unable to achieve 1g/1g download/upload with the Flint 2 on any firmware except the 4.6.6op24 rc from October of 2024.
upload seems to cap at 300, anyone know how to fix this or am i doomed to use an old fw
Did you use speedtest.net to test the UL 300Mbps? Please try manually selecting other speedtest nodes. And try more speed websites (like if available to access fast.com). Is the client wired or wireless to run speedtest?
If the laptop is directly connected to the ISP modem, is it available to get DL 1G / UL 1G?
Did you set up speed limit or install speed limit plugins?
Try changing to software acceleration, or disable the acceleration.
Thanks Tim for shooting over some ideas, i went ahead and installed 4.7.0 stable
ran /etc/init.d/gl_eqos stop && /etc/init.d/gl_eqos disable
still seeing poor upload, limited to only 100 upload now.
May I know the v4.7.5-op24 firmware also same issue?
Please check my previous post:
firmware 4.7.5-op24 did not make a difference
How about the speedtest if the Ethernet 2 (WAN/LAN1, 2.5G port) switch to WAN mode and connect to ONT?
