Kernel Log
Kernel Log
[ 0.000000] Linux version 4.4.92 (kyson@gl-inet) (gcc version 5.4.0 (LEDE GCC 5.4.0 r3560-79f57e422d) ) #0 Tue Oct 17 17:46:20 2017
[ 0.000000] Board has DDR2
[ 0.000000] Analog PMU set to hw control
[ 0.000000] Digital PMU set to hw control
[ 0.000000] SoC Type: MediaTek MT7620A ver:2 eco:6
[ 0.000000] bootconsole [early0] enabled
[ 0.000000] CPU0 revision is: 00019650 (MIPS 24KEc)
[ 0.000000] MIPS: machine is GL-MT300A
[ 0.000000] Determined physical RAM map:
[ 0.000000] memory: 08000000 @ 00000000 (usable)
[ 0.000000] Initrd not found or empty - disabling initrd
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x0000000000000000-0x0000000007ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x0000000007ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x0000000007ffffff]
[ 0.000000] On node 0 totalpages: 32768
[ 0.000000] free_area_init_node: node 0, pgdat 803bc4b0, node_mem_map 81000000
[ 0.000000] Normal zone: 256 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 32768 pages, LIFO batch:7
[ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
[ 0.000000] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=132768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
[ 0.000000] Kernel command line: console=ttyS0,115200 rootfstype=squashfs,jffs2
[ 0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Writing ErrCtl register=0007e004
[ 0.000000] Readback ErrCtl register=0007e004
[ 0.000000] Memory: 125540K/131072K available (3059K kernel code, 145K rwdata, 728K rodata, 156K init, 208K bss, 5532K reserved, 0K cma-reserved)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS:256
[ 0.000000] CPU Clock: 580MHz
[ 0.000000] clocksource: systick: mask: 0xffff max_cycles: 0xffff, max_idle_ns: 583261500 ns
[ 0.000000] systick: enable autosleep mode
[ 0.000000] systick: running - mult: 214748, shift: 32
[ 0.000000] clocksource: MIPS: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6590553264 ns
[ 0.000012] sched_clock: 32 bits at 290MHz, resolution 3ns, wraps every 7405115902ns
[ 0.007577] Calibrating delay loop… 385.84 BogoMIPS (lpj=1929216)
[ 0.070063] pid_max: default: 32768 minimum: 301
[ 0.074696] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.081067] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.094739] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.104293] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.110354] pinctrl core: initialized pinctrl subsystem
[ 0.116776] NET: Registered protocol family 16
[ 0.140876] rt2880_gpio 10000600.gpio: registering 24 gpios
[ 0.146326] rt2880_gpio 10000600.gpio: registering 24 irq handlers
[ 0.152476] rt2880_gpio 10000638.gpio: registering 16 gpios
[ 0.157878] rt2880_gpio 10000638.gpio: registering 16 irq handlers
[ 0.164001] rt2880_gpio 10000660.gpio: registering 32 gpios
[ 0.169403] rt2880_gpio 10000660.gpio: registering 32 irq handlers
[ 0.175523] rt2880_gpio 10000688.gpio: registering 1 gpios
[ 0.180834] rt2880_gpio 10000688.gpio: registering 1 irq handlers
[ 0.188494] clocksource: Switched to clocksource systick
[ 0.195181] NET: Registered protocol family 2
[ 0.200449] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.207174] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.213401] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.219632] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.225258] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.231699] NET: Registered protocol family 1
[ 0.235917] PCI: CLS 0 bytes, default 32
[ 0.240453] rt-timer 10000100.timer: maximum frequency is 1220Hz
[ 0.247257] Crashlog allocated RAM at address 0x3f00000
[ 0.269227] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.274849] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.287286] io scheduler noop registered
