I bought this device because it can store more than one SSID/AP as a connection. I was hoping that it would automatically switch to an active AP when another one disappears but it isn’t doing that. Here’s what I set up.
set up one connection in repeater WISP mode to my home’s wifi network. It connects fine and I can see the internet.
-I set up another connection in repeater WISP mode to my cell phone’s hotspot. It connects fine and I can see the internet.
-I then disabled my phone’s hotspot. The MT300N-V2 just sat there with no connection. Even after rebooting it will not make a connection to the home wifi.
I am going to connect the MT300N-V2 to a device that is not a computer (ham radio gateway device). I won’t be able to select saved access points with that device.
Does this product not work to automatically connect to another AP when the one it was connected do goes away?
I reflashed with FW 2.26 and have the same problem. My unit will not automatically connect to another saved access point when the current one is no longer present.
My problems are solved - I just received the regular Mango, non-V2, and it works fine. No issues connecting with another AP when the current one goes away. Also menus are working correctly as is the advanced menu for wireless.
I’m disappointed with the -V2 and lack of testing done before it was released.
