Mudi V2 on current 4.3.26 firmware.
Tor indicates connecting but never actually connects.
Worth mentioning that Tor worked just fine on earlier firmware versions.
Any suggestions?
Thank you!
Any suggestions?
Thank you!
Hello @bruce and thank you for your support.
Yes, if I downgrade, Tor will work (which eliminates “some regional policies will interfere with Tor's connection.”).
Is there a solution or temporary workaround for running Tor on 4.3.26?
Thank you.
