[ 0.683599] pci 0000:00:00.0: supports D1
[ 0.683608] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[ 0.683801] pci_bus 0000:00: busn_res: [bus 00-ff] end is updated to 00
[ 0.683829] pci 0000:00:00.0: BAR 0: assigned [mem 0x10000000-0x101fffff 64bit]
[ 0.691553] pci 0000:00:00.0: BAR 6: assigned [mem 0x10200000-0x1020ffff pref]
[ 0.699201] pci 0000:00:00.0: using irq 40 for pin 1
[ 0.708096] clocksource: Switched to clocksource MIPS
[ 0.714479] NET: Registered protocol family 2
[ 0.719991] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.727352] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.734106] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.740912] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.747081] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.753963] NET: Registered protocol family 1
[ 0.758623] PCI: CLS 0 bytes, default 32
[ 0.761280] Crashlog allocated RAM at address 0x3f00000
[ 0.767821] workingset: timestamp_bits=30 max_order=15 bucket_order=0
[ 0.781589] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.787734] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.807012] io scheduler noop registered
[ 0.811196] io scheduler deadline registered (default)
[ 0.817006] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[ 0.846289] serial8250.0: ttyS0 at MMIO 0x18020000 (irq = 11, base_baud = 1562500) is a 16550A
[ 0.861433] m25p80 spi0.0: found w25q128, expected m25p80
[ 0.876387] m25p80 spi0.0: w25q128 (16384 Kbytes)
[ 0.881385] 4 cmdlinepart partitions found on MTD device spi0.0
[ 0.887614] Creating 4 MTD partitions on "spi0.0":
[ 0.892675] 0x000000000000-0x000000040000 : "u-boot"
[ 0.899749] 0x000000040000-0x000000050000 : "u-boot-env"
[ 0.907236] 0x000000050000-0x000000060000 : "art"
[ 0.914194] 0x000000060000-0x000001000000 : "firmware"
[ 0.943459] 2 uimage-fw partitions found on MTD device firmware
[ 0.949732] 0x000000060000-0x0000001e0000 : "kernel"
[ 0.956310] 0x0000001e0000-0x000001000000 : "rootfs"
[ 0.963182] mtd: device 5 (rootfs) set to be root filesystem
[ 0.969233] 1 squashfs-split partitions found on MTD device rootfs
[ 0.975751] 0x000000b00000-0x000001000000 : "rootfs_data"
[ 0.984416] libphy: Fixed MDIO Bus: probed
[ 1.011435] libphy: ag71xx_mdio: probed
[ 1.641028] ag71xx ag71xx.0: connected to PHY at ag71xx-mdio.1:04 [uid=004dd042, driver=Generic PHY]
[ 1.651339] eth0: Atheros AG71xx at 0xb9000000, irq 4, mode:MII
[ 2.280640] ag71xx-mdio.1: Found an AR934X built-in switch
[ 2.333949] eth1: Atheros AG71xx at 0xba000000, irq 5, mode:GMII
[ 2.340586] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.347458] ehci-pci: EHCI PCI platform driver
[ 2.352349] usbcore: registered new interface driver usbtest
[ 2.358405] usbcore: registered new interface driver usb_ehset_test
[ 2.365064] usbcore: registered new interface driver lvs
[ 2.372318] NET: Registered protocol family 10
[ 2.381611] NET: Registered protocol family 17
[ 2.386344] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 2.400143] 8021q: 802.1Q VLAN Support v1.8
[ 2.406298] hctosys: unable to open rtc device (rtc0)
[ 2.411726] Warning: unable to open an initial console.
[ 2.423020] VFS: Mounted root (squashfs filesystem) readonly on device 31:5.
[ 2.432233] Freeing unused kernel memory: 320K
[ 2.436905] This architecture does not have kernel memory protection.
