Is there any way to indicate a preference to use a specific lte band for example firstnet band14 as first preference. Is that specifiable in one of the /etc/config files?
Can you just lock to that band 14?
@alzhao
Can you tell me what the process is to lock to a specific lte hand. In my specific case, I want to use lte band 14 when available. What if the band isn’t available, is there a fallback lte band that can be specfied
In the web panel, go to AT command section and you will find preconfigred AT command to lock band.
Just to quickly ask a question regarding Mudi:
Is there any plan to have an upgraded version of Mudi? OpenWRT version upgrade, better wifi speed, etc.
It is a Wish!
No plan yet.
