MT6000 won't connect to Internet Repeater mode
Just got this MT6000 (I also have a Beryl MT1300, and an AXT1800 slate. Am trying to use the router in repeater mode (wifi), as that is the only way I can connect this part of the house to another router in another part of the house (cannot use an ethernet connection). It does connect to the other router (not GliNet), but there is no Internet. Can't figure out what is happening. Haven't upgraded firmware yet but I doubt that is the problem. It will give internet via the guest wifi, but none through the standard wifi channel or ethernet.
What I've tried:
factory reset
changing to various addresses from the default 192.168.8.1.
ping the gateway of the other router (conneceted to the modem) = unreachable
pinging 8.8.8.8 or 9.9.9.9 = unreachable
ping my phone when it is connected to MT6000 = works correctly
using my phone to ping google: 100% loss
Thanks
  1. the issue screenshot, like GL GUI - Internet - Repeater
  2. Use MT1300 or AXT1800 to compare tests, can they repeater connection be available?
  3. The magic is that Guest WiFi is available, but the private WiFi and wired are not available? Is this true?
  1. Provide issue syslog after repeater connected.
  2. SSH to the router:
ifconfig
ip r
and ping the primary WiFi router IP
Yes, my MT1300 and AXT-1800 have no problem connecting and working correctly. See attached pic. Yes, it's true, Guest wifi can access the internet; Primary cannot either through RJ-45 or wifi.
Primary lan 192.168.110.1
Guest lan 192.168.111.1
System log
Thu Dec 12 21:15:22 2024 cron.err crond[4043]: time disparity of 3262 minutes detected
Thu Dec 12 21:16:00 2024 cron.err crond[4043]: USER root pid 10632 cmd . /lib/functions/modem.sh;check_ip
Thu Dec 12 21:16:00 2024 cron.err crond[4043]: USER root pid 10633 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Thu Dec 12 21:16:00 2024 cron.err crond[4043]: USER root pid 10634 cmd . /lib/functions/modem.sh;modem_net_monitor
Thu Dec 12 21:16:05 2024 authpriv.info dropbear[10676]: Child connection from 192.168.110.18:34854
Thu Dec 12 21:16:19 2024 authpriv.warn dropbear[10676]: Login attempt for nonexistent user
Thu Dec 12 21:17:00 2024 cron.err crond[4043]: USER root pid 10876 cmd . /lib/functions/modem.sh;check_ip
Thu Dec 12 21:17:00 2024 cron.err crond[4043]: USER root pid 10877 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Thu Dec 12 21:17:03 2024 authpriv.info dropbear[10676]: Exit before auth from <192.168.110.18:34854>: Max auth tries reached - user 'is invalid'
Thu Dec 12 21:17:11 2024 authpriv.info dropbear[10941]: Child connection from 192.168.110.18:33682
Thu Dec 12 21:17:11 2024 authpriv.warn dropbear[10941]: Login attempt for nonexistent user
Thu Dec 12 21:18:00 2024 cron.err crond[4043]: USER root pid 11110 cmd . /lib/functions/modem.sh;check_ip
Thu Dec 12 21:18:00 2024 cron.err crond[4043]: USER root pid 11111 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Thu Dec 12 21:18:00 2024 cron.err crond[4043]: USER root pid 11112 cmd . /lib/functions/modem.sh;modem_net_monitor
Thu Dec 12 21:19:00 2024 cron.err crond[4043]: USER root pid 11335 cmd . /lib/functions/modem.sh;check_ip
Thu Dec 12 21:19:00 2024 cron.err crond[4043]: USER root pid 11336 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Thu Dec 12 21:19:22 2024 authpriv.info dropbear[10941]: Exit before auth from <192.168.110.18:33682>: Max auth tries reached - user 'is invalid'
Thu Dec 12 21:20:00 2024 cron.err crond[4043]: USER root pid 11568 cmd . /lib/functions/modem.sh;check_ip
