Hi, my wireless ISP requires WPA-EAP authentication. I can’t find where to set up the WISP router that way. Is it possible? To connect my Linux laptop to the wireless ISP I use the following wpa_supplicant.conf settings; how to enter equivalent settings to the mini routerconfiguration?
SSID=“MyISP”
Proto=RSN
key_mgmt=WPA-EAP
pairwise=CCMP
auth_alg=OPEN
eap=PEAP
identity=“MyId”
password=“MyPassword”
phase2=“auth=MSCHAPV2”
Hopefully the mini router software is capable enough for this. My Android 4.4 phone can. I’m totally new to this product. It’s factory new with firmware 2.26. Thanks in advance for any help.
