Mudi 7 trouble with ftp
Hello, I have a specific situation that is not working. Wondering if anyone has any insight. All firmware is up to date. 4.10. and these exact devices work flawlessly on any of my unifi routers.
I have 3 devices on the LAN. One iPad running ftp software. and 2 canon r5 mark 2 mirrorless cameras. They connect to the iPad via ftp, and send small jpegs when I take a picture with either camera. The issue is, regardless of which camera it is, whatever camera that connects SECOND, is very slow to send, and even times out and fails to send images. if Camera A connects second, it cannot send images reliably. but if it connects first, its very snappy.
Is there some setting in OpenWRT/mudi7 firmware that prevents two clients from connecting to one ftp server on the LAN? Is there something im missing? im stumped.
Thank you for the detailed report.
To help us investigate this issue, could you please clarify a few details?
  1. When the second camera experiences slow transfers or timeouts, can the first camera still transfer images normally?
  2. How are the iPad and the two cameras connected to the Mudi 7? If they use Wi-Fi, which frequency band is each device connected to (2.4 GHz, 5 GHz, or 6 GHz)?
  3. When the camera that connects to the FTP server second experiences very slow image transfers, timeouts, or failed transfers, could you export the Mudi 7 system log and send it to us via private message?
Thank you for your understanding and support.
Thanks for the reply:
  1. Yes, it seems that the first camera to connect is able to maintain a fast connection.
  2. they're all connected to the same wifi SSID, and I tested with both 5Ghz and 6Ghz. I noticed the issue on a photoshoot, where I use the router, and then tested at home in a controlled environment. each device is about 1ft from the router to eliminate any reception issues.
  3. Sure, can you tell me how to do that?
Also, now neither camera can send images. the issue is definitely intermittent. last night when I was troubleshooting, it was working fast on one camera and not at all on the other camera. Now it takes several (20) seconds to send an image from either camera.
Thank you for the update.
If only one camera is connected to the router, will it still experience lag or stuttering over time?
You can send a private message by following these steps:
Thank you for your patience and understanding.
Haha thanks. I know how to send a DM, I meant how do I generate a log file :slight_smile:
I edited this response because I just tried turning things on again, and yes, the first camera remains speedy, and the second camera just hangs. maybe sending one image after a minute, sometimes just failing.
Go to the admin panel, System, Log, and hit Export Log.
thanks. DM sent to Charles.
Similar setup but I run an FTP server on my MacBook Air M5 and have a pair of Canon EOS R1 cameras sending CR3 raw images into a live ingest folder. 6 GHz wifi connection using the Mudi as a wireless hotspot, 17MB images arrive in a second or so from each camera. This usually works fine but every now and again one of the cameras will drop out for a few minutes and then resume the connection. Very odd.
Ahh perfect. Another person doing exactly this. Yes, I use the MacBook as well but with a different router. This travel one is when I’m running light and to an iPad. Ideally(obviously) it would work with iPads and MacBooks and whatever as the target server but trying to narrow the scope of this problem first to get it sorted with the iPad.
I’m doing r5mk2’s and am usually only sending small JPEGs so it’s lightning fast.
Is there any updates to this? Charles, did you get the log? I'd really like to use this router, but it's broken in it's current state for me.
Could you please try the following steps one at a time and check whether the transfer performance improves?
  1. Set the 5 GHz Wi-Fi to 802.11ax with an 80 MHz channel width.
    Please connect to the Mudi 7 via SSH and run the following commands:
uci set wireless.wifi1.hwmode='11axa'
uci set wireless.wifi1.htmode='HE80'
uci commit wireless
wifi reload
  1. Select an available DFS channel in the Mudi 7’s 5 GHz wireless settings and repeat the test.
  2. If possible, run the FTP server on your Mac and connect the Mac to the Mudi 7’s LAN port using an Ethernet cable.
    Alternatively, try a Windows computer or an Android device connected via Wi-Fi as the FTP server.
Thank you for your support and understanding.
  1. I get the following errors after the last line:
    root@GL-E5800:~# uci set wireless.wifi1.hwmode='11axa'
root@GL-E5800:~# uci set wireless.wifi1.htmode='HE80'
root@GL-E5800:~# uci commit wireless
root@GL-E5800:~# wifi reload
cfg80211tool.1: unrecognized option: mcastenhance
parseCmdinputs:1263 Unsupported Command
cfg80211tool.1: unrecognized option: value0
Unknown Command : 25
Unknown Command : 4
Unknown Command : 3
sh: out of range
Command failed: Not found
The issue is still there.
  1. I selected DFS 64 and waited the 60 seconds. The issue improved. I’d like to think it’s from interference, but I had the connection issue in the middle of a farm field with zero other wifi around.
I then checked my environment with a spectrum analyzer on one of my APs and channel 36 was completely clear, so I tried that next. The issue returned exactly like before. The first camera is fast, the second camera stalls.
  1. The above issues are the same regardless if connected to a computer running the software, or the iPad.
Thank you for testing these options and sharing the detailed results. The messages shown after running wifi reload are expected and do not affect normal operation.
We have forwarded this issue and your latest test results to the relevant team for further investigation. Since using DFS channel 64 improved the transfers, we recommend continuing to use that channel as a temporary workaround.
We’ll update you here as soon as we have new information or a fix. Thank you for your understanding and support.
Ok understood. Thank you.
Further info: I can confirm that this issue is not resolved on FW 4.10.2. Exact same behavior, and switching to a DFS channel solves the issue and both cameras can send images.
Thank you for the update and for confirming the behavior on firmware 4.10.2.
Our team is still investigating this issue and working on a fix, and we’ll update you here while we have further progress.