Thu Dec 12 21:20:00 2024 cron.err crond[4043]: USER root pid 11569 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Thu Dec 12 21:20:00 2024 cron.err crond[4043]: USER root pid 11570 cmd . /lib/functions/modem.sh;modem_net_monitor
Thu Dec 12 21:21:00 2024 cron.err crond[4043]: USER root pid 11805 cmd . /lib/functions/modem.sh;check_ip
Thu Dec 12 21:21:00 2024 cron.err crond[4043]: USER root pid 11806 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Thu Dec 12 21:22:00 2024 cron.err crond[4043]: USER root pid 12021 cmd . /lib/functions/modem.sh;check_ip
Thu Dec 12 21:22:00 2024 cron.err crond[4043]: USER root pid 12022 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Thu Dec 12 21:22:00 2024 cron.err crond[4043]: USER root pid 12023 cmd . /lib/functions/modem.sh;modem_net_monitor
Thu Dec 12 21:23:00 2024 cron.err crond[4043]: USER root pid 12237 cmd . /lib/functions/modem.sh;check_ip
Thu Dec 12 21:23:00 2024 cron.err crond[4043]: USER root pid 12238 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Thu Dec 12 21:23:56 2024 user.info : luci: accepted login on / for root from 127.0.0.1
Thu Dec 12 21:24:00 2024 cron.err crond[4043]: USER root pid 12485 cmd . /lib/functions/modem.sh;check_ip
Thu Dec 12 21:24:00 2024 cron.err crond[4043]: USER root pid 12486 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Thu Dec 12 21:24:00 2024 cron.err crond[4043]: USER root pid 12487 cmd . /lib/functions/modem.sh;modem_net_monitor
Thu Dec 12 21:24:46 2024 authpriv.info dropbear[12693]: Child connection from 192.168.110.18:54776
Thu Dec 12 21:24:57 2024 authpriv.notice dropbear[12693]: Password auth succeeded for 'root' from 192.168.110.18:54776
Thu Dec 12 21:25:00 2024 cron.err crond[4043]: USER root pid 12734 cmd . /lib/functions/modem.sh;check_ip
Thu Dec 12 21:25:00 2024 cron.err crond[4043]: USER root pid 12735 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Thu Dec 12 21:26:00 2024 cron.err crond[4043]: USER root pid 12955 cmd . /lib/functions/modem.sh;check_ip
Thu Dec 12 21:26:00 2024 cron.err crond[4043]: USER root pid 12956 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Thu Dec 12 21:26:00 2024 cron.err crond[4043]: USER root pid 12957 cmd . /lib/functions/modem.sh;modem_net_monitor
Thu Dec 12 21:27:00 2024 cron.err crond[4043]: USER root pid 13182 cmd . /lib/functions/modem.sh;check_ip
Thu Dec 12 21:27:00 2024 cron.err crond[4043]: USER root pid 13183 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Thu Dec 12 21:28:00 2024 cron.err crond[4043]: USER root pid 13400 cmd . /lib/functions/modem.sh;check_ip
Thu Dec 12 21:28:00 2024 cron.err crond[4043]: USER root pid 13401 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Thu Dec 12 21:28:00 2024 cron.err crond[4043]: USER root pid 13402 cmd . /lib/functions/modem.sh;modem_net_monitor
Thu Dec 12 21:28:16 2024 authpriv.info dropbear[12693]: Exit (root) from <192.168.110.18:54776>: Disconnect received
Thu Dec 12 21:28:32 2024 authpriv.info dropbear[13551]: Child connection from 192.168.110.18:39420
Thu Dec 12 21:28:35 2024 authpriv.notice dropbear[13551]: Password auth succeeded for 'root' from 192.168.110.18:39420
Thu Dec 12 21:29:00 2024 cron.err crond[4043]: USER root pid 13628 cmd . /lib/functions/modem.sh;check_ip
Thu Dec 12 21:29:00 2024 cron.err crond[4043]: USER root pid 13629 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Thu Dec 12 21:30:00 2024 cron.err crond[4043]: USER root pid 13847 cmd . /lib/functions/modem.sh;check_ip
