MT6000 - PPPOE connection
i need a bit of bug searching support. - I have configured my MT6000 behind a ONT Server & Followed the configuration provided at Testing to determine if you are a bot! for my provider Vodafone Germany.
->DS-Lite installed + VLAN on 7
The Configuration looks ok:
Blockquote Fri Jun 20 21:34:50 2025 daemon.notice netifd: Interface 'wan_6' is now up
Fri Jun 20 21:34:50 2025 daemon.info dnsmasq[29611]: reading /tmp/resolv.conf.d/resolv.conf.auto
Fri Jun 20 21:34:50 2025 daemon.info dnsmasq[29611]: using only locally-known addresses for domain test
Fri Jun 20 21:34:50 2025 daemon.info dnsmasq[29611]: using only locally-known addresses for domain onion
Fri Jun 20 21:34:50 2025 daemon.info dnsmasq[29611]: using only locally-known addresses for domain localhost
Fri Jun 20 21:34:50 2025 daemon.info dnsmasq[29611]: using only locally-known addresses for domain invalid
Fri Jun 20 21:34:50 2025 daemon.info dnsmasq[29611]: using only locally-known addresses for domain bind
Fri Jun 20 21:34:50 2025 daemon.info dnsmasq[29611]: using only locally-known addresses for domain lan
Fri Jun 20 21:34:50 2025 daemon.info dnsmasq[29611]: using nameserver 2a01:860::53#53
Fri Jun 20 21:34:50 2025 daemon.info dnsmasq[29611]: using nameserver 2a01:860::153#53
Fri Jun 20 21:34:50 2025 daemon.info dnsmasq[29611]: using nameserver 176.95.16.250#53
Fri Jun 20 21:34:50 2025 daemon.info dnsmasq[29611]: using nameserver 176.95.16.251#53
Fri Jun 20 21:34:50 2025 user.notice firewall: Reloading firewall due to ifup of wan_6 (pppoe-wan)
Fri Jun 20 21:34:51 2025 kern.debug kernel: [31611.471749] entrytb_aid_aquire(): found non-occupied aid:4, allocated from:4
Fri Jun 20 21:34:51 2025 kern.warn kernel: [31611.478812] 7986@C13L2,MacTableInsertEntry() 1577: New Sta:80:64:6f:63:79:3c
Fri Jun 20 21:34:51 2025 kern.notice kernel: [31611.490130] 7986@C08L3,ap_cmm_peer_assoc_req_action() 1714: Recv Assoc from STA - 80:64:6f:63:79:3c
Fri Jun 20 21:34:51 2025 kern.notice kernel: [31611.499465] 7986@C08L3,ap_cmm_peer_assoc_req_action() 2241: ASSOC Send ASSOC response (Status=0)...
Fri Jun 20 21:34:51 2025 kern.notice kernel: [31611.508533] 7986@C01L3,wifi_sys_conn_act() 1115: wdev idx = 0
Fri Jun 20 21:34:51 2025 kern.notice kernel: [31611.514532] 7986@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=0
Fri Jun 20 21:34:51 2025 kern.notice kernel: [31611.643890] 7986@C15L3,WPABuildPairMsg1() 5310: <=== send Msg1 of 4-way
Fri Jun 20 21:34:51 2025 daemon.warn odhcpd[28341]: A default route is present but there is no public prefix on lan thus we don't announce a default route!
