I have updated my MT300N-V2 to the latest firmware (3.102) and have updated the software packages but the only Zerotier package available is 2 years and 6 versions old (1.2.8-2). The current version is 1.4.6 and there are significant improvements since the 1.2 version.
I see on the openwrt package list that version 1.4.6 is available. Is there a way to install the most recent Zerotier version?
You can upgrade your plugin with the following commands.
opkg update
opkg upgrade zerotier
Thanks for the help.
I did the above but after installing and update/upgrade, opkg list-installed shows that I am still running Zerotier version 1.2.8-2. I guess that is becuase it’s pulling the package from the Gl.inet repository and not the openwrt repository. Is there a way to install the zerotier package from the openwrt repository?
I downloaded the updated zerotier package to the tmp folder on the router and tried installing but get:
Upgrading zerotier on root from 1.2.8-2 to 1.4.6-1…
Collected errors:
- satisfy_dependencies_for: Cannot satisfy the following dependencies for zerotier:
libstdcpp6
- opkg_install_cmd: Cannot install package zerotier.
root@GL-MT300N-V2:/tmp# opkg install libstdcpp6
Unknown package ‘libstdcpp6’.
Collected errors:
- opkg_install_cmd: Cannot install package libstdcpp6.
You can set the software source in advanced settings.
