MT300N-v2 USB Port Control ( deactivate/shutdown)
i´m use a MT300N-v2 (Version 3.102) and a Wildlife Cam.
If i connect the Cam via USB on the MT300N the Cam switch into the msdc mode (Mass Storage Mode) and i can copy the files (Pics/Vids). So far so good.
Unfortunately I will use the cam remote.
If the USB is connectet and the msdc mode is active the cam don´t work as cam.
Surveillance, record photo and Vids is not possible.
Now my question, is it possible to deactivate/shutdown the MT300N-v2 USB Port ?
The hub-ctrl -h 0 -P 1 -p 0 solution don´t work.
Thx
Ron
The USB port has a GPIO to control its power.
Check this post
OK , thx
/sys/class/gpio/usb/value
is the GPIO of the 3.102.
I try it later
it works !!!
on
echo “1”> /sys/class/gpio/usb/value
off
echo “0”> /sys/class/gpio/usb/value
THX
Ron