Fri Jun 20 21:34:52 2025 kern.notice kernel: [31612.671911] 7986@C15L3,WPABuildPairMsg1() 5310: <=== send Msg1 of 4-way
Fri Jun 20 21:34:53 2025 kern.notice kernel: [31613.695892] 7986@C15L3,WPABuildPairMsg1() 5310: <=== send Msg1 of 4-way
Fri Jun 20 21:34:54 2025 kern.err kernel: [31614.719437] 7986@C15L1,WpaEAPOLRetryAction() 7790: 4Way-MSG1 timeout with 80:64:6f:63:79:3c
Fri Jun 20 21:34:54 2025 kern.notice kernel: [31614.727794] 7986@C15L3,MlmeDeAuthAction() 1404: Send DEAUTH frame with ReasonCode(15) to 80:64:6f:63:79:3c
Fri Jun 20 21:34:54 2025 kern.warn kernel: [31614.737473] 7986@C01L2,wifi_sys_disconn_act() 1002: wdev_idx=0
Fri Jun 20 21:34:54 2025 kern.notice kernel: [31614.743655] 7986@C08L3,hw_ctrl_flow_v2_disconnt_act() 172: wdev_idx=0
Fri Jun 20 21:34:54 2025 kern.warn kernel: [31614.750650] 7986@C13L2,MacTableDeleteEntry() 1938: Del Sta:80:64:6f:63:79:3c
Fri Jun 20 21:35:00 2025 kern.debug kernel: [31620.295718] entrytb_aid_aquire(): found non-occupied aid:4, allocated from:4
Fri Jun 20 21:35:00 2025 kern.warn kernel: [31620.302780] 7986@C13L2,MacTableInsertEntry() 1577: New Sta:80:64:6f:63:79:3c
Fri Jun 20 21:35:04 2025 kern.notice kernel: [31624.699878] 7986@C08L3,ap_cmm_peer_assoc_req_action() 1714: Recv Assoc from STA - 80:64:6f:63:79:3c
Fri Jun 20 21:35:04 2025 kern.notice kernel: [31624.709139] 7986@C08L3,ap_cmm_peer_assoc_req_action() 2241: ASSOC Send ASSOC response (Status=0)...
Fri Jun 20 21:35:04 2025 kern.notice kernel: [31624.718211] 7986@C01L3,wifi_sys_conn_act() 1115: wdev idx = 0
Fri Jun 20 21:35:04 2025 kern.notice kernel: [31624.724197] 7986@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=0
Fri Jun 20 21:35:04 2025 kern.notice kernel: [31624.851812] 7986@C15L3,WPABuildPairMsg1() 5310: <=== send Msg1 of 4-way
Fri Jun 20 21:35:05 2025 kern.notice kernel: [31625.855822] 7986@C15L3,WPABuildPairMsg1() 5310: <=== send Msg1 of 4-way
Fri Jun 20 21:35:06 2025 kern.notice kernel: [31626.879817] 7986@C15L3,WPABuildPairMsg1() 5310: <=== send Msg1 of 4-way
Fri Jun 20 21:35:07 2025 kern.err kernel: [31627.903354] 7986@C15L1,WpaEAPOLRetryAction() 7790: 4Way-MSG1 timeout with 80:64:6f:63:79:3c
Fri Jun 20 21:35:07 2025 kern.notice kernel: [31627.911706] 7986@C15L3,MlmeDeAuthAction() 1404: Send DEAUTH frame with ReasonCode(15) to 80:64:6f:63:79:3c
Fri Jun 20 21:35:07 2025 kern.warn kernel: [31627.921389] 7986@C01L2,wifi_sys_disconn_act() 1002: wdev_idx=0
Fri Jun 20 21:35:07 2025 kern.notice kernel: [31627.927552] 7986@C08L3,hw_ctrl_flow_v2_disconnt_act() 172: wdev_idx=0
Fri Jun 20 21:35:07 2025 kern.warn kernel: [31627.934540] 7986@C13L2,MacTableDeleteEntry() 1938: Del Sta:80:64:6f:63:79:3c
Fri Jun 20 21:35:08 2025 kern.debug kernel: [31629.102124] entrytb_aid_aquire(): found non-occupied aid:4, allocated from:4
Fri Jun 20 21:35:08 2025 kern.warn kernel: [31629.109183] 7986@C13L2,MacTableInsertEntry() 1577: New Sta:80:64:6f:63:79:3c
Fri Jun 20 21:35:13 2025 kern.notice kernel: [31633.315344] 7986@C08L3,ap_cmm_peer_assoc_req_action() 1714: Recv Assoc from STA - 80:64:6f:63:79:3c
Fri Jun 20 21:35:13 2025 kern.notice kernel: [31633.324627] 7986@C08L3,ap_cmm_peer_assoc_req_action() 2241: ASSOC Send ASSOC response (Status=0)...
