mt300n-v2 with Version: 2.271 does not retain the settings for its middle LED after reboot or VPN on/off - the settings for the middle LED swithch to WiFi interface. Please, advise
So is any other things normal? Only LED changed?
Can you fix this in luci → system → LED?
@kyson-lok pls verify this problem.
yes, POWER_LED and WIFI_LED retain its default settings. Only the middle LED when configured to indicate VPN status resets itself after VPN off/on or reboot. middle LED resets to WWAN and no interface is being selected.
If you are experience in CLI, you can ssh to router, Edit /etc/init.d/startvpn, delete those lines:
if [ "$switch_disabled" != "1" ]; then
uci set system.vpn='led'
uci set system.vpn.default='0'
uci set system.vpn.name='vpn'
uci set system.vpn.sysfs="$led"
uci set system.vpn.trigger='netdev'
uci set system.vpn.dev='tun0'
uci set system.vpn.mode='link tx rx'
uci commit system
fi
Configuring the middle LED in luci again.
works! tanks plot
PS: I so like this little toy!!
