I have worked on this problem over a couple of days and used what worked before. After not using it for some time i can not seem to get the LTE to work. No issues before. I have not touched it in a while and when i put a AT&T sim card in it ( this sim works in two other LTE routers) it do not get a internet connection but it seems LTE does connect. I have attached a Screen shot of the Modem page from the main internet screen. I have gone as far as a full wipe and setup with no real reason to the issue. I am on 4.0 Any ideas?
Update: Downgraded back to 3.x and i can connect and use it just fine. Something is going on in 4.x that is causing a issue. Please let me know if there is something i can do for fix the issue with 4.x
you should enable SSH and remote webaccess
Contact our technical support team and send them your device mac and password.
Or send it to this email [email protected]
