Hey guys,
I just set up my Flint 2 and since I'm not a pro I would like to clarify if everything is working properly. The router is connected to a modem.
I managed to configure VPN via WireGuard which works fine. I had some trouble getting Adguard Home working but I think it's running but only if I activate "AdGuard Home Handle Client Requests" which interferes with the VPN, right?
I activated encryption, generated a certificate and private key, changed the port because the 443 isn't working and under "Upstream-DNS-Server" use the Quad9 and Cloudflare DNS-Servers for DNS-over-TLS and DNS-over-HTTPS.
What I don't understand is that I see three different IPs: in the Flint VPN settings, on an ip check website (nearly the same IP as in Flints VPN settings) and on dnsleaktest. But they all show the country to which my VPN is set to. The hostname shown by dnsleaktest is dns.adguard-dns.com.
Is everything alright? Do I have to change something? Let me know what infos you need to help me. Oh and the "Top queried domain" in AGH is (myiphone).local. Is this normal?
Edit: I now set the DNS-IP inside the WireGuard VPN details to the IP of AGH and set the VPNs IP als DNS-Upstream-Server in AGH and it seems to work a lot better now. Is this the way to go?
All the best!
