check replies please !! i need no tor on guest network !!
and I need a reliable killswitch on main network !
OK I tried this did not work to have (TOR) on main network and regular internet on guest network.
When I did what you said with The (TOR) switch on connected )
I have TOR on main network and no connection at all on guest I cant connect to the internet please check it out thank you
hello can you please address the issue here ???
I need TOR On Main network , And regular internet on guest network.
I did what you said and it didn’t work! ( MAYBE THOSE SETTINGS WORK FOR VPN ON MAIN AND NOT VPN PN GUEST BUT IT DOESNT WORK WITH TOR )
Please please help its been 2 weeks no fix yet
I’m very sorry that it does not support with tor now.
Only openvpn and wireguard support it.
Can you please add that to the offical release! it is nessary for use.
The old version has it i have used this for a long time with no issues but after nedding to upgarde beta I am stuck because without MTU chnge it will not work on old setup.
Can you make A fix please add the correct settings on the new uodate for guest normal network and tor on main when policys are set for vpn. since you dont make tor policys
add mtu settings to old version ???
or add tor to policys on new version .
or just include tor with the vpn policys on new version !
Im Stuck with a unuseable device now
