I purchased the MT330N just so I can use the USB to Ethernet. The unit drops the connection to the Mobley all the time. If I reboot the router, the connection is there and it works for about 5 mins and then it no longer shows as connected.
If I go into SETTING and click on 3G/4G it sees the AT&T and setting are all listed.
I have set the Mobley to never to turn off.
Is this a known issue? What settings do I need to it will not close the USB connection?
Please help as this is the only reason I got this and was glad it worked out of the box. But not glad it just stops the USB connection.
Sometimes I can just watch it connect and disconnect from the Mobley over and over.
Thank you.
(PLEASE REMOVE FIRST IMAGE!!! I CAN NOT SEE ANY WAY TO DO SO. WHICH YOU SHOULD BE ABLE TO DO!)
I do not understand what you mean. Are you saying NOT to use the USB connection? That is the entire reason I purchased this as it says it will do it and even had the settings for the AT&T service.
@alzhao - Thank you…Are you referring to the router or the Mobley device? I am assuming the router seeing that is what you support here. I know it is running off a a 5V USB charger, but I have not read anywhere that it requires 2A as the specs read 1A.
It has been running all night without issue in Wi-Fi WISP mode. It is connected to my home router via Wi-Fi and the Ethernet to a machine. No issue. does the USB data connection require more power than WISP? Seems strange.
