:mt300nv2
I bought this used mt300nv2 on eBay, when I insert power it only constantly blinking with 2 lights. And no wifi can be found. Please suggest what to do
Press and hold the reset button for 10 seconds to reset the firmware
doesnt work, tried million times.
Is any way to flash it trough usb? I dont have ethernet port in my notebook
You can buy a USB-RJ45 adapter, the uboot mode can only be accessed through a wired connection
If no luck, please contact your seller to get the replacement.
