Will Mudi offer a more recent Tor package over the "upgrade" button in Luci? Because bootstrapping freezes at 75% or 85% and I believe this may be the cause:
Did you use/enable the Tor feature in the Luci/Bootstrap and not in the GL Admin Panel?
Did you mean the Tor cannot work and it go to 85% but the process freeze?
Probably your ISP block the Tor network traffic?
Update:
Solution here (probably needs to be incorporated in your software because a factory reset clears this setting)
Sysctl.conf needs an edit.
