On my AR300M I can hit ~15Mbs down / 10 Mbs up. I tend to get better performance if one side is wired.
This is being used on a router running openvpn on my home network, not a commercial VPN service.
@RangerZ it’s only one side wireless (WAN has wired connection), although I didn’t see massive improvement with both sides wired perhaps because I tested at close range.
@LostDog 15mbps would be fantastic, I wonder if this is due to the increase of processing power with this device. What’s your regular connection speed without VPN?
I’m interested in finding out what the spec bump with the AR300M provides in terms of real-world speed.
There might be something wrong with my new router. I can only get 2.2Mbps with HMA OpenVPN on my MT300A. I get 18Mbps if I run the VPN from my PC. I really need to get the 7-10Mbps that others say they get for this to be useable.
Anyone have some advice for how to improve it. I looked at setting up a PPTP or L2TP interface through the advanced menu, but I couldn’t get them to connect.
