Hi everyone,
I’ve finally purchased an MT300Nv2 to replace my MT300A (which has magically gone missing for whatever reason.
I use an RFC4213 service through Hurricane Electric, as we have no native IPv6 available, and I do handle quite a bit of European technical support.
After configuring this tunnel to work like every other OpenWRT tunnel I’ve had, I see it is only binding IPv6 to the disabled public interface, and not passthrough onto my LAN.
network.wan6=interface
network.wan6.proto='6in4'
network.wan6.peeraddr='66.220.7.82'
network.wan6.ip6prefix='2001:x:1f19:6ae::/64'
network.wan6.tunnelid='x'
network.wan6.username='xx'
network.wan6.password='xx'
network.wan6.ip6addr='2001:x:1f18:6ae::2/64'
network.wan6.mtu='1480'
IPv6 works from router:
root@MT300N-V2:~# ping ipv6.google.com
PING ipv6.google.com (2607:f8b0:400f:806::200e): 56 data bytes
64 bytes from 2607:f8b0:400f:806::200e: seq=0 ttl=52 time=94.455 ms
64 bytes from 2607:f8b0:400f:806::200e: seq=1 ttl=52 time=92.980 ms
64 bytes from 2607:f8b0:400f:806::200e: seq=2 ttl=52 time=93.422 ms
64 bytes from 2607:f8b0:400f:806::200e: seq=3 ttl=52 time=92.957 ms
It appears to be assigning my routed subnet to the disabled guest subnetwork only (ifstats wan6)
"ipv6-prefix": [
"address": "2001:470:1f19:6ae::",
"mask": 64,
"class": "wan6",
"assigned": {
"guest": {
"mask": 64
I want the router to vend my /64 as normal to any clients which will accept it natively, and for whatever reason, this is the first I’ve had which is behaving like this.
As a but I just noticed- my non-public WiFi interface works, but claims it’s not associated.
SSID: GL-MT300N-V2-673
Mode: Master
Wireless is not associated
GL-MT300N-V2-673-Guest
Mode: Master
Wireless is disabled