[ 2.588113] random: fast init done
[ 3.081096] init: Console is alive
[ 3.084878] init: - watchdog -
[ 5.099264] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[ 5.255921] exFAT: Version 1.2.9
[ 5.297451] SCSI subsystem initialized
[ 5.306533] ehci-platform: EHCI generic platform driver
[ 5.312185] ehci-platform ehci-platform: EHCI Host Controller
[ 5.318453] ehci-platform ehci-platform: new USB bus registered, assigned bus number 1
[ 5.328934] ehci-platform ehci-platform: irq 3, io mem 0x1b000000
[ 5.358133] ehci-platform ehci-platform: USB 2.0 started, EHCI 1.00
[ 5.364909] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 5.372089] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.379703] usb usb1: Product: EHCI Host Controller
[ 5.384836] usb usb1: Manufacturer: Linux 4.9.120 ehci_hcd
[ 5.390624] usb usb1: SerialNumber: ehci-platform
[ 5.396383] hub 1-0:1.0: USB hub found
[ 5.400646] hub 1-0:1.0: 1 port detected
[ 5.407733] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 5.415784] ohci-platform: OHCI generic platform driver
[ 5.423829] uhci_hcd: USB Universal Host Controller Interface driver
[ 5.434820] usbcore: registered new interface driver usb-storage
[ 5.441957] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[ 5.452308] init: - preinit -
[ 6.001332] usb 1-1: new high-speed USB device number 2 using ehci-platform
[ 6.370934] usb 1-1: New USB device found, idVendor=05e3, idProduct=0618
[ 6.378025] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 6.385584] usb 1-1: Product: USB2.0 Hub
[ 6.390720] random: procd: uninitialized urandom read (4 bytes read)
[ 6.418393] hub 1-1:1.0: USB hub found
[ 6.422850] hub 1-1:1.0: 4 ports detected
[ 6.726970] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 6.848993] usb 1-1.1: new high-speed USB device number 3 using ehci-platform
[ 7.014002] usb 1-1.1: New USB device found, idVendor=05e3, idProduct=0752
[ 7.021315] usb 1-1.1: New USB device strings: Mfr=3, Product=4, SerialNumber=0
[ 7.029030] usb 1-1.1: Product: USB Storage
[ 7.033435] usb 1-1.1: Manufacturer: Generic
[ 7.059889] usb-storage 1-1.1:1.0: USB Mass Storage device detected
[ 7.077602] scsi host0: usb-storage 1-1.1:1.0
[ 7.188296] usb 1-1.2: new high-speed USB device number 4 using ehci-platform
[ 7.350813] usb 1-1.2: New USB device found, idVendor=2c7c, idProduct=0306
[ 7.358120] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 7.365832] usb 1-1.2: Product: LTE-A Module
[ 7.370344] usb 1-1.2: Manufacturer: Quectel
[ 7.374838] usb 1-1.2: SerialNumber: 0123456789ABCDEF
[ 8.125872] scsi 0:0:0:0: Direct-Access Generic STORAGE DEVICE 0233 PQ: 0 ANSI: 0
[ 8.389494] sd 0:0:0:0: [sda] 1966080 512-byte logical blocks: (1.01 GB/960 MiB)
[ 8.404431] sd 0:0:0:0: [sda] Write Protect is off
[ 8.409542] sd 0:0:0:0: [sda] Mode Sense: 0b 00 00 08
[ 8.415222] sd 0:0:0:0: [sda] No Caching mode page found
[ 8.420905] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 8.445446] sda: sda1
[ 8.454530] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 9.008484] mount_root: jffs2 not ready yet, using temporary tmpfs overlay
[ 9.087508] urandom-seed: Seed file not found (/etc/urandom.seed)
[ 9.214932] procd: - early -
[ 9.218054] procd: - watchdog -
[ 9.851621] random: jshn: uninitialized urandom read (4 bytes read)
[ 9.927221] procd: - watchdog -
[ 9.930767] procd: failed to set stdio: No such device
[ 9.936241] procd: - ubus -
[ 10.208303] random: ubusd: uninitialized urandom read (4 bytes read)
[ 10.348330] random: ubusd: uninitialized urandom read (4 bytes read)
[ 10.366686] procd: - init -
[ 11.967376] kmodloader: loading kernel modules from /etc/modules.d/*
[ 12.038950] ntfs: driver 2.1.32 [Flags: R/O MODULE].
[ 12.082312] tun: Universal TUN/TAP device driver, 1.6
[ 12.087632] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 12.124125] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 12.152632] Netfilter messages via NETLINK v0.30.
[ 12.170591] ip_set: protocol 6
[ 12.262782] u32 classifier
[ 12.265637] input device check on
[ 12.269545] Actions configured
[ 12.290603] Mirror/redirect action on
[ 12.308521] nf_conntrack version 0.5.0 (2048 buckets, 8192 max)
[ 12.396340] fuse init (API version 7.26)
[ 12.425924] usbcore: registered new interface driver cdc_acm
[ 12.431949] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 12.459416] usbcore: registered new interface driver cdc_wdm
[ 12.479707] Loading modules backported from Linux version wt-2017-11-01-0-gfe248fc2c180
[ 12.488193] Backport generated by backports.git v4.14-rc2-1-31-g86cf0e5d
[ 12.513630] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 12.539041] usbcore: registered new interface driver ipheth
[ 12.902828] usbcore: registered new interface driver usbserial
[ 12.909124] usbcore: registered new interface driver usbserial_generic
[ 12.916085] usbserial: USB Serial support registered for generic
[ 12.955421] wireguard: WireGuard 0.0.20180718 loaded. See www.wireguard.com for information.
