Mudi GL-E750 with EG25-G, facing slowness with 4G
The E750’s CPU is QCA9531, and its encryption performance is far inferior to the IPQ60000 of the AX1800.
is there any way that we can increase the speed by changing some settings ?
i mean in the openvpn to use less encryptions
E750’s cpu could achieve up to 17Mbps openvpn in our local test.
In real test 8-10mbps should be OK.
Definitely you can change the encryption to have a test.
Im using AES-128-CBC with UDP protocol. yet i get 3 Mbps
Can you try TCP?
Usutally UDP is faster but UDP is likely to be throttled.
to be honest with you i have VPN subscription which uses AES-256 and with this i get more than 5 Mbps on E750.
Whereas the VPN server hosted on my home router has AES-128 and with E750 it gives 3Mbps or less, but this same VPN on my Huawei router gives more than 5Mbps.
This behavior is very strange.
Please advice.
