Does Mudi+EP06-A work on Verizon network in USA?
T-Mobile SIM card works on Mudi+EP06-A. Verizon SIM Card (a normal phone sim card activated using an iPhone) doesn’t register. It shows Verizon, no connection.
Any tips?
Any tips?
By the way, both T-Mobile and Verizon sim cards works in the Mudi when I switched the EP06-A with a EC25-AF card.
So EC25-AF works well on both network, but EP06-A only works with T-Mobile, not Verizon.
Please help.
Verizon is fairly particular about what Data Modules they allow on their network…
For a list of supported/approved modules see the link below
https://opendevelopment.verizonwireless.com/design-and-build/approved-modules
hope this helps.
EP06-A is listed in verizon site. but somehow it didn’t work in Mudi.
The same Verizon SIM card works with EP25-AF in the same Mudi.
Any specific settings I need to do for EP06-A?
I don’t have a Mudi - but maybe check the APN? Some modems have built in profiles that are used if the APN is not specified in the connection settings.
Should be “vzwinternet” - and the SIM card should allow for tethering if it is a phone SIM…
Should work I would think if the device is on VZ’s approved list.