Fri Jun 20 21:35:13 2025 kern.notice kernel: [31633.333689] 7986@C01L3,wifi_sys_conn_act() 1115: wdev idx = 0
Fri Jun 20 21:35:13 2025 kern.notice kernel: [31633.339669] 7986@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=0
Fri Jun 20 21:35:13 2025 kern.notice kernel: [31633.467752] 7986@C15L3,WPABuildPairMsg1() 5310: <=== send Msg1 of 4-way
Fri Jun 20 21:35:14 2025 kern.notice kernel: [31634.495766] 7986@C15L3,WPABuildPairMsg1() 5310: <=== send Msg1 of 4-way
Fri Jun 20 21:35:15 2025 kern.notice kernel: [31635.519763] 7986@C15L3,WPABuildPairMsg1() 5310: <=== send Msg1 of 4-way
Fri Jun 20 21:35:16 2025 kern.err kernel: [31636.543301] 7986@C15L1,WpaEAPOLRetryAction() 7790: 4Way-MSG1 timeout with 80:64:6f:63:79:3c
Fri Jun 20 21:35:16 2025 kern.notice kernel: [31636.551655] 7986@C15L3,MlmeDeAuthAction() 1404: Send DEAUTH frame with ReasonCode(15) to 80:64:6f:63:79:3c
Fri Jun 20 21:35:16 2025 kern.warn kernel: [31636.561334] 7986@C01L2,wifi_sys_disconn_act() 1002: wdev_idx=0
Fri Jun 20 21:35:16 2025 kern.notice kernel: [31636.567494] 7986@C08L3,hw_ctrl_flow_v2_disconnt_act() 172: wdev_idx=0
Fri Jun 20 21:35:16 2025 kern.warn kernel: [31636.574487] 7986@C13L2,MacTableDeleteEntry() 1938: Del Sta:80:64:6f:63:79:3c
Fri Jun 20 21:35:17 2025 kern.debug kernel: [31637.711779] entrytb_aid_aquire(): found non-occupied aid:4, allocated from:4
Fri Jun 20 21:35:17 2025 kern.warn kernel: [31637.718840] 7986@C13L2,MacTableInsertEntry() 1577: New Sta:80:64:6f:63:79:3c
Fri Jun 20 21:35:17 2025 kern.notice kernel: [31637.768308] 7986@C08L3,ap_cmm_peer_assoc_req_action() 1714: Recv Assoc from STA - 80:64:6f:63:79:3c
Fri Jun 20 21:35:17 2025 kern.notice kernel: [31637.777509] 7986@C08L3,ap_cmm_peer_assoc_req_action() 2241: ASSOC Send ASSOC response (Status=0)...
Fri Jun 20 21:35:17 2025 kern.notice kernel: [31637.786575] 7986@C01L3,wifi_sys_conn_act() 1115: wdev idx = 0
Fri Jun 20 21:35:17 2025 kern.notice kernel: [31637.792579] 7986@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=0
Fri Jun 20 21:35:17 2025 kern.notice kernel: [31637.919727] 7986@C15L3,WPABuildPairMsg1() 5310: <=== send Msg1 of 4-way
Fri Jun 20 21:35:18 2025 kern.notice kernel: [31638.943743] 7986@C15L3,WPABuildPairMsg1() 5310: <=== send Msg1 of 4-way
Fri Jun 20 21:35:19 2025 kern.notice kernel: [31639.967733] 7986@C15L3,WPABuildPairMsg1() 5310: <=== send Msg1 of 4-way
Fri Jun 20 21:35:20 2025 kern.err kernel: [31640.991268] 7986@C15L1,WpaEAPOLRetryAction() 7790: 4Way-MSG1 timeout with 80:64:6f:63:79:3c
Fri Jun 20 21:35:20 2025 kern.notice kernel: [31640.999621] 7986@C15L3,MlmeDeAuthAction() 1404: Send DEAUTH frame with ReasonCode(15) to 80:64:6f:63:79:3c
Fri Jun 20 21:35:20 2025 kern.warn kernel: [31641.009301] 7986@C01L2,wifi_sys_disconn_act() 1002: wdev_idx=0
Fri Jun 20 21:35:20 2025 kern.notice kernel: [31641.015460] 7986@C08L3,hw_ctrl_flow_v2_disconnt_act() 172: wdev_idx=0
Fri Jun 20 21:35:20 2025 kern.warn kernel: [31641.022446] 7986@C13L2,MacTableDeleteEntry() 1938: Del Sta:80:64:6f:63:79:3c
Fri Jun 20 21:35:21 2025 kern.debug kernel: [31642.106898] entrytb_aid_aquire(): found non-occupied aid:4, allocated from:4
Fri Jun 20 21:35:21 2025 kern.warn kernel: [31642.113956] 7986@C13L2,MacTableInsertEntry() 1577: New Sta:80:64:6f:63:79:3c
Fri Jun 20 21:35:26 2025 kern.notice kernel: [31646.513062] 7986@C08L3,ap_cmm_peer_assoc_req_action() 1714: Recv Assoc from STA - 80:64:6f:63:79:3c
Fri Jun 20 21:35:26 2025 kern.notice kernel: [31646.522335] 7986@C08L3,ap_cmm_peer_assoc_req_action() 2241: ASSOC Send ASSOC response (Status=0)...
