I'm trying to setup SS/SSR services on the Mango. I've logged in via Luci and tried to setup the services as per the instructions but when I check status
Running Status
Global Client Running
Global SSR Server - Not Running
UDP Relay Running
SOCKS5 Proxy Running
DNS Tunnel Running
Global Client not running and there is no "google connectivity".
Any suggestions on how to solve this would be appreciated.
Thanks
N.
Yes it does:
PING openwrt.org (139.59.209.225): 56 data bytes
64 bytes from 139.59.209.225: seq=0 ttl=52 time=216.338 ms
64 bytes from 139.59.209.225: seq=1 ttl=52 time=216.250 ms
64 bytes from 139.59.209.225: seq=2 ttl=52 time=216.768 ms
64 bytes from 139.59.209.225: seq=3 ttl=52 time=215.634 ms
64 bytes from 139.59.209.225: seq=4 ttl=52 time=215.413 ms
— openwrt.org ping statistics —
5 packets transmitted, 5 packets received, 0% packet loss
round-trip min/avg/max = 215.413/216.080/216.768 ms
I finally got it to work. I knew it was a server setting issue so I restored to factory firmware and started the whole process again. Added 1 SSR server and began the process of trial and error, systematically going through each setting switching it on/off and testing connectivity. What I found was that Global Setting > Operating mode needs to be set to IP Routing and in SSR Server > Server Setup TCP Fast open needs to be unchecked.