Thu Dec 12 21:30:00 2024 cron.err crond[4043]: USER root pid 13848 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Thu Dec 12 21:30:00 2024 cron.err crond[4043]: USER root pid 13849 cmd . /lib/functions/modem.sh;modem_net_monitor
Thu Dec 12 21:31:00 2024 cron.err crond[4043]: USER root pid 14064 cmd . /lib/functions/modem.sh;check_ip
Thu Dec 12 21:31:00 2024 cron.err crond[4043]: USER root pid 14065 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Thu Dec 12 21:31:36 2024 authpriv.info dropbear[14226]: Child connection from 192.168.110.18:41654
Thu Dec 12 21:31:40 2024 authpriv.notice dropbear[14226]: Password auth succeeded for 'root' from 192.168.110.18:41654
Thu Dec 12 21:31:48 2024 authpriv.info dropbear[14226]: Exit (root) from <192.168.110.18:41654>: Disconnect received
Thu Dec 12 21:32:00 2024 cron.err crond[4043]: USER root pid 14289 cmd . /lib/functions/modem.sh;check_ip
Thu Dec 12 21:32:00 2024 cron.err crond[4043]: USER root pid 14290 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Thu Dec 12 21:32:00 2024 cron.err crond[4043]: USER root pid 14291 cmd . /lib/functions/modem.sh;modem_net_monitor
Thu Dec 12 21:32:26 2024 authpriv.info dropbear[14399]: Child connection from 192.168.110.18:47124
Thu Dec 12 21:32:31 2024 authpriv.notice dropbear[14399]: Password auth succeeded for 'root' from 192.168.110.18:47124
Thu Dec 12 21:33:00 2024 cron.err crond[4043]: USER root pid 14509 cmd . /lib/functions/modem.sh;check_ip
Thu Dec 12 21:33:00 2024 cron.err crond[4043]: USER root pid 14510 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Thu Dec 12 21:33:03 2024 authpriv.info dropbear[14399]: Exit (root) from <192.168.110.18:47124>: Exited normally
Thu Dec 12 21:33:30 2024 authpriv.info dropbear[14645]: Child connection from 192.168.110.18:52312
Thu Dec 12 21:33:35 2024 authpriv.notice dropbear[14645]: Password auth succeeded for 'root' from 192.168.110.18:52312
Thu Dec 12 21:34:00 2024 cron.err crond[4043]: USER root pid 14727 cmd . /lib/functions/modem.sh;check_ip
Thu Dec 12 21:34:00 2024 cron.err crond[4043]: USER root pid 14728 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Thu Dec 12 21:34:00 2024 cron.err crond[4043]: USER root pid 14729 cmd . /lib/functions/modem.sh;modem_net_monitor
Thu Dec 12 21:34:02 2024 authpriv.info dropbear[14645]: Exit (root) from <192.168.110.18:52312>: Exited normally
Thu Dec 12 21:35:00 2024 cron.err crond[4043]: USER root pid 14945 cmd . /lib/functions/modem.sh;check_ip
Thu Dec 12 21:35:00 2024 cron.err crond[4043]: USER root pid 14946 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Thu Dec 12 21:36:00 2024 cron.err crond[4043]: USER root pid 16744 cmd . /lib/functions/modem.sh;check_ip
Thu Dec 12 21:36:00 2024 cron.err crond[4043]: USER root pid 16745 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Thu Dec 12 21:36:00 2024 cron.err crond[4043]: USER root pid 16746 cmd . /lib/functions/modem.sh;modem_net_monitor
Thu Dec 12 21:37:00 2024 cron.err crond[4043]: USER root pid 16970 cmd . /lib/functions/modem.sh;check_ip
Thu Dec 12 21:37:00 2024 cron.err crond[4043]: USER root pid 16971 cmd sleep 30;. /lib/functions/modem.sh;check_ip
ifconfig
apcli0 Link encap:Ethernet HWaddr 9A:39:BC:71:B2:F3
inet addr:192.168.10.48 Bcast:192.168.10.255 Mask:255.255.255.0
inet6 addr: fe80::9839:bcff:fe71:b2f3/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:6230 errors:0 dropped:0 overruns:0 frame:0
TX packets:6299 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:362681 (354.1 KiB) TX bytes:310683 (303.4 KiB)
apclix0 Link encap:Ethernet HWaddr 9E:83:C4:A7:53:75
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