[ 0.291098] io scheduler deadline registered (default)
[ 0.296276] ralink-usb-phy usbphy: invalid resource
[ 0.301638] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[ 0.311452] console [ttyS0] disabled
[ 0.314900] 10000c00.uartlite: ttyS0 at MMIO 0x10000c00 (irq = 20, base_baud = 2500000) is a Palmchip BK-3103
[ 0.324573] console [ttyS0] enabled
[ 0.331608] bootconsole [early0] disabled
[ 0.346486] spi spi0.0: force spi mode3
[ 0.351007] m25p80 spi0.0: w25q128 (16384 Kbytes)
[ 0.355852] 5 ofpart partitions found on MTD device spi0.0
[ 0.361495] Creating 5 MTD partitions on “spi0.0”:
[ 0.366394] 0x000000000000-0x000000030000 : “u-boot”
[ 0.373305] 0x000000030000-0x000000040000 : “u-boot-env”
[ 0.380666] 0x000000040000-0x000000050000 : “factory”
[ 0.387620] 0x000000050000-0x000000fd0000 : “firmware”
[ 1.700711] 2 uimage-fw partitions found on MTD device firmware
[ 1.706776] 0x000000050000-0x000000192da9 : “kernel”
[ 1.713480] 0x000000192da9-0x000000fd0000 : “rootfs”
[ 1.720451] mtd: device 5 (rootfs) set to be root filesystem
[ 1.726378] 1 squashfs-split partitions found on MTD device rootfs
[ 1.732760] 0x0000009c4000-0x000000fd0000 : “rootfs_data”
[ 1.740185] 0x000000ff0000-0x000001000000 : “art”
[ 1.747909] rt2880-pinmux pinctrl: pin io40 already requested by pinctrl; cannot claim for 10100000.ethernet
[ 1.758029] rt2880-pinmux pinctrl: pin-40 (10100000.ethernet) status -22
[ 1.764889] rt2880-pinmux pinctrl: could not request pin 40 (io40) from group ephy on device rt2880-pinmux
[ 1.774845] mtk_soc_eth 10100000.ethernet: Error applying setting, reverse things back
[ 1.785760] gsw: setting port4 to ephy mode
[ 1.790115] mtk_soc_eth 10100000.ethernet eth0 (uninitialized): port 1 link up (100Mbps/Full duplex)
[ 1.799651] mtk_soc_eth 10100000.ethernet: loaded mt7620 driver
[ 1.806502] mtk_soc_eth 10100000.ethernet eth0: mediatek frame engine at 0xb0100000, irq 5
[ 1.815727] rt2880_wdt 10000120.watchdog: Initialized
[ 1.822554] NET: Registered protocol family 10
[ 1.830803] NET: Registered protocol family 17
[ 1.835439] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 1.848381] 8021q: 802.1Q VLAN Support v1.8
[ 1.854381] hctosys: unable to open rtc device (rtc0)
[ 1.873211] VFS: Mounted root (squashfs filesystem) readonly on device 31:5.
[ 1.881333] Freeing unused kernel memory: 156K
[ 4.325016] init: Console is alive
[ 4.328808] init: - watchdog -
[ 8.849424] kmodloader: loading kernel modules from /etc/modules-boot.d/
[ 8.947086] usbcore: registered new interface driver usbfs
[ 8.952856] usbcore: registered new interface driver hub
[ 8.958398] usbcore: registered new device driver usb
[ 8.970215] exFAT: Version 1.2.9
[ 9.013983] SCSI subsystem initialized
[ 9.025130] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 9.033856] ehci-platform: EHCI generic platform driver
[ 9.049633] phy phy-usbphy.0: remote usb device wakeup disabled
[ 9.055680] phy phy-usbphy.0: UTMI 16bit 30MHz
[ 9.060266] ehci-platform 101c0000.ehci: EHCI Host Controller
[ 9.066163] ehci-platform 101c0000.ehci: new USB bus registered, assigned bus number 1
[ 9.074381] ehci-platform 101c0000.ehci: irq 26, io mem 0x101c0000
[ 9.086959] ehci-platform 101c0000.ehci: USB 2.0 started, EHCI 1.00
[ 9.094512] hub 1-0:1.0: USB hub found
[ 9.098768] hub 1-0:1.0: 1 port detected
[ 9.106454] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 9.114777] ohci-platform: OHCI generic platform driver
[ 9.120479] ohci-platform 101c1000.ohci: Generic Platform OHCI controller
[ 9.127495] ohci-platform 101c1000.ohci: new USB bus registered, assigned bus number 2
[ 9.135671] ohci-platform 101c1000.ohci: irq 26, io mem 0x101c1000
[ 9.165877] hub 2-0:1.0: USB hub found
[ 9.170157] hub 2-0:1.0: 1 port detected
[ 9.177275] uhci_hcd: USB Universal Host Controller Interface driver
[ 9.198028] MTK MSDC device init.
