Mudi 7 Travel Case
Hi all,
Has anyone found a slim case for the Mudi 7 in Europe, specifically Germany?
The included case is too bulky for my travel setup. I'm after a "just-right" fit for device protection only. Extra space for cables and adapters isn’t needed as I already have that covered.
I've seen US options on Reddit but they point to Amazon.com, and don’t deliver to Europe. Challenge is sellers often do not list internal dimensions. I want to avoid trial-and-error returns if possible.
Thanks!
go to etsy and find a bloke in your country that will custom-make one for you.
Nice idea, I hadn’t even considered that. I will take a look.
In the interim, I have ordered a soft case from Ali to be going on with.
i bought this:
https://www.amazon.it/dp/B072HJ4FTX
I also found the included case way too bulky so I just made a little pouch out of PU-leather.
I picked up the Ugreen case suggested by saitobenkei. Thanks for the pointer.
I had to modify it slightly and cut out one of the bubbles to stop it pushing the power button and starting the device in the case. That done, the case seems to be pretty good. Got my spare SIM card and a short power cable in there with the deivce. I will see how it performs next week when I am travelling.
Just need to tidy up the cut a little now I know it works as a solution.
How about if you turn Mudi facing downward instead, then no need to cut off the pad. :slight_smile:
if you look in the link above to the case on Amazon, you’ll see both sides have these padded bubbles. Exactly the same spacing and effect.
And just to add, or close out the topic from my side. My Mudi 7 has completed a flight today in this case in a tightly packed bag. No accidental starts due to the power button being pressed now I made the cut. Its a winner from my side.
