Just wondering, why can’t I manually select a channel for 5GHZ wifi SSID without it failing to work? The wifi (set as hidden) cant then be detected. I have to leave it on auto and it works fine. Other wifi channels in my surround area are all on the same range.
I would say this is a bug as it used to be working when I got the router and it works fine when I’m on OpenWRT.
Im currently on 4.8.3.
