I found this setup repeater bridge, but I would like to have a bridge without repeater, means I would like
connect 2 PC’s to both ports (wan/lan) and make a bridge via wifi to my (internet) router. The mt300n-v2 should not be a repeater, means it shouldn’t send the ssid and should not allow in connecting devices via wifi (except my internet router…).
For MT300N-V2, you need to set up WDS (actually not really WDS and it works with any AP). When setting up WDS, leave LAN IP blank. DO NOT use static IP.
You can turn off the AP of MT300N-V2.
By default, WAN and LAN doesn’t bridged. If you want to do this, need to set up in LUCI. Need to remove WAN and edit LAN’s physical interface to eth0.0 and eth0.1
I have a problem. Everything done acc. your description. Router is accessible via WLAN (and also with connected PC via LAN/WAN port). Router can check firmware, can download packages, but the connected pc has no internet connection if dhcp is enabled (checked the received gateway and dns, is the ip from my main router which is connected to internet). If I disable dhcp and enter everything manually, then I have a internet connection. So what is wrong? Main router has dhcp running…
It is normal if you use bridge mode. On bridge mode, it should be disabled dhcp server, so the pc will gain ip from upstream router(Your main router), in this case, mt300n-v2 act as repeater.
If I connect the pc to the mt300n and use static ip on the pc(!) I have internet connection, but when I get the ip (and gateway and dns) via DHCP on the pc(!) I have no internet connection on the pc. But everything looks the same on the pc connection (correct ip, gateway and dns received).
So what is wrong?
IPv4-Routentabelle
Aktive Routen:
Netzwerkziel Netzwerkmaske Gateway Schnittstelle Metrik
0.0.0.0 0.0.0.0 192.168.0.241 192.168.0.77 291
127.0.0.0 255.0.0.0 Auf Verbindung 127.0.0.1 331
127.0.0.1 255.255.255.255 Auf Verbindung 127.0.0.1 331
127.255.255.255 255.255.255.255 Auf Verbindung 127.0.0.1 331
192.168.0.0 255.255.255.0 Auf Verbindung 192.168.0.77 291
192.168.0.77 255.255.255.255 Auf Verbindung 192.168.0.77 291
192.168.0.255 255.255.255.255 Auf Verbindung 192.168.0.77 291
224.0.0.0 240.0.0.0 Auf Verbindung 127.0.0.1 331
224.0.0.0 240.0.0.0 Auf Verbindung 192.168.0.77 291
255.255.255.255 255.255.255.255 Auf Verbindung 127.0.0.1 331
255.255.255.255 255.255.255.255 Auf Verbindung 192.168.0.77 291
Ständige Routen:
Netzwerkadresse Netzmaske Gatewayadresse Metrik
0.0.0.0 0.0.0.0 192.168.0.241 Standard
Not working (with dhcp on pc):
IPv4-Routentabelle
Aktive Routen:
0.0.0.0 0.0.0.0 192.168.0.241 192.168.0.4 35
192.168.0.0 255.255.255.0 Auf Verbindung 192.168.0.4 291
192.168.0.4 255.255.255.255 Auf Verbindung 192.168.0.4 291
192.168.0.255 255.255.255.255 Auf Verbindung 192.168.0.4 291
224.0.0.0 240.0.0.0 Auf Verbindung 192.168.0.4 291
255.255.255.255 255.255.255.255 Auf Verbindung 192.168.0.4 291
Ständige Routen:
Keine
It works now, it was the DHCP of the router. But this was/is funny, because my main router has a wireless mac filter and dhcp has restriction for allow only known MAC addresses.
So there are two mac addresses which I have to add to the wireless filter E4:95:6E:43:E4:A7 which is the MAC printed on the label of the router, and this E6:95:6E:03:E4:A7 which is apcli0 and belongs to WWAN.
And when I add this two mac’s to the dhcp and give static ip’s, I can see this devices in the list (note the two E6:95:6E:03:E4:A7:
