Yiki
April 23, 2024, 4:48pm
If I will flash this I need to use factory mode? Also, what will I loose if I flash clear OpenWRT? I see too much bloatware on my router that takes too much space.
Anyone did something like this? Can you please tell what will i need to know? Will I be able to change IMEI?
admon
April 23, 2024, 4:49pm
2
No, always use Sysupgrade to keep Uboot, which is important if you want to go back or need to restore the router. But you should avoid keeping the settings.
Ofc you will lose GL GUI and all embedded software.
Yiki
April 23, 2024, 5:03pm
3
What exactly embedded software is the most valuable that I will loose?
admon
4
The GUI.
In OpenWrt you will get luci
only.
All other software can be installed manually.
Yiki
April 23, 2024, 5:04pm
5
admon:
The GUI.
And that’s all? Will I still be able to use Tor or change IMEI?
admon:
restore the router.
You mean by reset button?
admon
April 23, 2024, 5:05pm
6
You might use Tor but manually then. And changing IMEI I don’t know.
In that case the OpenWrt community and OpenWrt wiki will be your friend.
^- This is how to restore the original firmware. By uploading the original one then.
Yiki
April 23, 2024, 5:10pm
7
Not really good perspective.
Ok. What should I remove not to have errors or have any troubles? I need to save space to install AGH…
Also… How to remove all logs keeping? Including MAC logs. Not deleting them, exactly disable creating
Install by myself?
admon
April 23, 2024, 5:17pm
8
Yiki:
Install by myself?
OpenWrt plain is for advanced users, so yes, installing by yourself.
https://openwrt.org/docs/guide-user/services/tor/client
Logs are saved in RAM only. Not sure how to disable them, sorry.
Maybe exroot could help, look into the forum for the instructions. Not sure if they work on Mudi (does it have USB?) but worth a try.
Yiki
April 23, 2024, 5:18pm
9
admon:
(does it have USB?)
It have SD. Isn’t it the same?
admon
10
Yep, same. You might use exroot then.