[ 9.215620] mtk-sd: MediaTek MT6575 MSDC Driver
[ 9.223888] sdhci: Secure Digital Host Controller Interface driver
[ 9.230267] sdhci: Copyright(c) Pierre Ossman
[ 9.238535] sdhci-pltfm: SDHCI platform and OF driver helper
[ 9.250460] usbcore: registered new interface driver usb-storage
[ 9.262473] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[ 9.274199] init: - preinit -
[ 9.533660] usb 1-1: new high-speed USB device number 2 using ehci-platform
[ 9.629940] mmc0: new high speed SDXC card at address 59b4
[ 9.643243] mmcblk0: mmc0:59b4 59.7 GiB
[ 9.696524] random: procd: uninitialized urandom read (4 bytes read, 17 bits of entropy available)
[ 9.705922] mmcblk0: p1
[ 10.043357] usb-storage 1-1:1.0: USB Mass Storage device detected
[ 10.059875] scsi host0: usb-storage 1-1:1.0
[ 10.854911] 8021q: adding VLAN 0 to HW filter on device eth0
[ 10.986778] scsi 0:0:0:0: Direct-Access SanDisk Ultra Fit 1.00 PQ: 0 ANSI: 6
[ 10.998040] sd 0:0:0:0: [sda] 60063744 512-byte logical blocks: (30.8 GB/28.6 GiB)
[ 11.006788] sd 0:0:0:0: [sda] Write Protect is off
[ 11.011700] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
[ 11.012323] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn’t support DPO or FUA
[ 11.031167] sda: sda1
[ 11.036928] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 13.037759] jffs2: notice: (433) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
[ 13.056886] mount_root: switching to jffs2 overlay
[ 13.079211] urandom-seed: Seeding with /etc/urandom.seed
[ 13.231850] procd: - early -
[ 13.234909] procd: - watchdog -
[ 14.080163] procd: - watchdog -
[ 14.083658] procd: - ubus -
[ 14.436323] random: ubusd: uninitialized urandom read (4 bytes read, 40 bits of entropy available)
[ 14.540490] random: ubusd: uninitialized urandom read (4 bytes read, 40 bits of entropy available)
[ 14.549829] random: ubusd: uninitialized urandom read (4 bytes read, 40 bits of entropy available)
[ 14.562619] random: ubusd: uninitialized urandom read (4 bytes read, 40 bits of entropy available)
[ 14.571915] random: ubusd: uninitialized urandom read (4 bytes read, 40 bits of entropy available)
[ 14.581294] random: ubusd: uninitialized urandom read (4 bytes read, 40 bits of entropy available)
[ 14.591274] random: ubusd: uninitialized urandom read (4 bytes read, 40 bits of entropy available)
[ 14.601287] procd: - init -
[ 15.672461] random: jshn: uninitialized urandom read (4 bytes read, 42 bits of entropy available)
[ 15.990598] kmodloader: loading kernel modules from /etc/modules.d/*
[ 16.055868] ntfs: driver 2.1.32 [Flags: R/O MODULE].
[ 16.075393] random: ubusd: uninitialized urandom read (4 bytes read, 43 bits of entropy available)
[ 16.121755] Initializing XFRM netlink socket
[ 16.148959] NET: Registered protocol family 15
[ 16.473256] tun: Universal TUN/TAP device driver, 1.6
[ 16.478493] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 16.580850] l2tp_core: L2TP core driver, V2.0
[ 16.608001] l2tp_netlink: L2TP netlink interface
[ 16.620843] gre: GRE over IPv4 demultiplexor driver
[ 16.635507] ip_gre: GRE over IPv4 tunneling driver
[ 16.672714] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 16.707419] Netfilter messages via NETLINK v0.30.
