Hi, guy’s.
I have multiple Mt300n-v2 routers and i want to put TOR firmware in one of them, but after i installed “lede-mt300n-v2-tor-2.2641.bin” firmware from default firmware administration panel, i can’t access admin panel anymore. Mostly it says “Connection reset”. I tried to access admin panel from WIFI, and with cable connection. Same thing. And yes, i unchecked “keep settings”, when i was installing firmware.
When i try connect internet directly to this TOR router, after long time waiting, i can access internet and it seems to be TOR network. So it seems router is working, but slow and without chance to access admin panel.
I also tried to install this firmware from uboot, and exactly same thing is happening. Also tried different OS when i was trying to access admin. It’s not my PC caching issue or something.
I would appreciate if i can get some hints how i can fix that things
Ok. I managed to login in admin panel, but tor is not connecting. It stucks on random number. There is small part of my logs. Maybe someone has seen something like this?
Wed May 9 19:47:30 2018 daemon.warn Tor[1845]: Problem bootstrapping. Stuck at 45%: Asking for relay descriptors. (Operation timed out; TIMEOUT; count 15; recommendation warn; host 496B007A9A2FDBAFC2DED063F48BB20677D28715 at 195.144.21.175:9001)
Wed May 9 19:47:30 2018 daemon.warn Tor[1845]: 14 connections have failed:
Wed May 9 19:47:30 2018 daemon.warn Tor[1845]: 13 connections died in state connect()ing with SSL state (No SSL object)
Wed May 9 19:47:30 2018 daemon.warn Tor[1845]: 1 connections died in state handshaking (TLS) with SSL state unknown state in HANDSHAKE
Wed May 9 19:47:55 2018 daemon.err uhttpd[1864]: cat: can’t open ‘/etc/domino/domino-release’: No such file or directory
Wed May 9 19:47:55 2018 daemon.err uhttpd[1864]: sh: update-file-available: not found
According to the docs Tor - GL.iNet Docs
You cannot connect to the admin panel when using Tor.
You cannot connect to Tor when using the admin panel.
Tor sometime stuck and seems the only way to recover is reboot.
