New Mudi, E750 I Updated to 3.015 didn’t save any settings.
Problems I face
Tor won’t start goes to 40% (my ISP doesn’t block tor) I can’t set the time in the router I change the time zone and makes no change I think this is causing the issue. How can I set the time I try to sync with my browser and set manually neither makes the changes shows date as 2020 so it’s not updating and I think this doesn’t allow tor to start
I can’t find/download LUCI I go to applications / plug-ins and can’t find or download LUCI after updating help.
I almost am giving up on using the Mudi has had many software issues.
I need to use Tor and change the routers name using Luci. Please, Fellow pears help me use the router cant get to work.
1- I tried on 2 web browsers Firefox. I turn off tor and all kill switches and policies,
I go to time zone and click sync, the time changes but not the date. After trying to start tor
error - ! (DATE XX-XX Time XX:XX:XX(notice) (control) bootstrap 40% (loading…keys) loading authority key cert
2- I go to Applications, Plugins, Click update, let it update look for ‘‘Luci’’ says not found. Thanks -Mudi
Thank you for trying to help, but I was just saying that so you don’t ask if I that the device is a brick . If I can’t change the time and date to start tor, and it’s not good that I can’t find luci, I do on my other GL routers. This is an expensive router I need to get it to work can I get direct support ? I reset firmware and tried again. How can I fix this?