Fri Jun 20 21:35:26 2025 kern.notice kernel: [31646.531412] 7986@C01L3,wifi_sys_conn_act() 1115: wdev idx = 0
Fri Jun 20 21:35:26 2025 kern.notice kernel: [31646.537397] 7986@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=0
Fri Jun 20 21:35:26 2025 kern.notice kernel: [31646.667698] 7986@C15L3,WPABuildPairMsg1() 5310: <=== send Msg1 of 4-way
Fri Jun 20 21:35:27 2025 kern.notice kernel: [31647.679698] 7986@C15L3,WPABuildPairMsg1() 5310: <=== send Msg1 of 4-way
Fri Jun 20 21:35:28 2025 kern.notice kernel: [31648.703691] 7986@C15L3,WPABuildPairMsg1() 5310: <=== send Msg1 of 4-way
Fri Jun 20 21:35:29 2025 kern.err kernel: [31649.727227] 7986@C15L1,WpaEAPOLRetryAction() 7790: 4Way-MSG1 timeout with 80:64:6f:63:79:3c
Fri Jun 20 21:35:29 2025 kern.notice kernel: [31649.735590] 7986@C15L3,MlmeDeAuthAction() 1404: Send DEAUTH frame with ReasonCode(15) to 80:64:6f:63:79:3c
Fri Jun 20 21:35:29 2025 kern.warn kernel: [31649.745269] 7986@C01L2,wifi_sys_disconn_act() 1002: wdev_idx=0
Fri Jun 20 21:35:29 2025 kern.notice kernel: [31649.751425] 7986@C08L3,hw_ctrl_flow_v2_disconnt_act() 172: wdev_idx=0
Fri Jun 20 21:35:29 2025 kern.warn kernel: [31649.758408] 7986@C13L2,MacTableDeleteEntry() 1938: Del Sta:80:64:6f:63:79:3c
Fri Jun 20 21:35:30 2025 kern.debug kernel: [31650.810982] entrytb_aid_aquire(): found non-occupied aid:4, allocated from:4
Fri Jun 20 21:35:30 2025 kern.warn kernel: [31650.818042] 7986@C13L2,MacTableInsertEntry() 1577: New Sta:80:64:6f:63:79:3c
Fri Jun 20 21:35:34 2025 kern.notice kernel: [31655.112318] 7986@C08L3,ap_cmm_peer_assoc_req_action() 1714: Recv Assoc from STA - 80:64:6f:63:79:3c
Fri Jun 20 21:35:34 2025 kern.notice kernel: [31655.121602] 7986@C08L3,ap_cmm_peer_assoc_req_action() 2241: ASSOC Send ASSOC response (Status=0)...
Fri Jun 20 21:35:34 2025 kern.notice kernel: [31655.130664] 7986@C01L3,wifi_sys_conn_act() 1115: wdev idx = 0
Fri Jun 20 21:35:34 2025 kern.notice kernel: [31655.136647] 7986@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=0
Fri Jun 20 21:35:35 2025 kern.notice kernel: [31655.267609] 7986@C15L3,WPABuildPairMsg1() 5310: <=== send Msg1 of 4-way
Fri Jun 20 21:35:36 2025 kern.notice kernel: [31656.287630] 7986@C15L3,WPABuildPairMsg1() 5310: <=== send Msg1 of 4-way
Fri Jun 20 21:35:37 2025 kern.notice kernel: [31657.311622] 7986@C15L3,WPABuildPairMsg1() 5310: <=== send Msg1 of 4-way
Fri Jun 20 21:35:38 2025 kern.err kernel: [31658.335161] 7986@C15L1,WpaEAPOLRetryAction() 7790: 4Way-MSG1 timeout with 80:64:6f:63:79:3c
Fri Jun 20 21:35:38 2025 kern.notice kernel: [31658.343514] 7986@C15L3,MlmeDeAuthAction() 1404: Send DEAUTH frame with ReasonCode(15) to 80:64:6f:63:79:3c
Fri Jun 20 21:35:38 2025 kern.warn kernel: [31658.353193] 7986@C01L2,wifi_sys_disconn_act() 1002: wdev_idx=0
Fri Jun 20 21:35:38 2025 kern.notice kernel: [31658.359357] 7986@C08L3,hw_ctrl_flow_v2_disconnt_act() 172: wdev_idx=0
Fri Jun 20 21:35:38 2025 kern.warn kernel: [31658.366344] 7986@C13L2,MacTableDeleteEntry() 1938: Del Sta:80:64:6f:63:79:3c
Fri Jun 20 21:35:39 2025 kern.debug kernel: [31659.310175] entrytb_aid_aquire(): found non-occupied aid:4, allocated from:4
Fri Jun 20 21:35:39 2025 kern.warn kernel: [31659.317236] 7986@C13L2,MacTableInsertEntry() 1577: New Sta:80:64:6f:63:79:3c
Fri Jun 20 21:35:39 2025 kern.notice kernel: [31659.407384] 7986@C08L3,ap_cmm_peer_assoc_req_action() 1714: Recv Assoc from STA - 80:64:6f:63:79:3c
Fri Jun 20 21:35:39 2025 kern.notice kernel: [31659.416682] 7986@C08L3,ap_cmm_peer_assoc_req_action() 2241: ASSOC Send ASSOC response (Status=0)...
