Hello!
I have portable 4G LTE Router. It works fine until I travel to another country and my SIM card uses EU roaming. Then the provider is no longer shown on the display. Also at https://192.168.8.1/#/internet I get the error message "Unknown error occurred. Please check the network environment or reboot the device". And the "Cellular" tab remains empty.
System log shows:
Thu Sep 19 16:32:12 2024 kern.info kernel: [ 2026.982439] do_page_fault(): sending SIGSEGV to glc for invalid write access to 00000000
Thu Sep 19 16:32:12 2024 kern.info kernel: [ 2026.982456] epc = 77e08e90 in libc.so[77de4000+a9000]
Thu Sep 19 16:32:12 2024 kern.info kernel: [ 2026.982489] ra = 77d788f5 in modem.so[77d64000+2e000]
Thu Sep 19 16:32:18 2024 kern.info kernel: [ 2032.728177] do_page_fault(): sending SIGSEGV to glc for invalid write access to 00000000
Thu Sep 19 16:32:18 2024 kern.info kernel: [ 2032.728195] epc = 77e2ae90 in libc.so[77e06000+a9000]
Thu Sep 19 16:32:18 2024 kern.info kernel: [ 2032.728229] ra = 77d9a8f5 in modem.so[77d86000+2e000]
Thu Sep 19 16:32:25 2024 kern.info kernel: [ 2039.412100] do_page_fault(): sending SIGSEGV to glc for invalid write access to 00000000
Thu Sep 19 16:32:25 2024 kern.info kernel: [ 2039.412118] epc = 77e56e90 in libc.so[77e32000+a9000]
Thu Sep 19 16:32:25 2024 kern.info kernel: [ 2039.412155] ra = 77dc68f5 in modem.so[77db2000+2e000]
Thu Sep 19 16:32:25 2024 kern.info kernel: [ 2039.765927] do_page_fault(): sending SIGSEGV to glc for invalid write access to 00000000
Thu Sep 19 16:32:25 2024 kern.info kernel: [ 2039.765945] epc = 77da8e90 in libc.so[77d84000+a9000]
Thu Sep 19 16:32:25 2024 kern.info kernel: [ 2039.765979] ra = 77d188f5 in modem.so[77d04000+2e000]
Kernel Log:
[ 2442.300469] do_page_fault(): sending SIGSEGV to glc for invalid write access to 00000000
[ 2442.300488] epc = 77e2ce90 in libc.so[77e08000+a9000]
[ 2442.300521] ra = 77d9c8f5 in modem.so[77d88000+2e000]
[ 2448.294899] do_page_fault(): sending SIGSEGV to glc for invalid write access to 00000000
[ 2448.294917] epc = 77df6e90 in libc.so[77dd2000+a9000]
[ 2448.294949] ra = 77d668f5 in modem.so[77d52000+2e000]
[ 2454.031314] do_page_fault(): sending SIGSEGV to glc for invalid write access to 00000000
[ 2454.031331] epc = 77db6e90 in libc.so[77d92000+a9000]
[ 2454.031364] ra = 77d268f5 in modem.so[77d12000+2e000]
[ 2460.038568] do_page_fault(): sending SIGSEGV to glc for invalid write access to 00000000
[ 2460.038584] epc = 77e1ee90 in libc.so[77dfa000+a9000]
[ 2460.038618] ra = 77d8e8f5 in modem.so[77d7a000+2e000]
Nginx Log:
Oops Log extractor (build Apr 9 2023 12:27:46).
No logs present
2024/09/19 16:40:43 [error] 3997#0: *1690 upstream prematurely closed FastCGI stdout while reading response header from upstream, client: 127.0.0.1, server: , request: "POST /rpc HTTP/1.1", subrequest: "/cgi-bin/glc", upstream: "fastcgi://unix:/var/run/fcgiwrap.socket:", host: "127.0.0.1"
2024/09/19 16:40:49 [error] 3997#0: *1692 upstream prematurely closed FastCGI stdout while reading response header from upstream, client: 127.0.0.1, server: , request: "POST /rpc HTTP/1.1", subrequest: "/cgi-bin/glc", upstream: "fastcgi://unix:/var/run/fcgiwrap.socket:", host: "127.0.0.1"
I use VPN WireGuard Client.
I changed Wi-Fi Name (SSID) and password.
The Multi-WAN Interface Status Tracking Method are "Internet always available when the interface is connected".
MAC Address: Manual / Random
Schedule Reboot and Wi-Fi Scheduled Mode
"Switch TX Power" are ON.
My other settings remain default.
The errors remain after a reboot. If I reset the router, it works again but only until I change the country again.
Please help.