[ 16.743177] ip_set: protocol 6
[ 17.160541] Loading modules backported from Linux version wt-2017-01-31-0-ge882dff19e7f
[ 17.168789] Backport generated by backports.git backports-20160324-13-g24da7d3c
[ 17.417876] i2c /dev entries driver
[ 17.467163] Linux video capture interface: v2.00
[ 17.691753] u32 classifier
[ 17.694529] input device check on
[ 17.698325] Actions configured
[ 17.719366] Mirror/redirect action on
[ 17.843800] nf_conntrack version 0.5.0 (1964 buckets, 7856 max)
[ 17.886017] fuse init (API version 7.23)
[ 17.916295] usbcore: registered new interface driver cdc_acm
[ 17.922084] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 17.950528] usbcore: registered new interface driver cdc_wdm
[ 17.998887] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 18.019214] usbcore: registered new interface driver ipheth
[ 18.226994] usbcore: registered new interface driver usbserial
[ 18.233070] usbcore: registered new interface driver usbserial_generic
[ 18.239903] usbserial: USB Serial support registered for generic
[ 18.387646] xt_time: kernel timezone is -0000
[ 18.396555] usbcore: registered new interface driver cdc_ether
[ 18.421452] usbcore: registered new interface driver cdc_ncm
[ 18.447852] usbcore: registered new interface driver cp210x
[ 18.453664] usbserial: USB Serial support registered for cp210x
[ 18.474729] gspca_main: v2.14.0 registered
[ 18.496344] usbcore: registered new interface driver sonixb
[ 18.519599] usbcore: registered new interface driver sonixj
[ 18.540358] usbcore: registered new interface driver gspca_zc3xx
[ 18.553834] usbcore: registered new interface driver huawei_cdc_ncm
[ 18.622197] PPP generic driver version 2.4.2
[ 18.643620] PPP MPPE Compression module registered
[ 18.655141] NET: Registered protocol family 24
[ 18.668063] PPTP driver version 0.8.5
[ 18.690362] usbcore: registered new interface driver qmi_wwan
[ 18.706403] usbcore: registered new interface driver rndis_host
[ 18.784749] rt2800_wmac 10180000.wmac: loaded eeprom from mtd device “factory”
[ 18.792223] ieee80211 phy0: rt2x00_set_rt: Info - RT chipset 6352, rev 0500 detected
[ 18.800151] ieee80211 phy0: rt2x00_set_rf: Info - RF chipset 7620 detected
[ 18.807889] ieee80211 phy0: Selected rate control algorithm ‘minstrel_ht’
[ 18.850682] usbcore: registered new interface driver sierra
[ 18.856567] usbserial: USB Serial support registered for Sierra USB modem
[ 18.889621] usbcore: registered new interface driver sierra_net
[ 18.930088] usbcore: registered new interface driver uvcvideo
[ 18.935964] USB Video Class driver (1.1.1)
[ 18.972828] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 18.988774] usbcore: registered new interface driver option
[ 18.994592] usbserial: USB Serial support registered for GSM modem (1-port)
[ 19.030631] kmodloader: done loading kernel modules from /etc/modules.d/*
[ 32.053715] 8021q: adding VLAN 0 to HW filter on device eth0
[ 32.073600] device eth0.1 entered promiscuous mode
[ 32.078773] device eth0 entered promiscuous mode
[ 32.107415] br-lan: port 1(eth0.1) entered forwarding state
[ 32.113150] br-lan: port 1(eth0.1) entered forwarding state
[ 33.954353] FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 34.106287] br-lan: port 1(eth0.1) entered forwarding state
[ 35.706310] random: nonblocking pool is initialized
[ 38.054131] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 38.076999] device wlan0 entered promiscuous mode
[ 41.007724] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 41.014474] br-lan: port 2(wlan0) entered forwarding state
[ 41.020138] br-lan: port 2(wlan0) entered forwarding state
[ 43.012015] br-lan: port 2(wlan0) entered forwarding state
[ 45.956953] EXT4-fs (mmcblk0p1): recovery complete
[ 45.964657] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 50.678218] mmcblk0: error -145 transferring data, sector 125302528, nr 8, cmd response 0x900, card status 0xb00
[ 50.713460] mmc0: tried to reset card