Fri Jun 20 21:35:39 2025 kern.notice kernel: [31659.425771] 7986@C01L3,wifi_sys_conn_act() 1115: wdev idx = 0
Fri Jun 20 21:35:39 2025 kern.notice kernel: [31659.431770] 7986@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=0
Fri Jun 20 21:35:39 2025 kern.notice kernel: [31659.559583] 7986@C15L3,WPABuildPairMsg1() 5310: <=== send Msg1 of 4-way
Fri Jun 20 21:35:40 2025 kern.notice kernel: [31660.575604] 7986@C15L3,WPABuildPairMsg1() 5310: <=== send Msg1 of 4-way
Fri Jun 20 21:35:41 2025 kern.notice kernel: [31661.599592] 7986@C15L3,WPABuildPairMsg1() 5310: <=== send Msg1 of 4-way
Fri Jun 20 21:35:42 2025 kern.err kernel: [31662.623131] 7986@C15L1,WpaEAPOLRetryAction() 7790: 4Way-MSG1 timeout with 80:64:6f:63:79:3c
Fri Jun 20 21:35:42 2025 kern.notice kernel: [31662.631482] 7986@C15L3,MlmeDeAuthAction() 1404: Send DEAUTH frame with ReasonCode(15) to 80:64:6f:63:79:3c
Fri Jun 20 21:35:42 2025 kern.warn kernel: [31662.641165] 7986@C01L2,wifi_sys_disconn_act() 1002: wdev_idx=0
Fri Jun 20 21:35:42 2025 kern.notice kernel: [31662.647319] 7986@C08L3,hw_ctrl_flow_v2_disconnt_act() 172: wdev_idx=0
Fri Jun 20 21:35:42 2025 kern.warn kernel: [31662.654311] 7986@C13L2,MacTableDeleteEntry() 1938: Del Sta:80:64:6f:63:79:3c
Fri Jun 20 21:35:43 2025 kern.debug kernel: [31663.704187] entrytb_aid_aquire(): found non-occupied aid:4, allocated from:4
Fri Jun 20 21:35:43 2025 kern.warn kernel: [31663.711247] 7986@C13L2,MacTableInsertEntry() 1577: New Sta:80:64:6f:63:79:3c
Fri Jun 20 21:35:47 2025 kern.notice kernel: [31667.912283] 7986@C08L3,ap_cmm_peer_assoc_req_action() 1714: Recv Assoc from STA - 80:64:6f:63:79:3c
Fri Jun 20 21:35:47 2025 kern.notice kernel: [31667.921572] 7986@C08L3,ap_cmm_peer_assoc_req_action() 2241: ASSOC Send ASSOC response (Status=0)...