[ 12.964377] wireguard: Copyright (C) 2015-2018 Jason A. Donenfeld <Jason@zx2c4.com>. All Rights Reserved.
[ 13.079197] xt_time: kernel timezone is -0000
[ 13.090013] usbcore: registered new interface driver cdc_ether
[ 13.111436] usbcore: registered new interface driver cdc_ncm
[ 13.315709] usbcore: registered new interface driver cp210x
[ 13.321740] usbserial: USB Serial support registered for cp210x
[ 13.347685] usbcore: registered new interface driver huawei_cdc_ncm
[ 13.472365] PPP generic driver version 2.4.2
[ 13.489973] PPP MPPE Compression module registered
[ 13.501839] NET: Registered protocol family 24
[ 13.521181] qmi_wwan 1-1.2:1.4: cdc-wdm0: USB WDM device
[ 13.526783] qmi_wwan 1-1.2:1.4: QuectelEC25&EC21&EG91&EG95&EG06&EP06&EM06&BG96&AG35 work on RawIP mode
[ 13.556094] qmi_wwan 1-1.2:1.4 wwan0: register 'qmi_wwan' at usb-ehci-platform-1.2, WWAN/QMI device, 0e:5d:8a:90:c9:4d
[ 13.567575] usbcore: registered new interface driver qmi_wwan
[ 13.600055] usbcore: registered new interface driver rndis_host
[ 13.643330] usbcore: registered new interface driver sierra
[ 13.649356] usbserial: USB Serial support registered for Sierra USB modem
[ 13.670126] usbcore: registered new interface driver sierra_net
[ 13.752634] PCI: Enabling device 0000:00:00.0 (0000 -> 0002)
[ 13.758807] ath10k_pci 0000:00:00.0: pci irq legacy oper_irq_mode 1 irq_mode 0 reset_mode 0
[ 14.063985] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/pre-cal-pci-0000:00:00.0.bin failed with error -2
[ 14.075331] ath10k_pci 0000:00:00.0: Falling back to user helper
[ 29.228499] firmware ath10k!pre-cal-pci-0000:00:00.0.bin: firmware_loading_store: map pages failed
[ 29.240927] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/cal-pci-0000:00:00.0.bin failed with error -2
[ 29.251870] ath10k_pci 0000:00:00.0: Falling back to user helper
[ 29.561622] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/QCA9887/hw1.0/firmware-6.bin failed with error -2
[ 29.572954] ath10k_pci 0000:00:00.0: Falling back to user helper
[ 29.685396] firmware ath10k!QCA9887!hw1.0!firmware-6.bin: firmware_loading_store: map pages failed
[ 29.897200] ath10k_pci 0000:00:00.0: qca9887 hw1.0 target 0x4100016d chip_id 0x004000ff sub 0000:0000
[ 29.906975] ath10k_pci 0000:00:00.0: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 1
[ 29.921083] ath10k_pci 0000:00:00.0: firmware ver 10.2.4-1.0-00033 api 5 features no-p2p,ignore-otp,skip-clock-init,mfp,allows-mesh-bcast crc32 c232a0c3
[ 29.968349] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/QCA9887/hw1.0/board-2.bin failed with error -2
[ 29.979375] ath10k_pci 0000:00:00.0: Falling back to user helper
[ 30.058218] firmware ath10k!QCA9887!hw1.0!board-2.bin: firmware_loading_store: map pages failed
[ 30.080014] ath10k_pci 0000:00:00.0: board_file api 1 bmi_id N/A crc32 546cca0d
[ 31.139545] ath10k_pci 0000:00:00.0: htt-ver 2.1 wmi-op 5 htt-op 2 cal file max-sta 128 raw 0 hwcrypto 1
[ 31.279654] ath: EEPROM regdomain: 0x0
[ 31.279662] ath: EEPROM indicates default country code should be used
[ 31.279666] ath: doing EEPROM country->regdmn map search
[ 31.279676] ath: country maps to regdmn code: 0x3a
[ 31.279681] ath: Country alpha2 being used: US
[ 31.279685] ath: Regpair used: 0x3a
[ 31.373515] usbcore: registered new interface driver option
[ 31.379538] usbserial: USB Serial support registered for GSM modem (1-port)
[ 31.387304] option 1-1.2:1.0: GSM modem (1-port) converter detected
[ 31.394205] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB0
[ 31.401625] option 1-1.2:1.1: GSM modem (1-port) converter detected
[ 31.408500] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB1
[ 31.415873] option 1-1.2:1.2: GSM modem (1-port) converter detected
[ 31.422779] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB2
[ 31.430199] option 1-1.2:1.3: GSM modem (1-port) converter detected
[ 31.437054] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB3
[ 31.537334] usbcore: registered new interface driver rt2800usb
[ 31.573272] ath: EEPROM regdomain: 0x0
