I have an MT300A that I want to connect my USB printer, Xerox Workcentre 6015, in order to turn it into a network printer.
The MT300A is stock except from the official updates:
Firmware 2.20
Openwrt release 15.05 Chaos Calmer
Linux kernel 3.18.27-1-04314c31bed8f992ea845699355da566
I found the following guide which seems to indicate that you can install p910nd and kmod-usb-printer which would allow you to access the printer from the MT300A over an USB connection:
The MT300A allows me to install the following:
p910nd 0.97-4
kmod-usb-printer 3.18.27-1
However I get the following errors when trying to install the kmod-usb-printer:
root@GL-MT300A:~# opkg update
and…
root@GL-MT300A:~# opkg install p910nd kmod-usb-printer
Package p910nd (0.97-4) installed in root is up to date.
Package kmod-usb-printer (3.18.27-1) installed in root is up to date.
Configuring kmod-usb-printer.
usblp is already loaded
Configuring p910nd.
Collected errors:
pkg_run_script: package “kmod-usb-printer” postinst script returned status 255.
opkg_configure: kmod-usb-printer.postinst returned 255.
root@GL-MT300A:~#
Have any of you had any luck connecting a USB printer to an MT300A or similar device?
Cheers!
