How to do a factory reset using the reset button? I’m not able to conncect to the web interface.
Try this:
Open the SIM cover, there is a big hole with label “reset”.
While the router boot up normally, use a pin to press and hold it for 10 seconds, then release the pin.
thank you! this works.
What worked for me:
Hold the pin down while initiating a Power Up, keep holding it engaged while you see the Reset countdown, only release when you see the message “Please Open Web”.