br-guest Link encap:Ethernet HWaddr 96:63:D1:C6:B3:84
inet addr:192.168.111.1 Bcast:192.168.111.255 Mask:255.255.255.0
TX packets:1 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:153 (153.0 B)
br-lan Link encap:Ethernet HWaddr 94:83:C4:A7:53:74
inet addr:192.168.110.1 Bcast:192.168.110.255 Mask:255.255.255.0
RX packets:2656 errors:0 dropped:0 overruns:0 frame:0
TX packets:2007 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:395360 (386.0 KiB) TX bytes:2072415 (1.9 MiB)
eth0 Link encap:Ethernet HWaddr 1E:D4:06:AC:86:2D
inet6 addr: fe80::1cd4:6ff:feac:862d/64 Scope:Link
TX packets:3024 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:98149 (95.8 KiB) TX bytes:2166797 (2.0 MiB)
Interrupt:119
eth1 Link encap:Ethernet HWaddr 94:83:C4:A7:53:72
Interrupt:119
lan1 Link encap:Ethernet HWaddr 94:83:C4:A7:53:74
lan2 Link encap:Ethernet HWaddr 94:83:C4:A7:53:74
lan3 Link encap:Ethernet HWaddr 94:83:C4:A7:53:74
lan4 Link encap:Ethernet HWaddr 94:83:C4:A7:53:74
lan5 Link encap:Ethernet HWaddr 94:83:C4:A7:53:74
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:4607 errors:0 dropped:0 overruns:0 frame:0
TX packets:4607 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:1093275 (1.0 MiB) TX bytes:1093275 (1.0 MiB)
ra0 Link encap:Ethernet HWaddr 26:47:0E:5C:66:AF
Interrupt:6
rax0 Link encap:Ethernet HWaddr 56:01:6B:D7:66:59
rax1 Link encap:Ethernet HWaddr 96:63:D1:C6:B3:84
========== ip -r ==============
Usage: ip [ OPTIONS ] OBJECT { COMMAND | help }
ip [ -force ] -batch filename
where OBJECT := { link | address | addrlabel | route | rule | neigh | ntable |
tunnel | tuntap | maddress | mroute | mrule | monitor | xfrm |
netns | l2tp | fou | macsec | tcp_metrics | token | netconf | ila |
vrf | sr | nexthop | mptcp }
OPTIONS := { -V[ersion] | -s[tatistics] | -d[etails] | -r[esolve] |
-h[uman-readable] | -iec | -j[son] | -p[retty] |
-f[amily] { inet | inet6 | mpls | bridge | link } |
-4 | -6 | -I | -D | -M | -B | -0 |
-l[oops] { maximum-addr-flush-attempts } | -br[ief] |
-o[neline] | -t[imestamp] | -ts[hort] | -b[atch] [filename] |
-rc[vbuf] [size] | -n[etns] name | -N[umeric] | -a[ll] |
-c[olor]}
Sorry, I don't know what you are looking for, and I don't know what options, etc. you need.
============= ping ==============
ping -c 2 192.168.110.1
PING 192.168.110.1 (192.168.110.1) 56(84) bytes of data.
64 bytes from 192.168.110.1: icmp_seq=1 ttl=64 time=0.720 ms
64 bytes from 192.168.110.1: icmp_seq=2 ttl=64 time=0.767 ms
--- 192.168.110.1 ping statistics ---
2 packets transmitted, 2 received, 0% packet loss, time 1006ms
rtt min/avg/max/mdev = 0.720/0.743/0.767/0.023 ms
  1. No key information is seen in the log. Please provide issue syslog again when the step 4 complete and issue occurs again.
  2. Checked all the configurations you attached, and there is no problem. (It is ip r,not ip -r, but it does not matter.)
  3. The private WiFi and LAN can not access, but the guest WiFi can access. That's amazing. Maybe the "br-lan" interface gateway is configured incorrectly..
  4. Please upgrade the firmware to latest 4.7.0 without 'keep settings', and re set-up the repeater again.
It's no wonder I had a problem. The router must not have been new. There was an address in the DNS under /Network/Lan. That kept everything from working correctly. I did upgrade to 4.7, and also saved settings. Think I'll re ugrade and wipe settings.
What the DNS address is? you manual set up or automatic obtain from primary?
If manual set up, can select the recommended DNS group.