Fri Jun 20 21:35:47 2025 kern.notice kernel: [31667.930634] 7986@C01L3,wifi_sys_conn_act() 1115: wdev idx = 0
Fri Jun 20 21:35:47 2025 kern.notice kernel: [31667.936638] 7986@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=0
Fri Jun 20 21:35:47 2025 kern.notice kernel: [31668.071576] 7986@C15L3,WPABuildPairMsg1() 5310: <=== send Msg1 of 4-way
Fri Jun 20 21:35:48 2025 kern.notice kernel: [31669.087529] 7986@C15L3,WPABuildPairMsg1() 5310: <=== send Msg1 of 4-way
Fri Jun 20 21:35:49 2025 kern.notice kernel: [31670.111605] 7986@C15L3,WPABuildPairMsg1() 5310: <=== send Msg1 of 4-way
Fri Jun 20 21:35:50 2025 kern.err kernel: [31671.135072] 7986@C15L1,WpaEAPOLRetryAction() 7790: 4Way-MSG1 timeout with 80:64:6f:63:79:3c
Fri Jun 20 21:35:50 2025 kern.notice kernel: [31671.143481] 7986@C15L3,MlmeDeAuthAction() 1404: Send DEAUTH frame with ReasonCode(15) to 80:64:6f:63:79:3c
Fri Jun 20 21:35:50 2025 kern.warn kernel: [31671.153163] 7986@C01L2,wifi_sys_disconn_act() 1002: wdev_idx=0
Fri Jun 20 21:35:51 2025 kern.notice kernel: [31671.159322] 7986@C08L3,hw_ctrl_flow_v2_disconnt_act() 172: wdev_idx=0
Fri Jun 20 21:35:51 2025 kern.warn kernel: [31671.166328] 7986@C13L2,MacTableDeleteEntry() 1938: Del Sta:80:64:6f:63:79:3c
Fri Jun 20 21:35:52 2025 kern.debug kernel: [31672.212428] entrytb_aid_aquire(): found non-occupied aid:4, allocated from:4
Fri Jun 20 21:35:52 2025 kern.warn kernel: [31672.219487] 7986@C13L2,MacTableInsertEntry() 1577: New Sta:80:64:6f:63:79:3c
Fri Jun 20 21:36:30 2025 kern.warn kernel: [31710.587089] 7986@C01L2,wifi_sys_disconn_act() 1002: wdev_idx=0
Fri Jun 20 21:36:30 2025 kern.warn kernel: [31710.593297] 7986@C13L2,MacTableDeleteEntry() 1938: Del Sta:80:64:6f:63:79:3c
Fri Jun 20 21:36:30 2025 kern.debug kernel: [31710.613997] entrytb_aid_aquire(): found non-occupied aid:4, allocated from:4
Fri Jun 20 21:36:30 2025 kern.warn kernel: [31710.621053] 7986@C13L2,MacTableInsertEntry() 1577: New Sta:80:64:6f:63:79:3c
Fri Jun 20 21:36:56 2025 kern.warn kernel: [31736.586797] 7986@C01L2,wifi_sys_disconn_act() 1002: wdev_idx=0
Fri Jun 20 21:36:56 2025 kern.warn kernel: [31736.592966] 7986@C13L2,MacTableDeleteEntry() 1938: Del Sta:80:64:6f:63:79:3c
Fri Jun 20 21:41:34 2025 daemon.warn odhcpd[28341]: A default route is present but there is no public prefix on lan thus we don't announce a default route!
Fri Jun 20 21:47:07 2025 kern.debug kernel: [32347.729005] entrytb_aid_aquire(): found non-occupied aid:4, allocated from:4
Fri Jun 20 21:47:07 2025 kern.warn kernel: [32347.736065] 7986@C13L2,MacTableInsertEntry() 1577: New Sta:b0:dc:ef:e8:25:38
Fri Jun 20 21:47:07 2025 kern.notice kernel: [32347.764467] 7986@C08L3,ap_cmm_peer_assoc_req_action() 1714: Recv Assoc from STA - b0:dc:ef:e8:25:38
Fri Jun 20 21:47:07 2025 kern.notice kernel: [32347.773761] 7986@C08L3,ap_cmm_peer_assoc_req_action() 2241: ReASSOC Send ReASSOC response (Status=0)...