[ 31.573281] ath: EEPROM indicates default country code should be used
[ 31.573284] ath: doing EEPROM country->regdmn map search
[ 31.573299] ath: country maps to regdmn code: 0x3a
[ 31.573304] ath: Country alpha2 being used: US
[ 31.573308] ath: Regpair used: 0x3a
[ 31.584134] ieee80211 phy1: Selected rate control algorithm 'minstrel_ht'
[ 31.588295] ieee80211 phy1: Atheros AR9531 Rev:2 mem=0xb8100000, irq=47
[ 31.677253] kmodloader: done loading kernel modules from /etc/modules.d/*
[ 54.762357] br-lan: port 1(eth1) entered blocking state
[ 54.767869] br-lan: port 1(eth1) entered disabled state
[ 54.773797] device eth1 entered promiscuous mode
[ 54.799601] br-lan: port 1(eth1) entered blocking state
[ 54.805120] br-lan: port 1(eth1) entered forwarding state
[ 54.811010] IPv6: ADDRCONF(NETDEV_UP): br-lan: link is not ready
[ 54.863352] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 55.718241] br-lan: port 1(eth1) entered disabled state
[ 62.007487] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 62.035150] IPv6: ADDRCONF(NETDEV_UP): wlan1: link is not ready
[ 62.075527] br-lan: port 2(wlan0) entered blocking state
[ 62.081293] br-lan: port 2(wlan0) entered disabled state
[ 62.087298] device wlan0 entered promiscuous mode
[ 62.201824] br-lan: port 3(wlan1) entered blocking state
[ 62.207430] br-lan: port 3(wlan1) entered disabled state
[ 62.213488] device wlan1 entered promiscuous mode
[ 62.218573] br-lan: port 3(wlan1) entered blocking state
[ 62.224169] br-lan: port 3(wlan1) entered forwarding state
[ 62.230221] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
[ 63.078209] br-lan: port 3(wlan1) entered disabled state
[ 64.568185] random: crng init done
[ 64.571781] random: 6 urandom warning(s) missed due to ratelimiting
[ 65.911965] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
[ 65.918953] br-lan: port 3(wlan1) entered blocking state
[ 65.924591] br-lan: port 3(wlan1) entered forwarding state
[ 66.185494] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 66.192571] br-lan: port 2(wlan0) entered blocking state
[ 66.198246] br-lan: port 2(wlan0) entered forwarding state
[ 70.353900] jffs2_scan_eraseblock(): End of filesystem marker found at 0x0
[ 70.446720] jffs2_build_filesystem(): unlocking the mtd device...
[ 70.472843] done.
[ 70.474878] jffs2_build_filesystem(): erasing all blocks after the end marker...
[ 85.278397] done.
[ 85.280471] jffs2: notice: (3965) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
[ 88.554668] device wlan1 left promiscuous mode
[ 88.559589] br-lan: port 3(wlan1) entered disabled state
[ 88.570504] device wlan0 left promiscuous mode
[ 88.575306] br-lan: port 2(wlan0) entered disabled state
[ 90.203678] IPv6: ADDRCONF(NETDEV_UP): wlan1: link is not ready
[ 90.307436] br-lan: port 2(wlan1) entered blocking state
[ 90.313099] br-lan: port 2(wlan1) entered disabled state
[ 90.319087] device wlan1 entered promiscuous mode
[ 90.324113] br-lan: port 2(wlan1) entered blocking state
[ 90.329751] br-lan: port 2(wlan1) entered forwarding state
[ 91.770323] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 91.778389] br-lan: port 2(wlan1) entered disabled state
[ 91.803488] br-lan: port 3(wlan0) entered blocking state
[ 91.809149] br-lan: port 3(wlan0) entered disabled state
[ 91.815142] device wlan0 entered promiscuous mode
[ 92.356842] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
[ 92.363781] br-lan: port 2(wlan1) entered blocking state
[ 92.369427] br-lan: port 2(wlan1) entered forwarding state
[ 92.872892] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 92.879834] br-lan: port 3(wlan0) entered blocking state
[ 92.885449] br-lan: port 3(wlan0) entered forwarding state
[ 125.744586] nf_conntrack: default automatic helper assignment has been turned off for security reasons and CT-based firewall rule not found. Use the iptables CT target to attach helpers instead.
[ 207.081657] eth0: link up (100Mbps/Full duplex)
[ 207.086784] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
