@alzhao
On the Mudi e750 router, Is it possible to map the switch to a custom script so I can start and stop a script instead of starting and stopping a vpn or tor when the switch is turned up or turned down. How would I go about getting this control?
Any help greatly appreciated
Thanks
While if you set it up to turn on/off vpn or tor, you can actually see how it works.
Pls check the following files to see how it works.
/etc/init.d/initswitch
/usr/bin/switchaction
In this file /etc/config/glconfig
you can find the defination of switch buttion actions if you have set in the UI. You can change to your own function
config service 'switch_button'
option enable '1'
option function 'myfun'
Then in /usr/bin/switchaction
you can write your own script like below. You need to add both on and off
"myfun")
#this is your own script, toggle on
/usr/bin/myownscript.sh on
Like in this images. /usr/bin/myownscript.sh
is your own script
Thanks for the detailed response. It works !