Fri Jun 20 21:47:07 2025 kern.notice kernel: [32347.783188] 7986@C01L3,wifi_sys_conn_act() 1115: wdev idx = 0
Fri Jun 20 21:47:07 2025 kern.notice kernel: [32347.789185] 7986@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=0
Fri Jun 20 21:47:07 2025 kern.notice kernel: [32347.919147] 7986@C15L3,WPABuildPairMsg1() 5310: <=== send Msg1 of 4-way
Fri Jun 20 21:47:07 2025 kern.notice kernel: [32347.925759] 7986@C15L3,PeerPairMsg2Action() 6303: ===>Receive msg 2
Fri Jun 20 21:47:07 2025 kern.notice kernel: [32347.932343] 7986@C15L3,WPABuildPairMsg3() 5595: <=== send Msg3 of 4-way
Fri Jun 20 21:47:07 2025 kern.notice kernel: [32347.938952] 7986@C15L3,PeerPairMsg4Action() 6734: ===>Receive msg 4
Fri Jun 20 21:47:07 2025 kern.warn kernel: [32347.950395] 7986@C15L2,PeerPairMsg4Action() 7098: AP SETKEYS DONE(ra0) - AKMMap=WPA2PSK, PairwiseCipher=AES, GroupCipher=AES, wcid=1 from b0:dc:ef:e8:25:38
Fri Jun 20 21:47:08 2025 daemon.warn odhcpd[28341]: A default route is present but there is no public prefix on lan thus we don't announce a default route!
Fri Jun 20 21:47:08 2025 daemon.info dnsmasq-dhcp[29611]: DHCPREQUEST(br-lan) 192.168.8.144 b0:dc:ef:e8:25:38
Fri Jun 20 21:47:08 2025 daemon.info dnsmasq-dhcp[29611]: DHCPACK(br-lan) 192.168.8.144 b0:dc:ef:e8:25:38 NB-NE01
Fri Jun 20 21:47:09 2025 daemon.warn odhcpd[28341]: A default route is present but there is no public prefix on lan thus we don't announce a default route!
Fri Jun 20 21:47:10 2025 daemon.warn odhcpd[28341]: A default route is present but there is no public prefix on lan thus we don't announce a default route!
Fri Jun 20 21:47:48 2025 user.info : luci: accepted login on / for root from 192.168.8.144
Anyhow once I connect to the router i keep getting a redirect to a vodafone error page of doom:
DSL-Benutzername / Passwort falsch! (Fehler 691)
I tripple checked + my wife did so too... so it can't be a typo...
Any advice before i throw this bad boy over the fence?
BEst,
Norbert
Hey Norbert,
Du brauchst normalerweise nicht in luci aktiv werden. Nutz einfach die Übersicht im normalen GL Interface und stell dort den WAN-Port auf PPPoE um. Im Normalfall ist ein ONT aber kein DS-Lite und braucht ggf. ein anderes VLAN. Die Info würde Dir Vodafone dann normalerweise bereitstellen.
Manchmal scheint es wohl VLAN 132 zu sein, siehe Glasfaser, eigener Router, Grundeinstellungen, VLA... - Vodafone Community
Grüße
Admon :seal:
Das VLAN 7 hat mit Vodafone schon bestätigt...
Vielleicht gibt es auch doch noch ein anderes Problem - habe das ganze gerade nochmal mit nem TP-Link Router probiert... same story...
Stimmen die Zugangsdaten denn? Also ist es PPPoE und nicht etwa IPoE oder sogar reiner DHCP mit fester MAC?
Jep alles ganz normal als PPPOE
Wenn ich nen Fehler in die Zugangsdaten einbaue oder das "vodafone-ftth.komplett" weglasse kommt auch ein leicht anderer Fehler - Dsl-Leitungsdaten falsch! (fehler 691)
Hmmm...
Die Fehlermeldung bei falschem VLAN wäre auch anders (PADO Timeout), deshalb gehe ich davon aus, dass es wirklich falsche Zugangsdaten sind. Noch mal bei VF überprüfen bzw. im Onlineportal vielleicht einsehen?
Scheinbar wirklich ein Fall für Dr. Vodafone... Störungsmeldung läuft... Da ist scheinbar was bei der Umstellung auf Glasfaser schiefgelaufen...:face_with_spiral_eyes:
Bin gespannt, sag mir gern Bescheid, wenn VF sich gemeldet hat :wink:
Die Entstörung ist durch - da hat sich bei der Tarifumstellung was aufgehängt wodurch sowohl VDSL als auch Glasfaseranschluss nicht mehr funktioniert haben.... - Im Zuge des ganzen Dramas hab ich die VF gleich noch überzeugt mir doch nen Dual Stack Anschluss zu schalten :innocent:.
War also tatsächl. kein Thema mit dem Router!
LG,
Norbert
Good to hear that this wasn't an issue with the router itself :slight_smile:
Dir noch einen schönen Tag!
