I bought a MUDI from GL Technologies in Shopee Philippines last July 4, 2023. I tested the item last July 10 and finds it functional. I followed its documentation found in their website and the related topics and issues in the forum.
I did experience unusual issue on my MUDI concerning very slow charging last September. If turn off, it takes more than 8 hours to completely charge the battery using other type c charging cable because the supplied charging cable keep loosen up after awhile and suddenly discharge itself. If turn on, it will slowly decreases it battery percentage and the cable will keep loosen up after sometime. I did couple of times to reset the router and use a pin to reset its MCU. Up to this writing, I will turn off the router and let it completely charge using the recommended charger. I manage somehow after trial and error in placing the cable to the charging port to continue charging the battery. I updated the firmware to its latest stable. I really like the latest firmware because Tor is functioning well, the cellular network has been optimized and much features has been enhanced except the battery charging of the router.
Is this really normal? I did not experience anything like this last July and August. Kindly help me on this issue. Thanks and God bless.
