MT6000 (Flint2) goodcloud GUI connect gives 502 Bad Gateway
Hi Support Team,
I have a MT6000 (Flint2) router and since I conected it to the goodcloud I cannot access it via remote GUI - it gives me 502 Bad Gateway when using port 80. when I use port 8080 it sends me to the openwrt login page and it is working as expected but no way to get to the normal GUI... Same for Flint is working as a charm - have no idea what is wrong
please help
thank you
VA
Did you enable "Force HTTPS for GUI" by chance?
I don't see such an option in the GUI or in the goodcloud? but when change the port to 443 the response is that I am using https over plain connection or something like that...
can you please advise where to find it?
found it - my bad sorry - I did check force HTTPS in the:
System > Security > Force HTTPS = enable
so when this is checked and any other port than 80 is in there - it is not working...
It's a known bug, that this will cause Goodcloud to not work correctly.
Maybe @bruce can send it to R&D for further investigation or at least bringing up a warning then?
I have already submitted this point, and will improve the HTTPS via the rtty web.
Thank you.
